08-05-2013, 10:35 AM | #1 |
Time to upgrade maf?
Hello zilvia,
I am running a ka-t with a garrett 60-1, 370, mid mount etc. I have a tune sitting around I'm gonna send back to get reflashed for this setup. My question is would it be worth it to get an n60/n62 maf, or should I just keep the stock one? I'm not looking for huge numbers, this is my daily so I'd rather have a safer setup than anything. Thanks |
08-05-2013, 11:30 AM | #3 |
Yeah but it costs MONEY.
@OP > get a friend in your car and some voltage logging tool, some multimeters can do it, some scopes too but they are expensive. log the MAF signal wire, it comes to the ECU, near your passenger legs. Bury the right pedal in the ground on 3rd all the way up. Does it reach 5V ? If the answer is no, then you dont need to change your MAF. It is not linear, so if you have 4.2V you still have a lot of room. The max is usually reached between 3500 and 5000 rpm. BTW i'd advice to just get a nistune (this logs MAF voltage and a bunch of other things too) or any other EMS (NO crap piggyback like SAFC ) and have someone tune your car. Off the shelf tune is ok for mild tuning, but i'd never get one with mods like you have. Plus you will get more HP and reliability... |
08-05-2013, 11:43 AM | #4 |
I'd love to get a nistune but it always comes back funds. The enthalpy tune should be good enough for my needs now. Thanks a lot for the info, I'll try it tonight
08-05-2013, 02:03 PM | #5 |
Never upgrade a maf unless absolutely necessary. Larger maf sensors have lower resolution. The smaller it is the better it will handle (report) small incremental changes.
That said, you do not have enough injector to upgrade your maf. it will not make a difference to report increased airflow to a computer if the computer cannot adjust the fuel supply to meet the demand for the additional airflow. last... you wont always see exactly 5V from a maxed maf. I have seen a maf stop at 4.5V and at 5.2V. |
08-10-2013, 08:40 AM | #7 |
Stay stock unless you do a full system upgrade. Think about it, Nissan did all that R and D for this specific motor so stock is the best you can have unless you go balls out and upgrade everything
08-10-2013, 11:15 AM | #8 | |
Man w/ CTSV & a Car Seat
a 60 trim T3 would push this to 250hp at 8-9 psi. He'd close to max of both 370cc injectors and stock MAF. |
