05-16-2011, 08:42 PM | #121 |
mine had a popping noise also. reason being. the collars that held up the spring it self were not tightened all the way and were loose. since that happened im assuming it screwed with the factory spring preload?
05-16-2011, 10:20 PM | #123 |
i believe i noted this about a page or two ago. Usually the popping is from
1. Loose top perches 2. The spring binding because of the rubber bushings they use. these bushings sit above and below the spring. They offer the nylon ones for about 25$ shipped for both sides. Im receiving my bushings tomorrow and if it doesnt rain Wednesday, taking apart the coilovers to put em in, and while im there, remove a collar or two |
05-16-2011, 11:45 PM | #124 | |
05-17-2011, 03:29 PM | #125 |
06-06-2011, 12:33 AM | #126 |
lol I just did the preload again and it's still messed up.
What else? Top perch/collar being right under the camber plates? If all else fails, I'll just have to go for those nylon bushings. Still think that's kind of messed up that they make you buy it to get rid of noise lol. Coils are still great quality stuff though. |
06-06-2011, 12:37 AM | #127 |
Mine make a popping noise when im at full lock sometimes, its never givin me a problem.
Im sure its just the spring binding. No biggie, ive gotton it with any coilovers ive had. Even my Konis. Regardless, i dont see myself getting any other coils, ever, in this price range. These are awesome for my daily S14 10;8 spring rate, and valved for 'street' use. Im low already, and still have plenty more to go down. |
06-06-2011, 12:44 AM | #129 | |
any less and my springs would be loose hahaha. |
06-06-2011, 12:49 AM | #131 |
LOL! Might as well put some white lithium instead. Haha. I'll try that this week. If it stops raining in June... in California.... which is retarded as shit. Just started sanding my car for paint too :'(
06-06-2011, 02:31 AM | #135 |
Trader Rating: (38)
Feedback Score: 38 reviews
i understand its old. but that doesn't change the fact it would serve its purpose better int he review thread. seeing as thats where ur sposed to go if ur looking for a review.
2016 Nissan 370z |
06-06-2011, 04:36 AM | #136 |
Interesting.. how low are you? I have the 10/8 rates and my car, with 1.7* camber STILL had a 1.5 finger gap with the coils MAXXED in the front. Even popping a collar off i can just barely fit my hand around the tire, so still almost 1 finger gap. Getting some 7" ERS springs in the future and dropping it another 1/2"-3/4" in front and it will be perfect. The 10kg springs are 8" length fyi.
06-06-2011, 09:28 AM | #137 | |
Instagram - SJKnoop |
06-17-2011, 10:47 AM | #139 | |
I flipped the spindles in the front. It reduces a lot of camber, ad allows for a lot more low. I plan on upgrading to the swifts eventually. |
06-17-2011, 10:48 AM | #140 | |
When i was desperate to get my car lower i put the rears on straight out of the box. take the time to adjust, and your ride will be golden. |
06-17-2011, 11:10 AM | #141 |
Got my new FA in last night, but they didn't send me the correct springs, so now I have to wait haha.
I'll be posting my own review in here of them shortly! Super pumped to get these babies on my car. |
06-17-2011, 02:08 PM | #143 |
Too much preload or too stiff of dampening is a possibility. What kind of bumps are we talking here? If you have large dips or bumps you will definitely feel it. I can't drive on the interstate around here because the bumps and dips are so big things would get ripped off my car.
06-17-2011, 02:58 PM | #144 |
I have the fronts preloaded and stiffened to 15 clicks and the rears are at 10 clicks. The fronts feel perfect . The rear i ddnt really know How to preload really. If u want it low in the rear won't the spring be sitting freely since the lower u go in the back the harder it is to preload the spring?
06-17-2011, 03:33 PM | #145 | |
06-17-2011, 06:03 PM | #146 | |
Trader Rating: (38)
I may just copy your front settings. I added some preload after I contacted Terry about the loud pop noise I was hearing while parking my car. As for the rears (from full hard soften it up about 6 clicks) so if 40 is full hard, it's at about 34 and I really enjoy my rears. But my fronts are definitely bouncy so I may try a softer setting. |
06-17-2011, 07:48 PM | #149 | |
I learned this from my experience of preloading coils. I had clunking and popping sounds so I asked PBM what's the deal and they told me DO NOT preload but to move the spring flush to the top plate, spin the locking collars snug to the bottom of the spring and tighten them there. The spring should not spin freely but you should be able to move/spin the spring if you tried turning it with your hand. All clunking and popping noises disappeared after I did this and ride got considerably better. |
06-17-2011, 09:34 PM | #150 |
Trader Rating: (38)
Not to take away from what you already know about coilovers and what you've experienced but by adding a couple of spins (adding preload) it completely got rid of the popping sounds to my coilovers. I was actually trying to dig up the email that I got from Chris at Fortune Auto to show you that one of their reps recommended adding maybe 2-5mm of preload.
EDIT: found the email, my initial message is the bottom part and Chris' response was the top I firmly believe that adding a little preload to my FA coilovers solved my popping problem. I have not heard a sound since I fixed it back in April. |
fortune auto, s14 |
