04-29-2020, 05:23 AM | #1 |
Water feed to turbo sr20de
Posted about this once but still need answers.
I am running a s13 sr20de(+t) and need to run water lines to my turbo. Where can I get feed from. It's a de so doesn't have stock locations unless you can drill and tap them. Let me know. Return should be easy enough just tap the water neck but I'm lost on feed. Any help appreciated Thank you |
04-30-2020, 09:30 PM | #3 |
If that location goes through to the water system then that works fine. Probably not the coolest water possible but if it's what the stock det uses must be fine. Got any idea what size the thread and pitch is?
