Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 04-11-2011, 09:56 PM   #1
79jeep
79jeep's Avatar
79jeep is an unknown quantity at this point
Talking CNC ...Hydro-E brake on z33
so yeah when i started to get into drftng i saw all my buddies with s- chasis cars initiating using the E-brake but unfortunately my 350z doesnt use the actual brake they're small shoes ..so i researched and found a couple options . but money was always an issue but i heard of some company call CNC they're product are reasonably priced so after so long nights and like 2qts of brake fluid on my carpet this is what resulted ......after the install the hydro doesn't affect pedal feel , I was still able to keep my ABS unit , but i do have to deactivate it in order to use the Hydro properly with the ABS going crazy......
79jeep is offline   Reply With Quote
Old 04-15-2011, 01:50 PM   #2
AN300zx
AN300zx is an unknown quantity at this point
thats a pretty intense Ebrake haha its like rally style
AN300zx is offline   Reply With Quote
Old 04-26-2011, 08:44 AM   #3
tryangle
tryangle's Avatar
tryangle is an unknown quantity at this point
Was this a staging brake used as an hydrobrake now?
tryangle is offline   Reply With Quote
Old 05-03-2011, 01:03 PM   #4
JDMStanced
JDMStanced is an unknown quantity at this point
dope! i PMed you
JDMStanced is offline   Reply With Quote
Old 05-31-2011, 04:40 PM   #5
Corbic
Corbic's Avatar
When you deactivate your ABS, are you talking about just turning off the VDC button, or are you doing something else?
Old 06-01-2011, 02:40 PM   #6
JDMStanced
i got this set up done but i can't lock up the rear. right now, i have only one mounting point so i can't pull hard. I hope that's the reason why.
Old 06-01-2011, 02:50 PM   #7
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
some serious leverage on that thing!!!
Old 06-02-2011, 11:26 AM   #8
XeroX
XeroX's Avatar
XeroX is an unknown quantity at this point
Thats pretty dope. Pics with steering wheel mounted?
Curious to know how far this places it from the wheel....
XeroX is offline   Reply With Quote
Old 06-02-2011, 04:59 PM   #9
Sileighty_85
Sileighty_85's Avatar
Not bad, looks like your legs gonna rub on it?
I just installed one in my buddies
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-03-2011, 11:06 PM   #10
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
^^^ nice job, super clean install on the MAX SLC Hydrobrake !!
O.P. dont those metal straps flex like a mother fer?
Even when we weld our brake to the tranny tunnel we have to reinforce it quite a bit to keep the sheet metal from flexing.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 06-04-2011, 01:56 AM   #11
s13 @ fullboost
Mine still has issues :/
Old 06-04-2011, 02:03 AM   #12
JDMStanced
issues with what?
Old 06-04-2011, 02:27 AM   #13
s13 @ fullboost
Locking up the rear brakes that was more directed to Dan sorry
Old 06-04-2011, 02:39 AM   #14
JDMStanced
i have problem locking up the rear also with my CNC staging brake.
i can lock up only when weight is shifted to one side.
never locks up going straight no matter how slow i go. is it because of my stock z33 VLSD?
Old 06-04-2011, 02:56 AM   #15
s13 @ fullboost
Exactly I can't ether my diff is welded
Old 06-04-2011, 03:00 AM   #16
JDMStanced
maybe when you bleed the hydro ebrake, you are suppose to tilt the staging brake 90 degrees so that the feeder is facing upward?
Old 06-04-2011, 03:05 AM   #17
s13 @ fullboost
Not sure what you mean here is What mine looks like uploadfromtaptalk1307178330012.jpg
Old 06-06-2011, 01:00 AM   #18
JDMStanced
^^i like your shift knob
i bled the brakes more today. i could lock up going straight around 50 mph but after like 3 times, it didn't lock up.
i parked the car and my rear pads were freaking smoking the crap out lol smells bad for sure. is this normal?
Maybe it didn't lock because my pads faded after 3 lock ups... i have stoptech street performance.
Old 06-06-2011, 03:16 PM   #19
s13 @ fullboost
I have bleed mine countless times even got another master and booster and still can't lock em up going straight
Old 06-06-2011, 03:27 PM   #20
JDMStanced
try bleeding with the inlet and outlet facing up
Old 06-07-2011, 04:31 PM   #21
s13 @ fullboost
I dont think I understand what you mean !!!
Old 06-08-2011, 07:56 PM   #22
JDMStanced
Are all CNC staging brakes like this? free play in handle?
http://s785.photobucket.com/albums/y...t=IMG_1240.mp4
Old 06-09-2011, 01:51 AM   #23
s13 @ fullboost
yeah mine has a little bit also But not side to side
350z, e-brake, hydro
