04-10-2019, 08:42 PM | #1 |
Steering wheel shake
When i start driving my wheel starts to shake really bad and idk why. ive also gotten a alignment. it only happens when i go 20kph-40. Any ideas?
04-11-2019, 03:11 AM | #2 |
balance your wheels? check all bushings on control arms? tie rods nice and snug? etc.... literally Google up reasons for shaking steering wheel and go down the list till you get to the cause.
04-29-2019, 09:02 AM | #6 |
I used to get a weird vibration at certain speeds too
it's mostly likely worn out bushings or suspension components, just gotta inspect everything and try and pin point it |
04-29-2019, 06:43 PM | #8 |
Had the same issue - a VIOLENT shaking of the steering wheel after certain speeds. Changed all bushings, alignment, adjusted coils - the works... pulled off the alignment rack.. same thing! Turns out my dumb ass just had low tire pressures! Filled them up to proper PSI and poof! Problem gone
Sent from my iPhone using Tapatalk Pro
