Old 04-19-2019, 05:21 PM   #1
Dthomas88
Dthomas88 is an unknown quantity at this point
S13/180sx & RB Parts
Updated July 22 2019 Sold stuff
I’ve got a lot of S13/180sx parts along with RB25 stuff. Prices are OBO.Not interested in shipping the big stuff but ask and I’ll let you know. Will ship the smaller things prices do not include shipping. Purchaser pays for shipping and PayPal fees. Any questions text me at 682-558-3937 I live between Austin and San Antonio in New Braunfels if you want to come by.
1) S13 Cluster Surround w/ switches and coin holder - $30
2) S13 Hazards Switch w/ pigtail - $5
3) S13 Windshield and hatch sprayer switch w/ pigtail -$5
4) S13 Defroster switch w/ pigtail - $5
5) S13 Cruise control / Brake light Pedal switch w/ pigtail - $10
6) S13 Cigarette lighter w/ socket - $10
7) S13 Wiper / Turn signal / headlight switches selling both (faded but work) - $10 together
8) S13 Ignition with Key - $30
9) SOLD
10) S13 glove box light assembly w/ switch - $8
11) SOLD
12) Brake reservoir with sensor - $10
13) S13 Hood prop -$10
14) S13 Hatch no name rear strut brace -$30
15) S13 USDM power mirrors (ones missing glass can use yours) both tested and working no switch - $40
16) S13 door handles - $10
17) SOLD
18) SOLD
19) S13 Pillar gauge pods - $10
20) SOLD
21) SOLD
22) S13 trunk weather stripping (good condition) - $50
23) S13 Underhood weather stripping(missing one clip) - $10
24) SOLD
25) SOLD
26) SOLD
27) S13 OEM BNIB trunk latch assembly - $35
28) SOLD
29) KA24DE Oem ECU - $45
30) SOLD
31) SOLD
32) SOLD
33) SOLD
34) RB25 OEM throttle body (No tps) - $15
35) Rb25 OEM Oil warmer/cooler - $10
36) SOLD
37) SOLD
38) SOLD
39) RB25 IACV Block off plate - $5
40) SOLD
41) SOLD
42) SOLD
43) SOLD
44) SOLD
45) SOLD
46) SOLD
47) Wiring Specialties RB25 S13 lower harness only installed it never used it cut batter cable for distribution block - $80
48) S13 Fuel Filter Bracket - $10
49) RB25 S2 OEM Cams - $100
50) SOLD
51) S13 Manual Doors mostly complete w/ glass and door panels. One is missing the mirror and handles. - $200 for both
52) KA24 water neck gasket - $5
53) S13 Foot rest/ dead pedal - $5
54) S13 Cluster Surround Vent w/ duct - $10
55) S13 Marker Light (no broken clips) - $5
56) S13 Under radio cubbyhole X2 - $10 each
57) Z32 Manual Speed Sensor (Got it for my RB25 but ended up using a dikota digital instead) - $60
58) Ark Design License Plate Trim - $5 for both
59) SOLD
60) SOLD
61) S13 Speedometer mounting bracket (mounts behind cluster under dash got an extra since I hacked up my old one to put the NX cluster in) - $5
62) SOLD
63) SOLD
64) S13 Energy Suspension Rear Sway Bar - $10
65) SOLD
66) S13 Energy Suspension Front Sway Bar 25mm - $10
67) S13 Energy Suspension Rear Control Arm / Suspension - $45
68) S13 Energy Suspension Front Strut Rod - $30
69) SOLD
70) Ark Design Boost Controller Blue (comes with everything you need solenoid harness and controller, used it for about a year works great I just consolidated my wide band and boost controller into one) - $120
71) S13 brake line retainer clips brand new from nissan x4 - $10
72) CNC 2.5in X 3in vband adapter - $20
73) SOLD
74) 3in 2 hole high heat exhaust gaskets x4 - $15
75) Thermostatic electric fan controller (push in probe type adjustable from 115F to 225F) - $20
76) 2.5in Stainless steel Vband clamp and weld on male/female fittings brand new - $25
77) Mild steel 2.5in x 3in cone reducer x2 - $20
78) S13 Replacement rear tail light push in bulb sockets x2 - $10
79) S13 radio adapter harness -$10
Clusters
A. Turned the miles back to zero and used it on my RB25 swapped vert for 13 miles until I got an NX cluster. Tach is adjusted for a RB25. Comes with harness small crack shown in picture- $50
B. SOLD
C. Cluster that came from a hatch with ABS top screws mount is broke shown in picture no harness -$25
180sx DCC
A. Just the DCC no harness ( has clear coat pealing but works) - $35
B. As far as I can tell complete DCC w/ Uncut harness. All sensors and actuators are present and worked when pulled from the car - $350
C. Partial DCC w/ cut harness, blend door motors, fan motor resister, and usdm pigtails to splice together - $120
Dthomas88 is offline   Reply With Quote
Old 04-20-2019, 07:34 AM   #2
burnsauto
burnsauto's Avatar
are the s13 trunk struts oem? if so I'll take them
Old 04-20-2019, 08:13 AM   #3
Dthomas88
They are not OEM Nissan, but I had gotten two sets by accident and used one on my Vert and they work and fit like Oem. But since they are not Oem I priced them accordingly.
Old 04-20-2019, 02:19 PM   #4
Hong41
Hong41 is an unknown quantity at this point
Part with the newer mirror control?
Hong41 is offline   Reply With Quote
Old 04-20-2019, 02:39 PM   #5
Dthomas88
You referring to one of the power folding mirror switches?
Old 04-20-2019, 02:51 PM   #6
Hong41
Yes that is sorry
Old 04-20-2019, 07:30 PM   #7
Dthomas88
Will bundle and give discounts if multiple things are purchased
Old 04-21-2019, 02:52 AM   #8
VenomKillz
VenomKillz's Avatar
VenomKillz is an unknown quantity at this point
How many clips is the shifter trim missing?
VenomKillz is offline   Reply With Quote
Old 04-21-2019, 07:53 AM   #9
Dthomas88
2 out of the 6
Old 04-22-2019, 03:30 PM   #10
Dthomas88
Bump Added a bunch of stuff from boost controller to wideband to exhaust and turbo stuff
Old 04-22-2019, 08:20 PM   #11
nzmoman
nzmoman's Avatar
nzmoman is an unknown quantity at this point
Do you have the inner door trim? (assuming its a couple or hatch). It runs from the bottom up the front of the A-pillar over the window and down the bottom of the B-Pillar? If so, please PM a price for that and the front sway bar bushings (#66)to 30024
nzmoman is offline   Reply With Quote
Old 04-22-2019, 09:50 PM   #12
Dthomas88
PM sent sir
Old 04-23-2019, 08:01 PM   #13
Dthomas88
Bump Prices are OBO more stuff added
Old 04-24-2019, 07:14 AM   #14
jsu1012
jsu1012's Avatar
jsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to behold
Sent you a PM.
@streetstyle_jay
jsu1012 is offline   Reply With Quote
Old 04-26-2019, 07:29 AM   #15
Dthomas88
Bump Prices Drop Anything Purchased today before the post office closes ships today.
Old 04-28-2019, 04:01 AM   #16
Guppy
Guppy is an unknown quantity at this point
Do you still have the middle s13 cluster and harness? I need one that will work with my sr swap.
Guppy is offline   Reply With Quote
Old 04-28-2019, 08:13 AM   #17
Dthomas88
Yes I do shoot me a text 6825583937
Old 04-30-2019, 06:06 PM   #18
Dthomas88
Bump bump bump Added some stuff sold some stuff. Prices are obo
Old 05-02-2019, 02:36 PM   #19
Dthomas88
Let’s clean out my garage guys.
Old 05-03-2019, 07:56 AM   #20
nzmoman
nzmoman's Avatar
Originally Posted by Dthomas88 View Post
PM sent sir
I don’t have a PM
Text 678360686six
Old 05-04-2019, 08:46 AM   #21
Dthomas88
Bump Price Drop
Old 05-05-2019, 09:57 AM   #22
duballstar37
duballstar37's Avatar
duballstar37 is on the path to ruinduballstar37 is on the path to ruinduballstar37 is on the path to ruin
11) S13 JDM power Folding mirrors ( removed the bases to use the USDM ones) have two different switches w/ pigtails both mirrors have been tested - SOLD
Thanks again for working with me while I sorted out the payment details. Payment sent and awaiting shipping information.
Thanks again!! Free Bump!!
P.A.T.T.
duballstar37 is offline   Reply With Quote
Old 05-05-2019, 11:41 AM   #23
Dthomas88
No prb. It’s packed and will be shipped on Monday
Old 05-10-2019, 07:42 AM   #24
Dthomas88
Bump it up. Price adjustments
Old 05-16-2019, 07:17 AM   #25
Dthomas88
Bump sold some stuff. Let me know prices are obo
Old 05-18-2019, 10:45 AM   #26
noobguy123
noobguy123 is an unknown quantity at this point
Pictures of the OEM S13 fenders.
noobguy123 is offline   Reply With Quote
Old 05-19-2019, 11:37 PM   #27
timohtee
timohtee is an unknown quantity at this point
Do you have the headlight retractor switch? Also, is the defrost switch #4 and headlight switch #7 still available?
timohtee is offline   Reply With Quote
Old 05-20-2019, 04:48 AM   #28
Dthomas88
Pm Sent
Pm sent
Old 05-29-2019, 03:48 PM   #29
Dthomas88
Bump still have things
Old 07-22-2019, 10:35 PM   #30
Dthomas88
Bump still have some stuff
