Old 06-15-2011, 06:13 PM   #1
Gold Zenki
Gold Zenki is an unknown quantity at this point
KA ka-t cast log mani top/bottom mount/w spacer for dual cam
im selling a cast iron cast iron turbo manifold t3 / t4 base has pattern for both sizes for the ka24de. turbo can sit top mount or bottom mount and turbo position is between cylinder 2 and 3. includes a cast iron beveled (angled)spacer which will also work as an adapter from t3- t4 or vise versa and gives you a better placement of the turbo if needed. manifold is cast iron. yes its heavy, and of course very thick which make this a strong manifold. has 35/ 38mm wastegate port for those that run external wastegates if not needed it can be blocked off. i test fitted in on a KA i have on a stand once or twice other than that its brand new. any questions text/call me 3o5-984-9o17 no calls later that midnight.or simply pm or reply.
Gold Zenki is offline   Reply With Quote
cast turbo manifold, ka-t, ka24det, kade-t, log manifold
