Old 07-14-2022, 10:21 PM   #1
mav1178
mav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfection
Genuine OEM/OE replacement parts interest list
I am in the process of gathering interest for some genuine + OE replacement parts, are any of the following of interest to people? All are brand new production, all are Made in Japan.
Genuine Nissan parts:
  • 22620-35F00 - KA24E + CA18DE/DET TPS sensor ~$130
  • 40202-35F00/F6200 - S13 4 lug front hub (bearing sold separately) ~$250
  • 40202-39F01 - S13 front 4 lug assembly w/ ABS(bearing sold separately) ~$450
OE replacement water pump/fan clutch, manufactured by NPW (www.gonpw.com):
  • N-103F - OE replacement RWD SR fan clutch ~$80
  • N-31F - OE replacement RWD KA24E/DE fan clutch ~$60
  • N-106 - OE replacement RB25/26 water pump ~$60
  • N-79 - OE replacement S13 SR20DE/DET water pump ~$50
Nippon Piston Ring (NPR) - actual genuine Nissan OE piston ring manufacturer:
  • SWN30096-0 - KA24E/DE piston ring std bore (12033-70F00) ~$45
  • SWN30096-2 - KA24E/DE piston ring +0.5mm (12036-70F00) ~$45
  • SWN30096-4 - KA24E/DE piston ring set +1.0mm (12038-70F00) ~$45
Some other parts that are readily available in the US, I am also trying to source. Just trying to get a cheaper source for people to have access to, such as S13 TPS, S14/15 TPS, rear wheel bearings, S14 5 lug front hubs, etc.
All of these parts are 4-6+ months out at this point.
Feedback appreciated, thanks.
Complete list of in stock items here:
https://bit.ly/3O5TOU5
Distributor for Nismo, ORC, and discontinued genuine Nissan parts.
Authorized dealer for Oakley -- PM me for the best prices!
[email protected]
mav1178 is offline   Reply With Quote
Old 07-15-2022, 10:50 AM   #2
Agamemnon
Agamemnon's Avatar
I'm in for the RWD KA24DE fan clutch.
Old 07-19-2022, 01:08 PM   #3
AKADriver
AKADriver's Avatar
Does NPR still make the whole KA24DE piston also? I see a few sellers that list them but it's hard to verify if these are genuine NPR. PN 11-598-x.
Old 07-19-2022, 01:14 PM   #4
mav1178
yes but there's also almost no point if the Nissan genuine units are available (STD grade 2 only):
https://www.nissanpartsdeal.com/part...010-53f01.html
but yes, the part number is accurate.
https://www.npramerica.com/attacheme...orPRINTOUT.pdf
page 212
Edit: I should add that very few people buy OE replacement piston rings or pistons unless it was a stock rebuild. I can probably source the parts, but given the responses so far in this thread it will probably be a money losing proposition for me.
[email protected]
Old 07-19-2022, 01:45 PM   #5
AKADriver
AKADriver's Avatar
Obviously yes. And I'd agree the NPR pistons/rings are probably not worth your while since they're not that hard to find and silly cheap. (I may grab this eBay auction just to have it on hand.)
Old 07-19-2022, 02:49 PM   #6
mav1178
the real issue is I can get it for cheaper, and I can make enough money off each sale to make it worth the trouble, but the piston rings (for example) are sold in boxes of 10 sets.
so I'd have to find 10 buyers of stock replacement piston rings, maybe 6 or 7 buyers just to break even.
everyone else that sells single qty get it from IMC or Worldpac without the box requirement.
[email protected]
Old 07-19-2022, 03:53 PM   #7
mothon
mothon's Avatar
mothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond repute
I would probably be interested in both fan clutches.
instagram: madness_garages14
mothon is offline   Reply With Quote
Old 07-23-2022, 03:56 PM   #8
cgtdream
cgtdream's Avatar
cgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond repute
This happened once, a few years ago, but any way you could get together an S14 fuel tank?
Juicy slayin aint easy, but dammit somebody has to do it!!!
cgtdream is offline   Reply With Quote
Old 07-23-2022, 06:31 PM   #9
mav1178
this post and this entire original thread from 2020 is context:
https://zilvia.net/f/showpost.php?p=...1&postcount=82
[email protected]
Old 07-25-2022, 01:24 PM   #10
Shift_grip
Shift_grip's Avatar
Shift_grip is an unknown quantity at this point
S14 zenki non-abs 5spd brake booster would be great to have new. Can't find one for the life of me.
Nissan Part #: 47210-70F96
I ♡ shitpiles
Shift_grip is offline   Reply With Quote
Old 07-25-2022, 04:01 PM   #11
mav1178
mostly limiting this to the parts I put up in the first post. Parts availability tend to go with the vendor that makes that specific part.
[email protected]
Old 07-26-2022, 11:42 AM   #12
KApasa
KApasa is an unknown quantity at this point
I’d be interested in the TPS.
KApasa is offline   Reply With Quote
