Old 03-09-2017, 08:13 PM   #1
rc1honda
rc1honda's Avatar
rc1honda is an unknown quantity at this point
Lifter tap vs rod knock vid inside.
https://youtu.be/egKr3Ibbrwc&fs=1" width="644" height="390">https://youtu.be/egKr3Ibbrwc&fs=1" />https://youtu.be/egKr3Ibbrwc">http://www.youtube.com/watch?v=https://youtu.be/egKr3Ibbrwc
UPDATE CRAZY CANSHAFT WEAR PATTERN BELOW any ideas welcome
http://imgur.com/zsldxAM
Have loud tapping coming from my newly swapped short block
Have bled the lifters twice now not sure what going on.
Car runs awesome. Power everywhere. Just loud tap. Follows the revs throughout the range.
No change in sound with spark plugs unplugged
S13 SR
.20 over
Cp pistions
Eagle rods
Hydro lifters
Hks 264 step 2
BC springs and retainers
Have the VC off now any ideas are welcome
rc1honda is offline   Reply With Quote
Old 03-09-2017, 08:43 PM   #2
jedi03
Check for the spacers between the rocker and valve
Old 03-09-2017, 09:19 PM   #3
derass
Video's not working. Could it be piston-slap from the new forged units?
Old 03-09-2017, 10:13 PM   #4
rc1honda
rc1honda's Avatar
Well ther block is used with "200" mikes on it.
But wait there's more what In gods holy name would cause this kind of camshaft wear
It goes like this all the way down the cam. Wearing where there is no journal contact? Never even head of it
Old 03-09-2017, 10:23 PM   #5
rc1honda
rc1honda's Avatar
Guides and shims are all in place. Although the bottom of the ras seems like the rockers have been trying to pop off
Old 03-10-2017, 12:39 AM   #6
wurley
wurley's Avatar
wurley is an unknown quantity at this point
are you sure the cams are for hydro lifter and not solid?
WTB: FRONT S14 SILVIA Q'S SEATS (purple zebra)
wurley is offline   Reply With Quote
Old 03-10-2017, 01:03 AM   #7
CompleteXen
CompleteXen is an unknown quantity at this point
Videos super quiet, for other to listen here is the fixed link - https://www.youtube.com/watch?v=egKr3Ibbrwc.
Were bearing clearances checked before install? If so it almost sounds like VTC or chain noise.
CompleteXen is offline   Reply With Quote
Old 03-10-2017, 03:09 AM   #8
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
Are you really missing cam cap bolts?
Frank_Jaeger is offline   Reply With Quote
Old 03-10-2017, 06:58 AM   #9
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
That's not wear, that's machining marks from the camshaft manufacture...
[email protected]
hanzbrady is offline   Reply With Quote
Old 03-10-2017, 07:02 AM   #10
hanzbrady
hanzbrady's Avatar
From someone who works in a machine shop,
Piston slap doesn't exist. "piston slap" is a builders excuse to get you to believe that your rod knock isn't that serious. Race engines that get serviced after a season will often be used until they have about .010" piston to wall clearance. Which is a hell of a lot more than the .003- .0035 that they're originally machined to and you know what not one of them happens to "slap" on start up.
[email protected]
Old 03-10-2017, 07:08 AM   #11
hanzbrady
hanzbrady's Avatar
That's because RAS suck. Let's think about what RAS actually do, in the event that a rocker would fall off it would normally just pop off or break and the valves in that cylinder wouldn't open and you'd have a misfire. Now when you add RAS the rocker can't fall off, well straight at least, more than likely you'll get a rocker stuck crooked over a valve or two hanging them open to punch a few holes in a piston ruining the short block and the head. But hey at least those RAS stopped the rocker from popping off right?
If you're really concerned about rockers flying off do a dual guide and solid pivot conversion, don't throw band aids at your problem.
[email protected]
Old 03-10-2017, 07:19 AM   #12
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Ahhhhh, he doesn't have RAS actually. He was just trying to convey what it looks like so we can get a better idea on the issue
P.S Take a look at the pic.
Also, those do not look like cam machine marks to me??
RalliartRsX is online now   Reply With Quote
Old 03-10-2017, 07:21 AM   #13
hanzbrady
hanzbrady's Avatar
Cams are sand cast, except for GSC which do produce billet camshafts. From what it looks like those cams are a 2 piece cast and had material squish out the sides of the mold, so when they we're removed from the mold they simply snapped the residual material off.
[email protected]
Old 03-10-2017, 07:35 AM   #14
rc1honda
rc1honda's Avatar
I DO HAVE RAS. I took the bolts off that side of the cam caps to check out the RAS and see look at the rockers and lifters.
The bottom of the RAS legs are beat up from the rockers popping against them.
Old 03-10-2017, 07:37 AM   #15
rc1honda
rc1honda's Avatar
Thanks for that doing man. Appreciate it.
Old 03-10-2017, 07:55 AM   #16
RalliartRsX
Trader Rating: (32)
Oppp,s I guess I misread about the RAS
Old 03-14-2017, 05:08 PM   #17
tgd89
tgd89 is on a distinguished road
My car was making similar sounds while the oil pump was failing, have you cranked the motor to see if oil is coming out of the cam squirters?
tgd89 is offline   Reply With Quote
Old 03-15-2017, 12:49 PM   #18
rc1honda
rc1honda's Avatar
Had it running with the VC off. Oil pressure is good and oil is flowing out of the squirters.
Still don't know what's caused that crazy cam wear.
Old 03-15-2017, 12:53 PM   #19
hanzbrady
hanzbrady's Avatar
That.^^^^^^
[email protected]
Old 03-15-2017, 12:59 PM   #20
hanzbrady
hanzbrady's Avatar
For example this is a product photo of a set of brand new Kelford SR20det cams and they have the same markings.
[email protected]
Old 03-15-2017, 04:42 PM   #21
rc1honda
rc1honda's Avatar
Ah I see it. Mine are HKS but yea it was worrisome.
Also I have a new OEM lifter and rocker arm coming. Will have it in this week.
I'll update if it fixes the issue
Old 03-15-2017, 05:10 PM   #22
bataangpinoy
bataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymore
what oil are you running?
Originally Posted by GTR-Garage
Handling, power and style must be in harmony.
bataangpinoy is offline   Reply With Quote
Old 03-16-2017, 09:20 AM   #23
rc1honda
rc1honda's Avatar
Mobile 1 0w-40. I've was thinking of going rotella 15w 40
Old 03-16-2017, 01:13 PM   #24
jedi03
Did you measure the cams and lifters to get your shims right? That's odd if they are hopping like you are describing too
Old 03-16-2017, 01:58 PM   #25
rc1honda
rc1honda's Avatar
Using the factory hydros, shims and guides. All put back into place from where they were From the factory.
It is possible it could be an bad spring as well.
Can't really rule out rod knock either. Although its definitely coming from the head and is a loud ticking not a knocking.
Old 03-17-2017, 08:02 AM   #26
jedi03
o check your coil packs...buddy had failed one sounded the same...did ruin the ring eventually with continued driving...also check for oil in the plug well
Old 03-18-2017, 03:19 PM   #27
rc1honda
rc1honda's Avatar
The car would misfire then i assume right? The car runs awesome actually.
Has power everywhere. Pulls 18mmHg vac and idles like a champ. Honestly I'm really bummed becuase the car runs so well but has the fucking tic. Took the wind outta my sails
Old 03-18-2017, 04:59 PM   #28
jedi03
His didn't it was wierd...first time I had seen it without other symptoms...
Old 03-19-2017, 11:08 AM   #29
rc1honda
rc1honda's Avatar
Update. Well new lifter and rocker arm did nothing.
Thinking it's rod knock.
Old 03-19-2017, 11:09 AM   #30
jr_ss
Trader Rating: (33)
jr_ss is just really nicejr_ss is just really nicejr_ss is just really nicejr_ss is just really nicejr_ss is just really nicejr_ss is just really nicejr_ss is just really nicejr_ss is just really nicejr_ss is just really nicejr_ss is just really nice
Feedback Score: 33 reviews
Pull the pan and remove bearing caps. You'll know when you see it.
My SR20VET
