05-19-2019, 12:17 PM | #1 |
No spark to plugs cables
No spark to spark plugs and cables recently sawped my ka dual cam from my 93 vert to a 89 coupe spliced the engine harness f1 plug was damaged couldn't decide pin it , spliced lower harrnes to fuse box , the battery cables read continuity I traced it to the 75amp alt relay/fuse idk what it is, if I pulled it out stops so then I traced it back inside to a blue plug above the fuse box on the driver side there's to plugs here a black and blue that connect to a box like connector, fuel pump is priming I'm getting power to coil dizzy getting power injectors as well , some one help pls ?!
05-20-2019, 07:08 PM | #3 |
Distributor seems to be good pulled It out rotated it you can hear injectors clicking , gana clean up the contacts on the cap rn, I noticed the ignitor chip getting really hot tho is I possible could be the coil was thinking of buying a msd blaster coil ?
