Old 07-15-2020, 11:35 AM   #1
Avayo
Avayo is an unknown quantity at this point
Scott's 92 S13
Hey guys! Always enjoyed reading other build threads so figured I would create one now that I'm making some progress on my 240. I actually ended up picking this car up back in 2017. I found it listed on Craigslist for a great price and drove down to Maryland with a couple buddies to pick it up. One of my friends thought I was crazy paying what I did for the car but I saw the parts that were included, and ended up making out like a bandit.
While on the hunt for a 240 I really only wanted two things, no rust and a hatch. I didn't even mind starting with a shell, because I wanted to get my hands in there and make it my own. I was coming from a Subaru and while it's a great car, it isn't the platform I wanted to go all out on.
Avayo is offline   Reply With Quote
Old 07-15-2020, 04:24 PM   #2
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
This is approved for now. Update with some actual build thread progress or this will most likely be closed.
Old 07-15-2020, 06:20 PM   #3
Avayo
First thing was first, I had to get that Silvia front end off. Before I even had the car I knew I wanted to run the kouki/type x aero on the car. I scored some parts from a forum member and it was a great start to the pop-up conversion.
Next up was fixing the damage on the quarter panel. It was a pretty nasty dent but instead of slapping overs on it and calling it a day I had it repaired.
After some going back and forth I decided to pull the SR outta there so I can paint the bay and patch up some holes. I have no intention on keeping this car blue so it had to happen eventually anyway. The battery tray was cut out pretty badly imo. Same deal on the other side. I had my buddy weld in some new metal so when I run the new intercooler piping it'll look nice and clean.
Just a little test fit with new fenders and bumper featuring my little man
Old 07-16-2020, 08:29 PM   #4
Avayo
My plans for this car are a full interior, fun street car that could also handle a track day here and there. I decided to ditch the sr and go for a jz. I ended up selling the turbo kit and engine for what I paid for the entire car! Headed down to Jersey to an engine importer and came home with this anchor.
I got the engine on the stand and started to tear it down. I replaced damn near everything maintenance related and tried cleanin it up best I could.
Cams pulled to replace the valve stem seals
Prepped for paint
Powder coated upper oil pan
New oil pick up tube and lower oil pan
Real Street billet timing tensioner bracket vs stock cast bracket prone to breaking
New water/oil pump, re-built and cerakoted cam gears
Powder coated valve covers to match the catch can
Radium press in AN fittings
Old 07-17-2020, 07:08 AM   #5
Avayo
Decided on running a tucked radiator instead of notching the support. Had to do a little cutting for clearance but welded in some new plates to cap it off.
Touge Factory catch can looking right at home in the corner
Would've loved running a v160 but the prices on those things are hard to wrap my head around. So I went with the cd paired with the serialnine conversion kit. I've heard great things about this kit so hopefully does the job. Also went with some Freed engineering/Cusco mount kit to swap it in.
Old 07-17-2020, 08:19 AM   #6
Avayo
Picked up a set of Z32 aluminum calipers and e-brake assembly. I was going to just rattle can them a gloss black but decided against that and had them sent off to be powder coated. I'm really glad I did because they came out awesome.
Couldn't help myself and pulled out a wheel to see what they would look like. Going to be running 17x9 +22 square set up on this car.
Old 07-17-2020, 09:21 AM   #7
JIMB0
JIMB0's Avatar
Trader Rating: (22)
JIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really nice
Feedback Score: 22 reviews
cant beat Kouki and TE's!
@JYW0RLD
JIMB0 is offline   Reply With Quote
Old 07-17-2020, 09:35 AM   #8
S14rebuild
Wow, great parts on an exciting build
Old 07-18-2020, 04:42 PM   #9
Avayo
Agreed! Timeless combo. Looking forward to seein yours back from paint
Thank you man! Got a long road ahead but should be pretty awesome once its done
Old 07-20-2020, 12:50 PM   #10
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
Now this is nice.
Dudes voice makes my arm feel punchy.
da_crew10 is offline   Reply With Quote
Old 07-21-2020, 12:51 PM   #11
Avayo
Originally Posted by da_crew10 View Post
Now this is nice.
Thanks bro! I'm trying the "do it right the first time method" lol
Like I said before, interior will be left in tact. Picked up some zeta 3's even though I kind've wish I just went with some oem 180sx seats.
Obviously need a Nardi classic to continue that cookie cutter theme
And a cross bar for the extra scene points...But seriously hoping this adds some rigidity to the car since I'm not running some fancy cage
Old 07-21-2020, 01:57 PM   #12
Avayo
Since the car came with the Silvia front I had to pick up some pop up headlights. I got a set for cheap but of course they're old and seen better days so I sourced some new hardware. Kind've crazy you can still get new parts for this car, thanks to the boys at nissanparts.
New vs old
Old 09-21-2020, 01:25 PM   #13
Avayo
Came so close to giving up on this car and parting it out for something else but decided I should just stick with it. Luckily I've got some good friends that talked me out of it. Plan is to place the engine in there next so I can see how much room I need to make for the CD.
Also sourced the rest of the exterior bits for the car.
Old 09-22-2020, 03:16 AM   #14
Fuglychuki91
Fuglychuki91 is on a distinguished road
Nice update man!
Fuglychuki91 is offline   Reply With Quote
Old 09-24-2020, 10:04 AM   #15
da_crew10
da_crew10's Avatar
Originally Posted by avayo View Post
cookie cutter theme
paint it red
Old 09-25-2020, 04:54 PM   #16
Avayo
Originally Posted by Fuglychuki91 View Post
Nice update man!
Thanks man, hopefully more to come soon
paint it red
I know right, it?s on my list lol Been done so many times but it?s so damn good.
Old 10-22-2020, 12:52 PM   #17
Avayo
Had some time today to finally drop the engine in for a test fit. Now I can get a better idea on where I need to clear the trans tunnel. Overall super happy with how it sits in there. Dying to order more parts and get it going. Debating on selling the Subaru to fund this car. It would really help push it over the finish line.
Old 01-03-2021, 07:56 AM   #18
Avayo
Little end of the year update. Decided to list up the sti for sale a few weeks ago to free up some space/money for the 240. Luckily lined up a buyer in the first 24 hours it was listed and got my full asking price.
I started looking around for someone willing to tackle the paint and body work on the 240. I was kind've surprised a couple shops I talked to weren't interested in any restoration work. I guess it worked out because while waiting to hear back from a few different options I spotted a MK4 Supra for sale.
I've wanted one of these cars for roughly 6 years now. Right around the same time the price on them skyrocketed. I was getting married, having a couple kids so it just didn't work out for me then. Then I saw this one owner, all original car pop up and knew it was now or never. It's a usdm n/a auto car with only 51k miles. I still can't believe I was able to find one un molested and not missing anything. The car feels like an absolute time capsule.
It needs a little paintless dent removal and a good detail but overall for its age it's in excellent condition. For now I'm just going to enjoy it as is while I acquire the parts I want for it. Will be pretty basic, 97-98 headlights/taillights, front lip yada yada. And then eventually GTE/6 speed swap.
For now the 240 will go on the back burner unfortunately. But I still would like to keep it for my son or daughter. Hoping at least one of them will be a car nut like me.
Happy New Year guys!
Old 01-04-2021, 05:29 PM   #19
Reece
Reece's Avatar
Reece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymore
in for supra posting
Originally Posted by Almighty So View Post
Don’t price bash me.
Reece is offline   Reply With Quote
Old 01-04-2021, 09:44 PM   #20
-kenny-
-kenny- is an unknown quantity at this point
Wow this is gonna be a nice build.
Bonus point for Supra
-kenny- is offline   Reply With Quote
Old 01-05-2021, 01:02 AM   #21
S13project
S13project's Avatar
S13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of light
Digging the attention tho the little things. In for more
S13project is offline   Reply With Quote
Old 01-05-2021, 02:53 PM   #22
Avayo
Appreciate the kind words fellas. Hopefully more to come soon!
Old 01-06-2021, 09:15 AM   #23
k00laid83
k00laid83's Avatar
k00laid83 is an unknown quantity at this point
I want a Supra so bad. That's one of my dream cars as well. Great Find!
Facebook or Instagram:@tightfitfab
Email: [email protected]
Check Us Out At: www.tightfitfab.com
k00laid83 is offline   Reply With Quote
Old 01-06-2021, 09:24 AM   #24
da_crew10
da_crew10's Avatar
In b4 partout!
Old 04-05-2021, 07:44 PM   #25
Avayo
I don't have too much to update but I did finally get my turbo kit which was a big hurdle. There's so many options out there it took awhile to decide on what would suit my needs the best. I ended up with a g30-900 with a turbo smart 50 mill waste gate.
Also the parts pile for the supra is starting to add up. As of now my plans are to continue the 240 build with my vvti engine and CD trans. The supra came from the factory with a TT auto diff (A02D for my supra guys) which is a 3.7 LSD. Turns out that pairs pretty well with the Grannas T56 kit. So at some point I'll use that for my trans and then build the GE with a GTE head, PHR turbo kit yada yada. That'll be a project for the future because to be honest, it's just not in my budget right now.
But I did want to start sourcing parts while I can get them bnib
Then there's this goofy ass Camry wheel the 93-97 has for god knows what reason
So I sourced a nice three spoke for it
That's really it for now. Next up for the 240 are clutch and injectors, then ill be able to get the engine and trans in for my buddy to work his magic on the welder.
Old 04-07-2021, 08:33 AM   #26
PoorMans180SX
PoorMans180SX's Avatar
Great looking stuff you have going here man. I like the idea of notching the lower rad support like that.
Old 04-07-2021, 10:11 AM   #27
hiimelvin
hiimelvin is an unknown quantity at this point
Beautiful builds so far. Great attention to detail and really tasteful mods. Good call on that Supra steering wheel.
hiimelvin is offline   Reply With Quote
Old 04-07-2021, 12:22 PM   #28
Avayo
Thank you man, I appreciate that. Yeah I kind?ve figured if I had to cut and remove anything I?d add some back. Plus looks a little cleaner once it?s painted
Thank you man! Yeah that old wheel is terrible, I don?t know what they were thinking haha
Old 08-15-2021, 07:40 AM   #29
Avayo
Nothing too crazy to update but I have gotten a few things done on both cars.
Engine dropped in temporarily
Found this sound deadening on Amazon. Had really good reviews and way cheaper than Dynamat. Figured why not, couldn't hurt anything. Started on the firewall and covered basically everywhere.
Dash support looked like it came from the bottom of the ocean so gave it a little elbow grease. Hit it with some sand paper, primered, and some rattle can paint.
A new carpet that needed to be trimmed to fit. Wasn't too bad getting it in there, just need to take your time.
Obligatory supra pic
Front bumper picked up from paint ready to go on with the updated lights. I'm currently finishing that swap. Needed to splice some wires for the new turn signals.
Also got around to installing the new wheel.
Old
New
Old 10-05-2021, 11:49 AM   #30
Thursday7
Thursday7's Avatar
Both of these have me drooling. Great stuff Scott!
