10-19-2020, 05:23 PM | #1 |
Aluminum Welding Rod Tests - Wayy better than anticipated
Beading or putting together IC hot pipes and cold pipes. This seems to be fine!
Also I would probably use this for welding bungs to those IC pipes.... Better than JB Welding them! What you guys think?
Turn and Burn! |
10-20-2020, 02:02 AM | #4 |
Tig welding aluminum was always easier for me than steel. I made countless sets of intercooler plumbing over the years and wouldn't do it any other way. It doesn't take long if you have the right tools, bandsaw, carbide bit,... I've even seen a special tool for removing burrs quickly without the use of an air compressor tool. I'm no machinist yet plumbing was always very easy and quickly done, not sure how you can improve that, looking for a way to improve something that doesn't need to be improved.
10-20-2020, 04:10 AM | #5 | |
Figured between vibration and 25-30psi over the whole area wouldnt hold up.... always tig welded my pipes. Just didnt seem like the best way. Guess somone should try it. (Ive seen iat bungs brazed and hold up) |
10-20-2020, 09:52 AM | #6 |
This guy tested these rods on pipe and looks like it would work well for intercooler pipes. This is a much cheaper alternative to welding.
https://www.youtube.com/watch?v=JYzMHdedIeM |
10-20-2020, 11:46 AM | #8 |
Trader Rating: (26)
Feedback Score: 26 reviews
If you're justifying this instead of doing it the right way, god bless. That looks like dog shit, isn't going to hold as well as you think and has zero penetration.
10-20-2020, 07:35 PM | #11 |
For me its an alternative to weld on an bund to some aluminum..... It would be stupid to buy a TIG welder to do bungs once maybe 5 years..... I have a crappy mig for car panels or something, but TIG is another level.
But agreed on full piping probably not, but track fix would be awesome!
Turn and Burn! |
10-21-2020, 08:54 AM | #12 |
The problem with that stuff as a trackside fix is once you get the permanent repair done, you'll be battling weld contamination like crazy. Stick to quick epoxy for trackside repairs which can be removed easier later.
I've actually used that stuff a couple times on a motorcycle to fill in where a chain went awry... It's not easy to work with. It's basically like working with solder and not like welding. |
10-21-2020, 08:59 AM | #13 |
The thing is once you have a TIG you will find a million uses for it and you can build your own cool shit. A good hobbyist AC/DC TIG setup can be had for under $1200 (including a 150 bottle of gas, nice foot pedal, torch, consumables etc.). The machine will pay for itself pretty quickly.
10-21-2020, 08:40 PM | #15 | |
Gotta go outskirts.... Then you think 5 mins to weld a bung and a 40 minute drive 1 way to get it done..... gotta have a few short cuts
Turn and Burn! |
10-22-2020, 05:56 AM | #16 |
If there's anything I've learned about cars it's that it's always better to do it yourself not rely on someone else... Even a friend. Put yourself in that friend's shoes too and you end up welding dirty little jobs as favors for everybody.
10-22-2020, 12:31 PM | #17 |
Yup i agree. All my friends have jobs and families. And to do anything in SF bay area with fab, you either gotta be like matt field drift cave building 100k drift machines or not surviving.
I think its really becoming fact of life being older and owning a serious big boy toy. But ima try this welding rode. Hope you guys sat through the video, its always done well.
Turn and Burn! |
10-23-2020, 03:36 PM | #18 | |
If I were in your position, I'd be looking at a $100 flux core mig and mild steel pipe. |
10-24-2020, 09:31 PM | #19 |
Yea i have a mig and gas. But not pipe bending. So i just use my blitz pipes and put iat bung. I tapped and jbwelded thr bung before on my car and was fine on track duty. Figured this would be better than JB
Turn and Burn! |
10-26-2020, 03:33 AM | #21 | |||
