Old 10-03-2014, 02:48 PM   #1
kaptin
kaptin is an unknown quantity at this point
S13 Chassis Harness and S.M.J. Pinout
Hello Zilvia,
I've been working on my chassis harness and have put together a good bit of info to help me stay organized... Hope someone else might find it useful.
My coupe does not have A.B.S., and as I understand that is the biggest differences in the chassis harness for the s13.
I am also not running fog lights, ac, or the A.S.C.D.
All the info was pulled from the 1989 F.S.M.
PLUGS NOT LISTED
E5 - REAR WASHER MOTOR
E6 - FRONT WASHER MOTOR
E7 - FLUID LEVEL SWITCH
E12 - INHIBITOR SWITCH
E13 - REVOLUTION SENSOR
E14 - INHIBITOR SWITCH
E15 - TO SOLENOID VALVE SUB-HARNESS
E43 – Dropping resistor
E44 – Compressor
E46 – A.I.V. control solenoid valve
E51 – To engine room harness (E28(FOG HARNESS))
E52 – Front fog lamp R.H.
E53 – Front fog lamp L.H.
E54 – Front wheel sensor L.H.
E56 – Actuator
E58 – A.S.C.D. actuator
E106 – Key lock solenoid
E114 – To E.F.I. harness (F3)
E115 – To E.F.I. harness (F4)
E116 – To E.F.I. harness (F5)
E117 – A/T control unit
E118 – A.S.C.D. control unit
Pinout for the S.M.J. (E101)
Plugs and Pinouts
Wire Colors and Wire routs
Fuse box labels
Again I hope this helps. Zilvia has been a huge help on my build and I'm hoping to give back a little. Any questions or corrections, lemme know.
Thanks guys!
kaptin is offline
Old 10-06-2014, 09:55 AM   #2
Dori240
Dori240 is an unknown quantity at this point
Thanks for the break down!
Dori240 is offline
Old 11-23-2019, 10:29 PM   #3
nikitos260496
nikitos260496 is an unknown quantity at this point
Hey, I can’t see the pictures for some reason
nikitos260496 is offline
Old 11-24-2019, 09:00 AM   #4
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
because Photobucket has ruined every single photo hosted on their site.
also going to lock this thread now since its a zombie and you dug it up.
dorkidori_s13 is offline
pinout, s13, s13 chassis harness, smj
