Old 11-17-2020, 11:51 AM   #1
Sterlingaidenk
Sterlingaidenk is an unknown quantity at this point
s14 Iat sensor stuck at same temperature.
My iat is stuck at -40 degrees, it is a two wire iat, with a grey plug. cel for the iat has been on for the past 2 yrs and emissions are coming up soon, cant pass unless it's fixed. Brand new engine wiring harness, 5 point ground kit. Swapped out ECU's and problem continues, currently a stock a/t ka24de s14. Also has egr delete, not sure if its linked up to anything else in a circuit some way(unused plugs).Tried different iat's from new, to some from the junkyard and all of them are the same way. What am I missing?
Sterlingaidenk is offline   Reply With Quote
Old 11-17-2020, 12:09 PM   #2
S14rebuild
How u gonna pass emissions with egr deleted?
Old 11-17-2020, 12:19 PM   #3
Sterlingaidenk
I hid all the extra wiring. The car runs very clean too, it's just the cel that makes me not pass.
Old 11-17-2020, 12:42 PM   #4
S14rebuild
Cel will come on for no egr aswell...
But id pull-out the multimeter and start proben the harness... voltage in and voltage out
Old 11-22-2020, 10:50 AM   #5
Sterlingaidenk
I have tested for a voltage and have no voltage coming from the harness connector, I tested the other terminal on the harness connector for continuity and that was a success. So now it's just figuring out my voltage problem.
