Old 11-30-2019, 03:41 PM   #1
OG-sk33zy
OG-sk33zy is an unknown quantity at this point
CA S14 won’t crank / loses all power
My manual s14 won’t start or crank. After it sits and power comes back on to the accessories, I try starting it and after no cranks it just completely dies. I haven’t replaced the battery in about 3 years and the car sits for months at a time without being started. I have replaced the starter a few months ago. Any idea in which direction I should go? Should I start by replacing the battery? Then narrowing it down from there. I repeatedly charge the battery but haven’t gotten it tested yet.
OG-sk33zy is offline   Reply With Quote
Old 11-30-2019, 03:42 PM   #2
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
Replace the battery....
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 11-30-2019, 04:24 PM   #3
Kingtal0n
Kingtal0n's Avatar
Kingtal0n has much to be proud ofKingtal0n has much to be proud ofKingtal0n has much to be proud ofKingtal0n has much to be proud ofKingtal0n has much to be proud ofKingtal0n has much to be proud ofKingtal0n has much to be proud ofKingtal0n has much to be proud ofKingtal0n has much to be proud ofKingtal0n has much to be proud ofKingtal0n has much to be proud of
Fully charged healthy battery is 12.65volts
use a $5 harbor freight multi meter to test that
Kingtal0n is online now   Reply With Quote
Old 11-30-2019, 06:49 PM   #4
OG-sk33zy
I will just buy a battery so I can eliminate it as possible cause. I will keep the thread updated.
Old 11-30-2019, 08:15 PM   #5
OG-sk33zy
Just put a battery, nothing happens , I turn key to start it and everything dies. Everything shuts off for like 10-15 minutes and then the time on the cluster comes on but nothing else powers up. I NEED HELP PLEASE
Old 11-30-2019, 09:06 PM   #6
Jamaica
Jamaica's Avatar
Jamaica is an unknown quantity at this point
Basic stuff first. Clean terminals, check fuses, check and clean grounds. Could of asked in the small questions thread.
Jamaica is offline   Reply With Quote
Old 12-07-2019, 04:37 PM   #7
kyral
kyral's Avatar
kyral has made poor choiceskyral has made poor choiceskyral has made poor choiceskyral has made poor choiceskyral has made poor choiceskyral has made poor choices
was this a brand new battery?
kind of sounds like a short to ground on the starter circuit
I was right, they were wrong, and they are salty about it =)
kyral is offline   Reply With Quote
Old 12-07-2019, 05:47 PM   #8
S14rebuild
S14rebuild is a jewel in the roughS14rebuild is a jewel in the roughS14rebuild is a jewel in the roughS14rebuild is a jewel in the roughS14rebuild is a jewel in the roughS14rebuild is a jewel in the roughS14rebuild is a jewel in the rough
Ignition switch?
