Old 04-19-2020, 07:04 PM   #1
RedSled
RedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-known
rear stay assembly
hi good day, need some input as to why the rear stay assembly bends on s13 rear suspension ,I've replaced them already and well was doing some work on the rear an noticed these slightly bent again ,this is the part that acts as the front washer for the bushings on the subframe and also connect to the chassis .
RedSled is offline   Reply With Quote
Old 04-19-2020, 07:20 PM   #2
samotage
samotage is an unknown quantity at this point
Are your subframe bushings munted? You can tell if you have axle tramp. If so the subframe will slop about, and likely bend these stays.
Sent from my iPad using Tapatalk
samotage is offline   Reply With Quote
Old 04-19-2020, 07:36 PM   #3
RedSled
Got spl solid bushings even the diff has solid bushings
Old 04-19-2020, 08:57 PM   #4
samotage
How much power? Is the chassis twisting?
Old 04-19-2020, 09:32 PM   #5
RedSled
Isn't this normal for s13 ? cause when I was getting a replacement, there were a lot of bent ones
Old 04-20-2020, 06:24 AM   #6
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
Are you bending the arm of the little tabs that come off the rear subframe that the bolt goes through to secure the arm or literally the whole control arm itself?
SupaDoopa is offline   Reply With Quote
Old 04-20-2020, 08:15 AM   #7
RedSled
just the little arms
Old 04-20-2020, 08:18 AM   #8
RedSled
actually both gets slightly bent ,but the one I'm seeing the bends are the ones bolting directly under the subframe bushings
Old 04-20-2020, 02:01 PM   #9
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
The fuck is a 'little arm?' Take a picture.
