11-18-2019, 01:30 PM | #1 |
1.5JZ S14 Poject *Big Price Drop*
Hello zilvia
I am re posting this ad because I am getting an error page for some reason if I try to edit my previous posting. I lowered the price significantly to speed the sale and to match the work needed to be done. I am not interested in parting out and while I am looking for a straight sale Id be open to a trade offer if you had something in mind. ONTO THE CAR I had the machine work done by Chuck Exton from Exton Automotive Machine Shop in PA. Chuck had made a name for himself in the drag scene in the funny car world and I have seen many successful local builds come out of his shop as well. I got the car running and before I got the chance to put it on the dyno, decided I wanted to get into drifting so I took the car back apart and began the roll cage where the project stopped. The cage is almost complete just needs a rear cross bar and gusseting if preferred. The car is apart but everything is in a bin or bag so a uhaul & car trailer or big truck bed & car trailer will be the necessary method of transportation. This car comes with full clean interior! Located in Oxnard CA Ok now for the fun stuff. Im going to list the parts and their retail price to get an idea where the current price point is coming from. Parts list comes in around $21k not including the chassis itself, the machine work and also a few other things I know im forgetting. ASKING $9,500 FIRM DRIVETRAIN - $12,500 ENGINE $5755-1.5JZ (1JZ non vvti head on a 2JZ block) HEAD BC 264 Camshafts - $740 BC Springs and Titanium Retainers - $415 SupraStore Cam Gears - $200 New OEM Valve Seals BLOCK CP 10.5:1 Pistons With Upgraded 9310 Wrist Pins -$1000 Carillo H-Beam Rods With Upgraded SPS CARR Bolts $2100 Titan Motorsports Billet Main Caps - $590 ATI Super Damper - $390 A.R.P. Head and Main studs- $320 Transmission $3800 R154 Transmission With All Marlin Crawler Upgrades - $2000 SPEC Twin Disk Clutch W/ Wilwood Master Cyl - $1800 TURBO KIT $2945 Precision 7275 Turbo - $1600 Tial 50mm BOV - $230 Tial MVS 38mm Wastegate - $265 4" V-Band Downpipe to 3" V-band Exhaust CXRacing manifold - $500 Large Core Intercooler & Piping - +/- $350 Chassis $8795 FUEL $1990 ID2000cc Injectors- $1400 Radium Engineering Surge Tank W/Dual Bosch 044 Pumps - $440 Walbro 400LPH E85 In-Tank Pump - $100 Ebay Top Feed Fuel Rail - +/- $50 ELECTRONICS $3380 Upgraded 240Amp Alternator - $400 AEM V2 Standalone - $1000 Chase Bays Harness *unused* - $1200 3.5 Bar Map Sensor - $150 AEM UEGO Wideband $130 Oil Pressure & Boost Gauge - $100 Dakota Digital Tach Adapter - $80 Dakota Digital Speedo Adapter - $80 LS Coil Packs - $240 Suspension $3425 ER Spec Roll Cage - $500 ISR PRO Arms - $600 Solid Diff & Subframe Mounts - $205 Q45 Diff + J30 Axles - +/- $200 Square 17x9.5 Wheels W/ Nitto NT05 on rear - $600 CXRacing 2jz Swap mounts - $440 Maverick Dual Z32 Caliper Mount - $230 Z32 Front and 4 Z32 Rear Calipers - $600 ISR Hydro Ebrake - $50 https://ibb.co/xCgmTrT https://ibb.co/W50ZW8r https://ibb.co/sb3W1r9 https://ibb.co/qydtgmQ https://ibb.co/JQRt8mB https://ibb.co/7WxxBdx https://ibb.co/tskpSLP https://ibb.co/Sv3XPV3 https://ibb.co/QvBwdxX https://ibb.co/NF75wHb https://ibb.co/NNNytPd BEFORE CHASSIS FAB https://ibb.co/pP2HP9g https://ibb.co/SRFKj6v Last edited by findmea240; 11-18-2019 at 07:52 PM.. |
