Old 09-28-2020, 02:01 PM   #1
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
Sr20det not holding boost!
Hey guys. I've been having this issue for a while now and decided to post up. I have a s13 sr20det in my Datsun that I've been getting dyno tuned for a while. The issue is the the engine isn't holding boost. It will boost up set pressure but would taper off. My tuner and I have boost leak tested this engine and have seen leaks before which we all fixed but now there are none. The engine has a gtx2860 gen 2 internal wastegate with hks actuator, greddy manifold and Tomei poncams. We tested on wastegate pressure only and it would spike to 14 before dropping down to 10 which should be the spring pressure. Very strange for the initial spike in pressure to 14 before dropping off. What areas are common for the boost to drop off to?
lexus baby
5t341tH is offline   Reply With Quote
Old 09-29-2020, 04:13 AM   #2
S14rebuild
Ditch the internal wastegate and go with a larger EXTERNAL wastegate and a good dual port boost controller
Old 10-03-2020, 10:40 AM   #3
5t341tH
5t341tH's Avatar
I am trying to stick with internal wastegate. Also I have a innovate motorsports boost controller
lexus baby
Old 10-03-2020, 10:52 AM   #4
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Sounds like the actuator isn't opening fast enough on low boost, and getting blown open on high boost. Maybe something to do with the positioning of the actuator with respect to its action?
zombiewolf513 is offline   Reply With Quote
Old 10-05-2020, 03:42 PM   #5
5t341tH
5t341tH's Avatar
thats a possibility. The way the actuator mounts is a custom setup that I came up with. In my datsun it has very little room on the turbo side, so I had to mount it on the compressor housing. I will double check it actuates smoothly. But that wouldn't cause it to not hold boost right?
lexus baby
Old 10-05-2020, 05:57 PM   #6
S14rebuild
If the wastegate is stuck holdn the flap open...no boost will build
Old 10-05-2020, 09:40 PM   #7
zombiewolf513
You might have it adjusted such that the wastegates open position is at the maximum range of the actuator. Making the actuator too weak to reel the wastegate back in when youre at high boost exhaust gas pressures. Just a guess tho. Maybe theres a pinhole or rip in the diaphragm or canister, causing a leak in the actuators pressure differential.
You might want to consider welding the internal wastegate shut and buying a codyace modded exhaust manifold for an external wastegate for your tight fitment issues.
https://forums.nicoclub.com/93-saphi...r-t552332.html
Old 10-06-2020, 09:35 PM   #8
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
HKS actuators can hold around 18psi steady boost before they start dropping off... depending on your turbo choice also..
I had a 2871r on a similar set up like yours before and it held boost at 19psi no issues with spike or drop.
I also had an HKS EBC
Dboyizmlg is offline   Reply With Quote
Old 10-08-2020, 01:03 PM   #9
5t341tH
5t341tH's Avatar
I am trying to keep this internally wastegated. I bought this turbo new with the t25 flange and 5 bolt so I could keep internal wastegate. The hks actuator is also new. I modified the arm on the actuator so it can clear my steering column in the datsun. The arm has been shortened and bent at an angle.
lexus baby
Old 10-08-2020, 01:06 PM   #10
S14rebuild
Pull the turbo outlet off and actuate the wastegate and see if the flapper is fully closing and can swing freely... visually look and confirm
Then test the wastegate with compressed air/regulator...
Old 10-08-2020, 01:09 PM   #11
PoorMans180SX
PoorMans180SX's Avatar
Put more preload on the gate. Use more duty cycle in the boost controller on the top end. Test the gate crack pressure with a pump.
I don't know what HKS gates are supposed to open at, but I highly doubt it's 10psi.
