04-29-2019, 10:00 PM | #1 |
Trader Rating: (106)
Feedback Score: 106 reviews
GARAGE CLEANOUT! S13 Coilover, manual rack, climate control, RB25 turbo, misc...
-RB25 TURBO- $125
Supposedly rebuilt with billet wheel, unable to verify, has shaft play. -ALUMINUM DUAL ELECTRIC FAN SHROUD- $50 Pretty sure it’s S14, doesn’t quite fit S13, VERY beefy part, unknown brand. -S13 CLIMATE CONTROL ELECTRONICS- SOLD! -E-BRAKE KNOB- SOLD! -SEALED CATCH CAN- $40 Custom baffled and stuffed with stainless steel wool. 3/8” in/out and sealed, ideal for PCV system. -S13 ALUMINUM COOLANT TANK- $10 Mounting is weird because the hose is in a dumb spot, have to drill a hole in the tower. Used to slosh our coolant on track, made a baffle to fix that. -MOMO HORN BUTTON- $25 Pretty clean, only very minor scratches from normal use. -MAGNAFLOW 3” HIGH FLOW CAT- SOLD! -S13 MANUAL STEERING RACK- $100 Actual REAL manual conversion, not just plugged lines. Much better than plugged/looped lines!!! -S13 KONI COILOVER SETUP- $250 Custom built setup, old JIC front housings modded to fit S13 Koni yellow strut inserts, rear S13 Koni yellows with sleeves. Cusco front camber plates and radial bearings to eliminate steering bind, Tein rear upper mounts. Comes with second set of front strut inserts and adjustment knob. Upper mount bearings worn, all front struts worn. Comes with bump stops, but no springs. Rides super nice, fronts will go pretty low, rears would need ground control sleeves or very short springs to go low. -VIPER ALARM SYSTEM- $100 Remote start, one mile range, COMPLETE system. Setup for newer vehicle w/can communication. Sent from my iPhone using Tapatalk Last edited by racepar1; 05-17-2019 at 10:31 AM.. |
