03-29-2020, 02:35 AM | #1 |
Sr20vet rwd conversion which pistons?
Hi guys I?m building. Rwd sr20vet using p12 head and p12 turbo cam with super tech shimless valves +1mm
I just found out the pistons we using are CP DET pistons so there is no valve relief The motor is assembled and spun by hand no sound of hitting, but I?ve heard that I need to use sr20vet pistons. Is this true ? |
03-30-2020, 09:02 AM | #4 |
Yes....hence the variable valve LIFT in the terminology.
You will have to clay your engine WITH the high lobe activated. It serves no purpose to turn the engine over on the low lobes as that tells you zilch on valve clearance...... |
03-31-2020, 07:41 PM | #6 |
Hook up an air source to the VVL oil feed line to lock the rockers while you turn the motor over
04-03-2020, 08:15 AM | #8 | |
Trader Rating: (130)
Feedback Score: 130 reviews
if you can do your own disassembly and machine work, then its obv cheaper. if you want to skip the cost of machining all together, just buy new pistons that are designed for this application. |
