Old 10-24-2020, 01:40 AM   #1
Ugly SR
Ugly SR has a spectacular aura aboutUgly SR has a spectacular aura aboutUgly SR has a spectacular aura aboutUgly SR has a spectacular aura aboutUgly SR has a spectacular aura aboutUgly SR has a spectacular aura about
Wheel bearing help (identify)
I bought a "s14" 5 lug swap compete on cl for my s13. 300zx brakes, the whole lot... or at least I thought so. Pressed in s14 lower ball joints into the 13 arms and have been enjoying the car all summer. Recently the wheel bearing started growling, so I ordered new s14 timkens and.. they don't fit... I've been searching, and cannot find, for the life of me, what bearing has a center bore of 34mm... I get random "200sx s14x-15" searches of this size (non US), but cannot find why most sites say the s14 is 1.18xxx" when my spindle measures 1.33xx or 34mm.. ideas? Thanks in advance.
89' s13
88' quest
Ugly SR is offline   Reply With Quote
Old 10-24-2020, 01:03 PM   #2
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
are you sure you received s14 bearings? did you measure the ID?
zombiewolf513 is offline   Reply With Quote
Old 10-24-2020, 01:21 PM   #3
Ugly SR
Yes, triple checked part numbers and ID, they are too small.
89' s13
88' quest
Old 10-24-2020, 05:41 PM   #4
S14rebuild
Maybe j30 hubs? Seen this before
Old 10-24-2020, 05:48 PM   #5
zombiewolf513
...well what was the measurement???
Old 10-24-2020, 09:51 PM   #6
Ugly SR
Did you read the first post?
I checked those part numbers also. Still the wrong size bearing.
Called the dealership today with no help from the excellent parts department. Amazingly enough, the "nissan tech" doesn't have access to specs on a bearing.. amazing.
At this point I don't care if have to buy new hubs with bearings, just need a clear answer. I have places I'll call on Monday but was hoping for answer sooner.
89' s13
88' quest
Old 10-24-2020, 10:11 PM   #7
zombiewolf513
good luck.
Old 10-25-2020, 01:15 PM   #8
Agamemnon
Agamemnon's Avatar
S14 front hub bearings are not replaceable. They are a sealed piece that will damage the hub if removed. The S14 timkin bearings being sold are S13s which have a smaller spindle which is why they're too small for your spindle. You'll need to get 2 new hubs.
Old 10-25-2020, 01:33 PM   #9
S14rebuild
^WELL there u go.. good info to have..sure this will be looked at again
Old 10-25-2020, 04:57 PM   #10
NukeKS14
NukeKS14's Avatar
NukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really nice
s14
Second this. I just redid mine this past spring;
https://www.z1motorsports.com/front-...ly-p-9473.html
That's where I got mine.
Pic of me failing at life on mine (yeah I got Timken bearings from Rock Auto too) before ordering the complete units from Z1. That's the aftermath of trying to press them out with a 12T shop press. Spacer tilted a little bit and the race came back out the top side. Did a check and realized the Timken was too small for the spindle anyway and said screw it.
NukeKS14 is offline   Reply With Quote
Old 10-26-2020, 08:43 AM   #11
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
ALSO, I highly recommend cleaning out the factory grease, even on a brand new hub/bearing, and replace it with something better.
I've been using NEO grease for over a decade, another thing I can blame on dave coleman.
https://motoiq.com/project-silvia-th...gs-like-i-did/
Old 10-26-2020, 11:23 AM   #12
Ugly SR
Thanks for the info guys. I figured as much about the replacement, just as well. I called z1 this morning, unfortunately they dont have them in stock to measure, so we'll see what happens. I will post my findings.
89' s13
88' quest
Old 10-26-2020, 05:42 PM   #13
S14rebuild
Theres a set for sale in marketplace now....fyi
Old 10-27-2020, 12:22 PM   #14
KA24DESOneThree
KA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfection
I've done this with every bearing on every car I've owned since I had a Miata, but I use Redline CV-2 (just because, I don't have anything against NEO and use only NEO diff oil in my diff [again just because]) instead.
Seriously worth it. I haven't run across a single bearing that I'd consider properly lubricated from the factory.
KA24DESOneThree is offline   Reply With Quote
Old 10-27-2020, 02:17 PM   #15
Ugly SR
of course...right after I buy new ones.. lol
yes, I've use redline on my racecar, great stuff.
Thanks for the replies guys. New parts should be here friday.
[IMG][/IMG][IMG][/IMG][IMG][/IMG]
89' s13
88' quest
Old 10-27-2020, 04:18 PM   #16
Agamemnon
Agamemnon's Avatar
Good looking car.
Old 10-28-2020, 03:09 PM   #17
Ugly SR
Good looking car.
Thanks. When its not on jack stands it is.. lol
89' s13
88' quest
