03-17-2019, 04:17 PM | #1 |
Garage clean out s13/s14 parts
Alright so its time to get rid of some stuff ive been piling up, everything is used but was working fine when removed, prices are cheap because I need the space more than the money so let me know if you need anything , I'm located in the IE , just shoot an offer I probably won't say no, not gonna post pics bcuz it takes too long, pm me if you want more info.
S13 dual cam cluster 5$ S14 used 5 speed lower harness uncut/no splices 30$ S14 used 5 speed lower harness cut/ spare parts 5$ S13 dual cam distributor with cap rotor and wires 20$ S13 oem coolant reservoir no leaks starting to crack 5$ S13 ka dual cam ecu 20$ S13 oem shift knob pretty clean 5$ Ka Dual cam power steering pump bracket 5$ Ka dual cam alternator front bracket no bolts 5$ S14 zenki oem front sidemarkers no cracks 10$ S13 ka24de ignition coil with bracket and new ignition control module 10$ S13 ka24de complete intake manifold with throttle body and fuel rail 20$ S13 vert main body harness uncut/no splices 100$ S13 vert main engine bay harness with fuses boxes uncut 100$ S13 ka24de engine harness cut and missing maf connector 10$ S13 ka24de lower harness 20$ S13 ka24e 5 speed oem radiator pretty clean 10$ S13 abs open diff with j30 rear cover 10$ S13 both oem 6 bolt axles with axle nuts clean30$ S13 abs 4 lug hubs 10$ S13 hatch oem taillights clean all 3 pieces 20$ S13 oem front calipers with hoses, and good pads 20$ S13 oem rusty front rotors less than 1000 miles 5$ S13 sr20 ebay downpipe never used 10$ S14 oem se wheels only have 3 need tires , 5$ each S13 dual cam random header 5$ Also have Extra 5 speed transmission parts , s13 bell housing, throw out sleeve, clutch fork, used trans mount , shifter plate, etc. lmk if you need anything I pretty much have a whole extra 5 speed transmission taken apart 5$ whatever you need. |
03-18-2019, 11:54 AM | #3 |
I don't know if you have it or not but would be amazing if you did. I am looking for the vacuum hose from the intake to the brake booster. I am looking for the whole thing metal tube, rubber hose and check valve. Mine was removed I think for a 2jz swap that never happened. If so how much shipped to 83607?
Have a great day, jared |
03-18-2019, 01:26 PM | #4 |
You don't by chance have an upper s14 ka harness? it can be cut up
04-04-2019, 11:51 PM | #9 |
whats up man, I'm looking to pick up the s13 distributor, clutch fork, throw out sleeve and maybe other things too. I'm local and ready to pick up thanks
Zzzz |
