Old 08-14-2019, 07:26 PM   #22771
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
Does anyone know if it is still possible to buy S14 240SX door weatherstripping? Ive been checking my usual spots and its all discontinued.
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 08-14-2019, 09:39 PM   #22772
inopsey
i just bought all the new s14 door/chassis seals i could in the fall (2018), was able to source every seal except the trunk.
Old 08-15-2019, 11:51 PM   #22773
Standard
Standard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud of
DarkSide, here's the link for the adapter socket
https://www.amazon.com/Halogen-Headl.../dp/B07JB43739
For the rubber boot that protects the housing from the elements, I'd suggest measuring the diameter of the hole on the housing and head to a pick n pull yard, they are super common on Toyotas, Nissans and Hondas especially and I'd bet you could find one that would fit perfectly. At the yards I frequent an item like that would be free, same goes for an adapter socket that may work. Look for a mid 2000's Altima for the socket. Good luck man!
Standard is offline   Reply With Quote
Old 08-19-2019, 02:02 PM   #22774
Presto
Presto's Avatar
Presto is an unknown quantity at this point
s13 Bought broken coupe like 5 months ago haven’t driven it yet
HELP A NOOB OUT!! I bought this car with dreams of driving a 240 but I still haven’t fixed it
Ka24e SOHC
Previous owner did injector pigtails, distributor,rotor, ignition coil, water pump, coolant temp sensors, fuel pump, engine and trans mount, egr block off plate, pretty much deleted everything besides brake booster and fpr,
I did: new injectors, new maf sensnor, new throttle position sensor, new header + exhaust, re routed 1 vacuum line, new o2 sensor, cleaned throttle body plenum thing, capped some holes on intake manifold,
I know I have to re-do the ignition timing and properly calibrate the tps, and my coolant temp sensor connector wiring cracked off, and the hose on my air regulator is dried solid
Problem: Car can start first turn after sitting for a long time, it will idle at almost 2k rpm but it stays right there the needle doesn’t jump around at all, after some time the car just slowly starts stalling itself out, and when I give it gas it will bog really bad.
Presto is offline   Reply With Quote
Old 08-19-2019, 06:42 PM   #22775
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
I wanted to know if anyone has used the ISR e85 injectors with success?
https://www.enjukuracing.com/product...-set-of-4.html
lewisfk is offline   Reply With Quote
Old 08-19-2019, 06:47 PM   #22776
lewisfk
lewisfk's Avatar
s13 E85
Old 08-19-2019, 07:04 PM   #22777
My!
My! will become famous soon enoughMy! will become famous soon enoughMy! will become famous soon enoughMy! will become famous soon enoughMy! will become famous soon enough
does anyone know how much type x kits go for these days?
My! is offline   Reply With Quote
Old 08-19-2019, 09:25 PM   #22778
lewisfk
lewisfk's Avatar
^^ You can get all the parts new from FRSPORT or Nissanraceshop for about 880 for the body kit. To complete the look it will cost $300 for brackets and lights needed for the front end. 450-565 for the type x rear lights with lock and key. The biggest hassle will be SHIPPING! I was quoted $500 from Cali to Texas. Grand Total 2,215 with tax. There are individuals on this forum who can get better prices than this, due to being Old G. I'm taking a road trip to California in March 2020, and plan to pick up my kit then.
Old 08-20-2019, 11:56 AM   #22779
WIKID S4TEEN
WIKID S4TEEN's Avatar
WIKID S4TEEN is making a name for him/her selfWIKID S4TEEN is making a name for him/her self
For those running BMW style 95 wheels, what hardware are you using because I noticed the wheel is for a 14x1.5 lug bolt/stud and most wheel adapters are 12mm studs.
Rock wha U jock and don't talk if U ain't got!!
WIKID S4TEEN is offline   Reply With Quote
Old 08-20-2019, 11:58 PM   #22780
Standard
^^ Are you sure? Im almost certain that the kouki 180sx sideskirts, rear valance and front lip were discontinued. Got a link for these brand new?!? The front bumper, brackets, and tail lights are still available but I think that's it right?
Old 08-21-2019, 12:11 AM   #22781
lewisfk
lewisfk's Avatar
https://frsport.com/nissan-76858-60f...iABEgLfMvD_BwE
Just google type x side skirts
Old 08-21-2019, 06:52 AM   #22782
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
Rear valences and front lip definitely are. Pretty sure side skirts and the rear wing are also discontinued, but not as confident on those.
Originally Posted by lewisfk View Post
I could be wrong, but I don't believe FR Sport actually has any of that stuff anymore. They have tons of old listings for OEM Nissan items on their website that have been discontinued, some for years. I've reached out to them a few times and they reply to tell me it is discontinued and out of stock.
I can't say that is the case specifically for the items in question, just sharing my experience with them as of late.
The front bumper and MOST components for installation are still available new. NissanParts.cc is running 10% off until Sunday as well which helps with the cost (no affiliation with them other than being a long time customer):
https://www.nissanparts.cc/c-180sx-kouki-17
These prices reflect more or less what I have seen this stuff go for in the last year (used condition):
Front bumper (all brackets and lights): $700-900
Front Lip (OEM): $600-900
Side Skirts: $550-700
Rear Valences: $500-600
Wing: $300-400
Tail Lights: $500-650
Certainly not trying to say these prices are right or wrong, just based on observation.
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
Old 08-21-2019, 07:05 AM   #22783
CamryOnBronze
Originally Posted by DarkSlide77 View Post
https://www.ebay.com/i/233232838623?...gaAkHfEALw_wcB
This is the link just to see the circular rubber seals that are on the back of the Silvia headlight. The best way I would describe it is like a grommet kinda. If anyone has any idea where to find these or find another way to deal with it I’d like to hear it.
26029-10V00 & 26029-10V00 (Right) and 26029-10V00 & 26317-25V00 (Left) are the part numbers for those rubber seals on the Silvia headlights. I would hit up Jesse Streeter or RHD Japan to have them check to see if they are still available or not. Good luck!
CamryOnBronze.com
Old 08-23-2019, 07:43 AM   #22784
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
QUESTION:
What would be a good price for an s14 zenki 1996 shell?
Maroon in color. Clean complete interior and the exterior has faded paint but the body itself is very mint. Blown KA under the hood, auto transmission. SE model so came with the bumper lip spoiler, "fog lights", sunroof, and 5 lug. Overall I would rate it a 7/10.
Owner wants $2,000.00
Dudes voice makes my arm feel punchy.
da_crew10 is offline   Reply With Quote
Old 08-24-2019, 04:29 PM   #22785
DarkSlide77
DarkSlide77's Avatar
DarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really nice
Ka24e SOHC
First fix the problems you mentioned that you know you have, then come back and report.
DarkSlide77 is offline   Reply With Quote
Old 08-25-2019, 02:30 PM   #22786
Presto
Presto's Avatar
s13 I give up goodbye cars
My car make me mad today
Old 08-26-2019, 10:09 AM   #22787
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Does anyone know what TOb and sleeve (and part numbers if possible) Nismo Coppermax Twin or Gmax twin use??
Old 08-28-2019, 07:24 AM   #22788
180sx_
180sx_'s Avatar
180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about
my interior makes an annoying squeak, its only the worst when driving around town and slow, tight corners and going over small bumps which causes the interior to creak and squeak. sounds like its the passenger side but lord knows where exactly it could be. i might try have a look tomorrow
180sx_ is offline   Reply With Quote
Old 08-28-2019, 04:11 PM   #22789
NuclearMacaroni
NuclearMacaroni is an unknown quantity at this point
s13 Silvia Question
Alrighty, i know Silvias, i know the chassis codes, i know Chukis Koukis Zenkis.. But im trying to figure out a little question ive been asked. Car in question is a 1992 Nissan 240sx S13 Hatch, no body swaps... bone stock. And the question is what JDM enthusiasts call the car... ive tried everything and so far nothing is right. Anything im missing?
NuclearMacaroni is offline   Reply With Quote
Old 08-28-2019, 08:34 PM   #22790
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
1992 240sx S13 hatch = chuki
Old 08-29-2019, 06:10 PM   #22791
lewisfk
lewisfk's Avatar
I need a new vacuum source, since I have a chase bays master cylinder delete kit. Is the throttle body enough to support boost gauge and any other items.
Old 09-01-2019, 01:52 PM   #22792
Andrewkd
Andrewkd's Avatar
Andrewkd is an unknown quantity at this point
SR S14 rotors won’t fit in
Hello guys, not too long ago I bought an s13 with a s14 subframe, it had z33 brakes on the rear, I went back to 4 lug and stock brakes, bought rotors for s14 but they hit the drum assembly, they won’t slide all the way in, it makes no sense for the subframe, arms, axle, etc to fit right in as s14 and the knuckle be z32, very weird, anyone knows if there’s a difference, my best bet is that if the rotor has to be bigger then it’s z32 knuckle but I’m not sure as it wouldn’t make much sense as to all s14 parts to fit so smoothly
Andrewkd is offline   Reply With Quote
Old 09-01-2019, 10:59 PM   #22793
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Stock 240 doesn't use drum ebrake. S13 and s14 rear calipers have ebrake built into the caliper.
Old 09-01-2019, 11:08 PM   #22794
Andrewkd
Andrewkd's Avatar
Damn so I got z32 knucke and drum?
Old 09-01-2019, 11:14 PM   #22795
Andrewkd
Andrewkd's Avatar
Old 09-01-2019, 11:20 PM   #22796
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Z32 knuckle makes it so that bottom of the shock is a fork mount vs s-chassis which is a stud/eyelet mount. They're interchangeable but the shock mount is different.
The correct way to fix it would be to just pull the ebrake assembly off. You'd be missing the backing plate but otherwise everything else bolts on.
Look up z32 rear brake swap and then just imagine the reverse.
https://importnut.net/300zxbrakeswap.htm#rearbrake
Old 09-02-2019, 03:45 AM   #22797
SRSmith
SRSmith is an unknown quantity at this point
Hey Guys,
My carbon fiber hood split in two (top and bottom halves separated). What should I use to fuse the halves back together? Is there something I could buy locally?
Thank you much
SRSmith is offline   Reply With Quote
Old 09-02-2019, 02:50 PM   #22798
srh666
srh666's Avatar
srh666 has made poor choicessrh666 has made poor choicessrh666 has made poor choicessrh666 has made poor choicessrh666 has made poor choicessrh666 has made poor choices
Any yashio factory dealers in the united states?
srh666 is offline   Reply With Quote
Old 09-03-2019, 11:14 AM   #22799
rv_zenki
rv_zenki is an unknown quantity at this point
Im having a potential ignition timing issue with my 1996 s14 with a KA. Im looking at the timing with a OBD scanner from amazon. I followed the procedure from alldata: Warm it up, Shut it down, unplug TPS, turn it on, rev it to 3K 3 times, adjust timing to 20*, shut it off. plug TPS back in, Start it, rev to 3k 3 times again. After I do all this the timing at idle is like 11*? Not sure whats up.
rv_zenki is offline   Reply With Quote
Old 09-04-2019, 10:07 PM   #22800
SkidzNY
SkidzNY is an unknown quantity at this point
neeewb y cant i make a new thread
SkidzNY is offline   Reply With Quote
