Old 09-02-2006, 04:45 PM   #1
Slidin240Wayz
Slidin240Wayz's Avatar
Question about S14 Sr20det hose by Throttle Body
Before I took the motor I just cut this hose. I know the air goes to the AICV area; one of the sensors in the middle of the intake manifold. I just don't have a picture of where it went to. I am guessing it went to the IC piping.
Is it necessary to connect it?
If so, where does it connect to?
Any other input about this?
Carlos
Slidin240Wayz is offline   Reply With Quote
Old 09-02-2006, 05:28 PM   #2
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
it connects to the intake intercooler piping that goes to the throttle body...i've kept it and everything runs fine...haven't ran without it though.
sean350z is offline   Reply With Quote
Old 09-02-2006, 05:31 PM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
its the air inlet for the aicv bypass. it goes to a vac line before the TB
Old 09-02-2006, 05:48 PM   #4
Slidin240Wayz
So I am guessing it is necessary. Thanks.
I asked because I wanted to run the IC piping between the frame and the Power brace arms (stock ones) because it does in fact fit, instead of running it through the battery tray.
Carlos
Old 09-02-2006, 05:50 PM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
you can. just put a nipple on the IC pipe and run a vac line to it.
