10-27-2020, 03:02 PM | #1 |
Aftermarket z33 diff into s13/14 pumpkin.
I'm having some difficulty selecting a differential for my 1992 Silvia k's. I have an r200 open diff pumpkin that I would like to install a nismo lsd gt pro differential into. The problem is that those differentials come with new axle stubs.
They offer them in 3x2, 5 bolt, and 6 bolt output shafts. 3x2 axles are impossible to find new, and are all used or reman. 5 bolt axles same deal just junk reman ones or used. They have an option to order it with 6 hole gtr style output shafts. Does anyone happen to know if 350z and the skyline shafts share the same specs? I'm just trying to find a way where I can run that nismo lsd, but use new z axles since they're still available new. Also from what I've read it seems that the manual 350z diffs are the same as s13/s14 diffs. Do you think if I was to order a diff for a 350z that comes with the z output shafts that it would be able to work, as long as I use the stock ring and pinion? Any tips or recommendations would be highly appreciated. Thank you.
Need aftermarket parts? PM or DM me competitive pricing! IG@S13Guille |
10-27-2020, 08:13 PM | #3 |
I asked Mike kojima from motoiq, and he said they're the same internals as long as it's a manual diff and you use the s chassis ring gear and Pinion. Not sure if anyone has tried it though.
10-30-2020, 06:24 AM | #4 |
Why not spend the coin and just convert to the Z33 R200?
