Old 02-18-2015, 09:54 PM   #1
TwoForties
TwoForties's Avatar
TwoForties is an unknown quantity at this point
Unhappy Ka24de Misfire
Hey guys, I bought a 91 240sx coupe the other day with a stock ka24de(besides catback) and on the drive home it seemed like it had some problems; lacking power, idle shakes, etc... I have been starting it multiple times, but have not driven it since then. The car failed to start once, but usually starts right up. I unplugged the spark plug wires one at a time to find out that cylinder #1 wasn't firing. I switched the spark plugs around to find out that they weren't the issue. I then tested the spark plug wire for conductivity, which gave good results. I ohm tested the fuel injector connectors and they were even across the rail. The MAF sensor wire connector seemed loose. And it seemed to be missing a metal piece into which I think the MAF signal prong connects to. I'm not sure if that is meant to be or not. I have done some research to get to where i'm at now, but I don't know what else to check and I could use some guidance to help me find the problem.
TwoForties is offline   Reply With Quote
Old 02-19-2015, 09:30 PM   #2
jza80king
jza80king is an unknown quantity at this point
I would suggest pulling any codes first. That might lead you to what is causing your issue.
jza80king is offline   Reply With Quote
Old 02-22-2015, 10:23 PM   #3
TwoForties
TwoForties's Avatar
The fuel injector was bad. Switch them around and the misfire came along.
ka24de, misfire
