06-05-2019, 04:24 PM | #1 |
Trader Rating: (18)
Feedback Score: 18 reviews
TONS OF RACE CAR PARTS!!!!! Tial-Aeromotive-Precision-PROEFI-RacePak-ARE-Voltex-CP...
HUGE PRICE DROP ON ALL PARTS
So as my vehicle and myself progress, it unfortunately requires things to change over time. I'm adding a lot of my current parts up. They are already removed from the car and will not be getting anymore hours put on them. - Everything was on the vehicle and used for 2 seasons (11 Events Total) - Everything is in Perfect Working Order TF-Works Ceramic Coated Custom SR-VE Dual Plenum Intake Manifold w/ Fuel Rail (no injectors) - Dual intake plenum design - Individual runner gasket design - Dual Plenum Explained: A dual plenum allows the air to be calmed down in the first plenum and then move into the second plenum evenly, thus allowing all cylinders to get an equal amount of airflow. Most inline engines tend to get less air in the rear cylinders and this helps even it out. In the end, you get a lower chance of leaning out the last cylinder and you potentially get more power. - NEW PRICE - $1,300 Billet 90mm Throttle Body - NEW PRICE - $200 TF-Works Ceramic Coated SR VE Twin Scroll Dual Wastegate Exhaust Manifold - Reason: Going to a V-Band connection with a large single wastegate - NEW PRICE - $1,050 Precision 5862 Turbo Twin Scroll .84A/R Ceramic Coated - Reason: Going with a large V-Band style turbo - Price: $1,250 RacePak IQ3 Data Logger - 250-DS-IQ3LD - Includes GPS module - $1,150 ProEFI Color CAN Display (non-logger) - $350 Spa Design Dual Gauge (Boost/EGT) - Comes with sensors - $200 Spa Design Dual Gauge (Liquid Temp/Liquid Temp) - Comes with sensors - $200 Spa Design Dual Gauge (Trans Temp/Rear End Temp) - Comes with sensors - $200 Voltex Carbon Diffuser - had 2 small cracks, which were repaired professionally by a shop in Illinois - $400 WedsSport SA55M - 18x9 + 20 and 18x10 +18 (5x114.3) - WedsSport Center Caps - WedsSport Valve Stems - BRAND NEW...never had tires on them and have never been mounted on a car. - Retail= $2,178 + Shipping - Asking= $1,400 ARE Universal Remote Oil Filter Block - $100 CP Pistons SR20VE-T 9.0:1 Compression - 89mm - $350 SuperTech P11 +2mm Intake Valves - 5 Angle Valve Job - $175 Supertech P11 +1mm Exhaust Valves - 5 Angle Valve Job - $175 Hydraulic Hand Brake - Wilwood Master Cylinder - Reservoir not included - $80 R.J.S. Racing Equipment 5-Point Harness (Pink) - BRAND NEW! - Cam Lock - $105 350z Doors - $200 350z Door Panels - $100 350z Master Cylinder - $50 350z Brake Booster - $50 350z Front Upper Arms - $50 350z Front Lower Control Arms - Have SPL Bushings (need a single replacement bushing spacers) - $75 350z Dust Sheilds - $40 350z Drivers Side Floor Mat - $25 350z Drivers Side Door Sil - $20 350z Wheel Speed Sensors - $20 SR20DET Chain Tensioner - $40 SR20DET Upper Oil Pan - $35 SR20DET NEW Oil Pump gears and Cover - $30 SR20DET Oil Block - $15
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 10-09-2019 at 08:36 AM.. |
06-05-2019, 04:50 PM | #2 |
are you parting out your z33 or something happened?
06-05-2019, 05:35 PM | #3 |
Trader Rating: (18)
Nah, just changing things up a bit. Bigger turbo for the upgraded engine and switching to all motec. Should be done with the change in the coming months.
https://instagram.com/eck_matthew/ |
06-05-2019, 04:58 PM | #4 |
Trader Rating: (130)
Feedback Score: 130 reviews
oh look at all these things I need!!!
06-10-2019, 10:23 AM | #5 |
Trader Rating: (18)
Took money off all parts. Total combined price drops totaled over $1,600. These are great deals guys!
06-12-2019, 03:13 PM | #7 | |
