04-17-2019, 06:02 AM | #1 |
Hey everyone for some reason my car keeps coming out of alignment to the point where I can notice it by just looking at the vehicle.
As for rack play, I just got it back not to long ago from getting rebuilt from a place that ive been dealing with for a while. I have the: GKtech front super lock kit on my s14 Brand new inner and outer tie rods from GK tech and the lower control arms are from GK tech New rubber bushings on the rack. Has anyone run across this issue? If so, how did you go about fixing this any help is appreciated. |
04-17-2019, 08:04 AM | #2 | |
Have you checked your rack for play? Or the tie rods, Steering bushing, etc.
04-17-2019, 03:59 PM | #3 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
What parts do you have? How old are they?
When was the last time you replaced the bushings in the stock arms you have?
04-18-2019, 02:04 PM | #4 |
What is out of alignment?
Toe? Camber? Caster? What is the condition of the parts? Are the adjustment points torqued or loose? Is your car a rusted smashed up shit box? |
04-22-2019, 06:04 AM | #6 |
Hey guys sorry was having some technical issues with pretty much all my technology last week. As far as what comes out of alignment I always notice the Toe the most but my camber seems to come out as well. The parts are about a year old but have been in my car in the garage and havent even seen the track yet just some regualr driving here and there last season. As for everything being torqued I have torqued everything down and im sure the guy aligning the car does as well since everyone in my area goes to him for alignments sinces hes the best around. The car isnt a beat up 240 thats rotted out or anything its in good condition. For the rach shifting Im not sure I will look at it soon been kinda busy but it has all new bushings and everything that I installed and are tight. thats why im kind of at a loss for this no idea how they could come out of alignment so easily.
04-23-2019, 04:13 PM | #7 |
Trader Rating: (130)
Feedback Score: 130 reviews
you need hard data about what "coming out of alignment" means.
eyeballing is NOT a good method. provide before and after measurements, then check whatever controls those measurements. you need to know what the toe setting is when the car is aligned, then you can say "yes its definitely 1/4" different NOW, compared to when we aligned it", then you can check tie rods, rack, etc. you need to know what the camber and caster settings were when the car is aligned, then you can say "we set it at 3* but now its at 5*" then you can check the top hats and tension rods and subframe and all the rest. just saying "oh I think it LOOKS like its out of alignment" doesn't really mean much to me, unless you're a cyborg, in which case, why are you fucking with 240s instead of doing cool cyborg shit??? |
04-23-2019, 04:50 PM | #8 |
While I totally agree with you but heres the thing when both wheels were pointing straight after alignment and now the front wheels look like their pigeon toed im sure they are out of alignment.
04-23-2019, 05:03 PM | #9 | |
Go to. Bell Tire or Firestone, pay for a 180 warranty or whatever and get it squared away. CHECK ALL THE TORQUE VALUES with a torque wrench. Drive the car, recheck the torque values. See if things are loosening up. Check your hubs. If you have bearings that shot, that's going to make it impossible to get a proper alignment as the whole will is shifting about on the loose bearing. |
04-23-2019, 07:41 PM | #11 |
04-29-2019, 11:21 PM | #12 |
What about the camber adjustment bolts at the strut/knuckle. If those are used for the adjustment and they have been over torqued they can stretch. They can also rotate if you hit a bump and are worn out. Have it aligned and mark every nut and bolt with a paint pen while on the rack. If you have an issue and am adjustment bolt or cam has shifted then you found your issue.
04-30-2019, 12:14 AM | #13 |
The last 240 I got, somebody had replaced some of the bolts in the suspension with the wrong size bolts. It had some S13 camber cam bolts in an S14 strut for example. The strut would slap back and forth whenever you turned.
Just fyi people can do things like that |
04-30-2019, 08:16 AM | #14 | |
that's awesome |
