Old 05-26-2019, 12:40 AM   #1
HULKS14
HULKS14 is an unknown quantity at this point
s14 S14 Indicator/Hazard Problem HELP!!!
so ive recently changed from a Sr20de to a Sr20det
and ive come to an issue with my lights.
When indicating left or right my hazard lights come on checked all the fuses everything is good im baffled with what to do?
any help would be amazing cheers!
HULKS14 is offline   Reply With Quote
Old 05-26-2019, 09:18 AM   #2
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 is an unknown quantity at this point
Feedback Score: 18 reviews
The turn signal stalk can be going bad. Only the reverse lights are connected to the trans wiring harness, so this really doesn't have anything to do with the engine swap. Unless of course you did some extra wiring work that you failed to mention.
Old 05-26-2019, 10:29 AM   #3
Kingtal0n
Kingtal0n's Avatar
Kingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really niceKingtal0n is just really nice
also try messing with the hazard button
Old 05-27-2019, 01:02 AM   #4
HULKS14
i did however attempt to delete alot of my dash loom but the hazard switch had like 3 red/pink wires spliced between them , i do believe it could be the turn signal stalk failing...
problem, s14
Copyright ©2000 - 2019, vBulletin Solutions Inc.
