Old 05-19-2019, 12:17 PM   #1
Socalkev
Socalkev is an unknown quantity at this point
KA No spark to plugs cables
No spark to spark plugs and cables recently sawped my ka dual cam from my 93 vert to a 89 coupe spliced the engine harness f1 plug was damaged couldn't decide pin it , spliced lower harrnes to fuse box , the battery cables read continuity I traced it to the 75amp alt relay/fuse idk what it is, if I pulled it out stops so then I traced it back inside to a blue plug above the fuse box on the driver side there's to plugs here a black and blue that connect to a box like connector, fuel pump is priming I'm getting power to coil dizzy getting power injectors as well , some one help pls ?!
Socalkev is offline   Reply With Quote
Old 05-20-2019, 07:38 AM   #2
jedi03
bad distributor maybe? how to contacts inside look?
Old 05-20-2019, 07:08 PM   #3
Socalkev
Distributor seems to be good pulled It out rotated it you can hear injectors clicking , gana clean up the contacts on the cap rn, I noticed the ignitor chip getting really hot tho is I possible could be the coil was thinking of buying a msd blaster coil ?
Old 05-25-2019, 03:32 PM   #4
Jfornachon
Jfornachon is an unknown quantity at this point
The coil would be a good place to start if it is getting hot like you say. Not a bad time to upgrade while you are at it.
Have a great day,
jared
Jfornachon is offline   Reply With Quote
