Old 05-15-2006, 09:48 AM   #1
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
need help fast before i send my s13 ta a shop
i think i fried my wiring harness to my sr20det but only one wire is fried its the black with a white line to hte crank angle sensor. to fix this should i replace it cause i cant figure out how to fix the problem when i put my battery ta start up my car. motor cranks but wont fire up.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 05-15-2006, 11:27 AM   #2
slider2828
slider2828's Avatar
Black with white line is a major line bro... That is like the electrical line. Of course the car won't start because your CA is not getting voltage obviously, therefor it isn't reading the angle of your cams. Anyways you need to replace that line and make sure you voltage to the line is good. Secondly, how did you fry that line? and good luck on your CAS because that thing is super sensitive to anything and expensive to replace... Good Luck
Woops one more thing, the black and white line also should run to MAFS, ECU, ECCS relay (ECU Relay).... Try to trace it
Old 05-16-2006, 09:15 AM   #3
s13silvia123
how did i fried this line the black with the white line. all i did was just put a new battery. i checked all my grounding they were all there but i have no idea why it did that.
