Old 08-18-2019, 04:04 PM   #1
Slim240
Slim240 is an unknown quantity at this point
KA TDC On KA24e
I believe I’m having timing issues on my KA24e w a single cam. I’m trying to install a new distributor as the other one was toast. I’ve seen videos on how to get top down center on dual cam KAs but barely anything on the single cam variant, do you guys have any tips or procedures? The engine almost wants to run but it’s not running :/
Slim240 is offline   Reply With Quote
Old 08-18-2019, 04:45 PM   #2
S14rebuild
S14rebuild is a glorious beacon of lightS14rebuild is a glorious beacon of lightS14rebuild is a glorious beacon of lightS14rebuild is a glorious beacon of lightS14rebuild is a glorious beacon of lightS14rebuild is a glorious beacon of lightS14rebuild is a glorious beacon of lightS14rebuild is a glorious beacon of lightS14rebuild is a glorious beacon of lightS14rebuild is a glorious beacon of lightS14rebuild is a glorious beacon of light
Its the same... pull pug, put long screw driver in hole, turn crank till its all the way up and air is pushing out the top. And the highest the screw driver goes.Thats compression stroke and tdc. Look for timing mark on crank pulley
S14rebuild is online now   Reply With Quote
Old 08-18-2019, 07:08 PM   #3
Slim240
KA
Appreciate it and just to clarify stick the screw driver in cylinder #1 rifht? I eyeballed the first cylinder last time to find TDC so I thought I did something wrong. I also don’t have any timing knotches on my pulley for some reason I see the pointer but no markings
Old 08-18-2019, 07:09 PM   #4
Slim240
Old 08-19-2019, 07:39 AM   #5
jedi03
yup number 1, just roll it back an forth to verify actual tdc as there are a few degrees where the piston stays up
Old 08-19-2019, 10:04 AM   #6
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
is it the factory pulley? if so, get in there with a toothbrush and scrub it up. the markings are just little notches and its easy for them to get covered up with grime and gunk,
brndck is online now   Reply With Quote
Old 08-19-2019, 10:34 PM   #7
Slim240
KA
Awesome ill try that even though it is pain in the ass to get to the pulley lmfao
