Old 01-17-2021, 06:37 PM   #1
butwduptho
butwduptho's Avatar
butwduptho will become famous soon enoughbutwduptho will become famous soon enoughbutwduptho will become famous soon enoughbutwduptho will become famous soon enough
Brand New Blitz Boost Controller
$400 obo
The Blitz SBC Type R (Sequential Boost Controller Type R) is the newest boost controller offer by BLITZ. This unique boost controller is the cutting edge in boost controller technology. The SBC Type R features the same dual solenoid design as the SBC i-D Spec R for maximum boost response and the capability to hold up to 43.5psi (3.00hkPa). (TypeR twin solenoid valve, TypeS is a single solenoid valve)
FEATURES
Adopt a new body and a flat display and compact. Thickness (the thinnest part) 12mm only. Can be mounted on flexible three-piece construction of the valve controller unit
Has thinner body of only 12mm can bemounted on the valve controller unit
Adopted the new TN liquid crystal display 7-segment display and bar graph high visibility.
The newly developed compact, high-performance solenoid valves adopted to correspond also to high flow rates.
Achieve stability and rise of boost pressure and response
One control channel can be set for "Lo" 2 and "Hi" in the manual control. Equipped with a completely new control algorithm. Suppress the sauce of boost pressure and boost pressure stability.
DUTY value control, value GAIN, P-GAIN value can be set for each channel Standard with boost display, peak hold, warning, limiter, a scramble boost function.
By connecting the optional radio was adopted a "Wireless Remote Switch", and channel switching operation can be scrambled at hand.
Check out this item on OfferUp. https://offerup.co/TyvAFWKUXfb
butwduptho is offline   Reply With Quote
Old 05-03-2021, 01:30 PM   #2
butwduptho
butwduptho's Avatar
Bump still available
