03-26-2019, 10:47 AM | #1 |
S14 Sr20det redlines at startup
Just swapped my zenki sr20det into my kouki. I have a FMIC, HKS SSQV BOV (not recirculated), stock intake with K&N filter, Kouki MAF & ECU, and a new radiator. I dont have the cat or exhaust hooked in yet because the car isnt running
My vacuum lines are cold pipe to stock wastegate. Top right plug from throttle body goes to the BOV but did not use the plastic filter. All others are plugged [IMG][/IMG] The issue is at startup. I start the car and it idles rough for a few seconds before it revs up towards redline. I have no idea what is causing this but I feel like it has to be a massive vacuum leak somewhere I have checked: + fuel lines are installed correctly + all couplers are on tight and correct + plugged large and small hole on stock rubber intake pipe + HKS BOV appears to be on tight and doesnt spin + throttle body "inner" screws are on + throttle cable is attached with two watchers and doesnt seem to be pulling too much on the throttle + grounds seem to be right for W/S harness + capped all vacuum lines on intake manifold / throttle body that are under the throttle body + capped large outlet on cold pipe intended for BOV Any ideas? I think it is a massive vacuum leak but I am not sure as I have gone over the car a lot but maybe I am missing something on the intake manifold. Is it because my BOV is not recirced? |
03-26-2019, 10:59 AM | #2 |
03-26-2019, 11:18 AM | #3 |
Have you verified that the throttle body is functioning properly? I had a similar problem, turned out a ziptie had fallen into the intercooler, got sucked into the throttlebody and wedged throttle plate open. Luckily I got it before it went into the engine.
S13 |
03-26-2019, 11:41 AM | #4 | |
I tried to attach an engine bay picture to this |
03-26-2019, 11:44 AM | #5 | |
Shouldnt the throttle body remain slight open at all times? I imagine a small amount of air is needed even at idle I plan to try to start the car without the throttle cable engaged today to see if I still rev up |
03-26-2019, 11:45 AM | #7 |
03-26-2019, 04:45 PM | #9 |
Thanks everyone...
I disconnected the throttle cable completely and the car idles rough but doesnt rev up like crazy. I looked closer at the bracket and there was some welding done to it so it must be off from stock position. Now, I am off to figure out if I can buy one or if I have to build it. |
03-27-2019, 08:31 AM | #10 |
usually its custom (speaking from s13/aftermarket intake manifold experience) but if that's what did it you should be able to adjust the cable with the nuts on either side of the bracket to allow it to close...then you can start getting the rough idle out of the way!
