Old 12-15-2014, 10:32 AM   #1
overdueBlaSiaN
overdueBlaSiaN is an unknown quantity at this point
SR overboosting but no power. HELP
my boost continues to build as I go higher in RPMs
even with this overboosting issue the car still pulls sluggish
I've changed the wastegate actuator and didn't help much
any ideas what could be my problem?
overdueBlaSiaN is offline   Reply With Quote
Old 12-15-2014, 10:51 AM   #2
bmxer882x
bmxer882x is an unknown quantity at this point
Got a wideband? U could be going super rich or lean. Either would cause a huge loss in power.
bmxer882x is offline   Reply With Quote
Old 12-15-2014, 11:15 AM   #3
overdueBlaSiaN
Thanks for the reply
No wideband
Old 12-15-2014, 11:18 AM   #4
overdueBlaSiaN
My mods:
Walbro 255 fuel pump
HKS BOV
HKS wastegate actuator
Godspeed exhaust manifold
3inch circuit sports turbo elbow
Aluminum CX radiator
Old 12-15-2014, 05:46 PM   #5
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
What is considered "overboosting" for you?
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd
silverarrow27 is offline   Reply With Quote
Old 12-15-2014, 06:41 PM   #6
Kingtal0n
Kingtal0n's Avatar
Clogged cat? restriction somewhere it sounds like.
We need numbers. how much boost.
My immediate instruction to you is, disconnect the actuator so the engine doesn't boost at all anymore. Drive it like that for a while, see how it feels. If it still feels sluggish and slower than it should be, you have narrowed down your problem some. Do a boost leak check is next on the list.
Old 12-15-2014, 07:18 PM   #7
overdueBlaSiaN
Boost used to stop at 7psi but just continues to climb
Update:
I drove the car to work today
Car didn't feel sluggish. Problem went away
So now my only problem is the overboosting issue
When you say unplug disconnect the actuator, do you mean take it out ? Or just unplug the vacuum line?
Also I don't have a cat
Old 12-15-2014, 07:41 PM   #8
bataangpinoy
bataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymore
did you inspect the source line for the wastegate?
Originally Posted by GTR-Garage
Handling, power and style must be in harmony.
bataangpinoy is offline   Reply With Quote
Old 12-15-2014, 08:05 PM   #9
frostie00
frostie00 is an unknown quantity at this point
Do you have a manual boost controller?
frostie00 is offline   Reply With Quote
Old 12-15-2014, 11:12 PM   #10
overdueBlaSiaN
No I haven't but I know my line has a slight bend due to my cold pipe and Hotpipe being a tight fit. I'll try to fix that right now
Old 12-15-2014, 11:13 PM   #11
overdueBlaSiaN
Yes I do
It's tee'd off to cold pipe and wastegate
Old 12-16-2014, 12:13 AM   #12
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
Originally Posted by overdueBlaSiaN View Post
Yes I do
Lol, well that could be your issue right there.
You mentioned the turbo has HKS adjustable "actuator" correct?
This is what you do!
-take manual boost controller off
-run your vaccum hose from the actuator to the hotpipe
- check boost after this!
-if still over boost to like 13psi or so, then adjust the rod on the actuator a couple turns at a time to lower boost.
BTW just a heads up, those manual boost controllers are garbage.
Dboyizmlg is offline   Reply With Quote
Old 12-16-2014, 11:36 AM   #13
overdueBlaSiaN
My Hotpipe doesn't have a nipple to put a vacuum line on. Can I just use cold pipe?
I still have the stock SMIC but aftermarket cold pipe that has a nipple
Old 12-16-2014, 12:08 PM   #14
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
^ yes you can still use cold pipe.
But.... It's recommended that the shorter the distance the better.
Either hotpipe, or compressor housing.
You should be ok with cold pipe for now though, later in the future you should get a quick tap fitting and drill it in the coupler, or nipple fitting on the hotpipe.
Old 12-16-2014, 12:11 PM   #15
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
I have my quick tap fitting on the turbo outlet coupler.
Bought it for about $10.00 from FRSPORT.com
Old 12-16-2014, 03:28 PM   #16
overdueBlaSiaN
Ok so I did what you said and now my boost is back to 7psi
Thanks you so much !!
Old 12-17-2014, 07:52 PM   #17
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Glad it worked out.
Old 12-17-2014, 09:23 PM   #18
Fuego
Fuego is an unknown quantity at this point
Set it to 11 and let it breathe like Nissan wanted it to.
Fuego is offline   Reply With Quote
240, s13, sr20, sr20det
