Old 10-26-2019, 02:34 PM   #22891
Presto
Presto's Avatar
Presto is an unknown quantity at this point
Originally Posted by S14rebuild View Post
Hub-quick release-steering wheel
Or
Hub quick release(all in one)-steering wheel
They all have 6 bokt flange would say 99% match right up
Not that complicated
do I HAVE to buy a wheel made for the quick release or not if I already have an aftermarket wheel
Presto is offline   Reply With Quote
Old 10-27-2019, 05:05 PM   #22892
S14rebuild
S14rebuild has much to be proud ofS14rebuild has much to be proud ofS14rebuild has much to be proud ofS14rebuild has much to be proud ofS14rebuild has much to be proud ofS14rebuild has much to be proud ofS14rebuild has much to be proud ofS14rebuild has much to be proud ofS14rebuild has much to be proud ofS14rebuild has much to be proud ofS14rebuild has much to be proud of
There is no wheel that is MADE for a quick release. Just make sure the bolt pattern matches and ur good.
Old 10-29-2019, 07:17 AM   #22893
1illsuspect
1illsuspect's Avatar
1illsuspect is an unknown quantity at this point
Originally Posted by [240sx] View Post
^ I don't think that's what he meant. Reads as 'the thread' was from 2011, not the chassis model year.
THIS! Thank you.
1illsuspect is offline   Reply With Quote
Old 10-29-2019, 07:26 AM   #22894
1illsuspect
No such thing as a 2011 z32....... thats ur issuse
If ur looking for 2011 Z33 they thats a diffrent story...
Lol...The thread was from 2011, not the Z32, and it was a dead end. Basically, Iím seeing cheap dodge Brembo calipers everywhere and looking for brackets to mount them so my s14. Anyone?
Old 10-29-2019, 08:53 AM   #22895
S14rebuild
Just go with ctsv calipers chepest brembo options and use z33 track rotors
Old 10-29-2019, 07:26 PM   #22896
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
Does anyone know where to buy replacement seals for the OEM Nissan S14 Sunroof Visors/Wind Deflectors?
I cant pinpoint what they're technically referred as
Sent from my SM-G950U using Tapatalk
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 10-31-2019, 12:18 AM   #22897
Presto
Presto's Avatar
Sweet thanks
Old 10-31-2019, 12:22 AM   #22898
Presto
Presto's Avatar
Can I plug an sr20 maf straight into a Ka24e ?
Old 10-31-2019, 04:57 AM   #22899
S14rebuild
It will not "plug" directly in. Ull need the pigtail. Wire it up correctly and then it will work.
Old 10-31-2019, 05:44 AM   #22900
Presto
Presto's Avatar
I bought an airbox + maf and seller says maf fits sr20 but also I just plugged it into my Ka24e but maybe it’s a Ka24e maf? (Since sr20 maf wouldn’t plug right into Ka24e)
Old 10-31-2019, 05:47 AM   #22901
S14rebuild
Correct..if it plugs in to a ka24e connect...its a sohc maf.
If it plugs into an sr20 plug its indeed sr20maf.
It will work for an sr20 just needs the connector and proper wiring.
Seems like the seller was very blaahhh on his description of the item
Old 10-31-2019, 09:31 AM   #22902
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
I bought an airbox + maf and seller says maf fits sr20 but also I just plugged it into my Ka24e but maybe itís a Ka24e maf? (Since sr20 maf wouldnít plug right into Ka24e)
KA24e MAF - 3 PIN PLUG, 3 PIN SOCKET
SR20det MAF - 4 PIN PLUG, 4 PIN SOCKET (only 3 pins are used)
The SR20det and KA24e MAFs are interchangeable as long as you have the correct plug wired into the harness. The SR20det plug/socket is 4 pins long, but only has 3 pins. the KA24e plug/socket is 3 pins long and uses all 3 pins.
since you plugged the MAF straight into your wiring harness, you have a KA24e MAF... BUT, the KA24e MAF will work on an SR20det if you wire in the SR20det MAF plug.
make sense?
Bought something from me??? POST A REVIEW HERE!!!
Old 10-31-2019, 11:14 AM   #22903
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
I recently found out that JZX100 tie rod ends fit our tie rods and provide a bit of a bend for better geometry.
Only problem is the castle nut is a bit too tall.
Anybody know the proper size castle nut we can use that will properly fit with the cotter pin in?
ZenkiKid is offline   Reply With Quote
Old 11-01-2019, 12:30 AM   #22904
Presto
Presto's Avatar
Thanks guys that helps a lot
Old 11-01-2019, 05:04 AM   #22905
S14rebuild
Watch the next episode from SAMMIT and maybe youll learn that too
Old 11-01-2019, 08:17 AM   #22906
brndck
brndck's Avatar
Trader Rating: (126)
Feedback Score: 126 reviews
flapper disc will take care of that for you
https://www.harborfreight.com/4-1-2-...isc-67639.html
Old 11-01-2019, 06:58 PM   #22907
Sarjh
Sarjh is an unknown quantity at this point
Anybody ever gotten stock s13 rear knuckles modified ~40mm+ drop? It would seem like a lot of work to do, but I am curious.
Sarjh is offline   Reply With Quote
Old 11-03-2019, 11:37 PM   #22908
Presto
Presto's Avatar
I put a gallon a muriatic acid into my gas tank thatís filled with water this morning and Iím letting it sit until tomorrow morning, I have another gallon of muriatic acid and I was wondering if I should add it or if the 1 gallon will be enough?
Old 11-04-2019, 07:28 AM   #22909
S14rebuild
Add it, if it eats thru the tank..buy another tank and try again..
Old 11-04-2019, 10:14 AM   #22910
brndck
brndck's Avatar
what are you trying to achieve? roll center correction?
yes, its doable, but unless you're a skilled fabricator, the cost is gonna be $$$$ to pay someone else to do it.
imo you'd be better off buying a rear knuckle from PBM or Driftworks
Old 11-05-2019, 07:55 PM   #22911
JacobSamm
JacobSamm has a little shameless behavior in the past
s13 Help Navigating the forum
I am brand new to Zilvia, and actually just made an account. I am currently working on swapping an rb20det into an s13 but I have not been able to find any threads about this swap on the forum. Any guidance/ links to threads about this would be greatly appreciated.
JacobSamm is offline   Reply With Quote
Old 11-05-2019, 08:53 PM   #22912
Presto
Presto's Avatar
How hard is it to unplug the 5th gear sensor on a Ka24e s13?
Also Does it have a 1st gear sensor?
I’m noob sorry
Old 11-05-2019, 08:53 PM   #22913
S14rebuild
Yea...use the search feature on the forum....there is lots and lots of info out there....no one will spoon feed u here. Wrong place.
Oh and welcome
Old 11-06-2019, 09:56 AM   #22914
brndck
brndck's Avatar
https://lmgtfy.com/?q=rb20det+swap+into+s13&s=g
Old 11-07-2019, 09:46 AM   #22915
JrDarknes
JrDarknes's Avatar
JrDarknes is just really niceJrDarknes is just really niceJrDarknes is just really niceJrDarknes is just really niceJrDarknes is just really niceJrDarknes is just really niceJrDarknes is just really niceJrDarknes is just really niceJrDarknes is just really nice
PM me for any help. I noticed youíre in Indiana as well. I did the swap 4 years ago. I can help you with any questions or advice.
Instagram: Nismo_Lk
JrDarknes is offline   Reply With Quote
Old 11-07-2019, 10:21 AM   #22916
duballstar37
duballstar37's Avatar
duballstar37 is on the path to ruinduballstar37 is on the path to ruinduballstar37 is on the path to ruin
I put a gallon a muriatic acid into my gas tank that’s filled with water this morning and I’m letting it sit until tomorrow morning, I have another gallon of muriatic acid and I was wondering if I should add it or if the 1 gallon will be enough?
Edit: Small questions deserve small answers. I only used one gallon of Muriaic acid (hot water first) and I didn't let it sit overnight, just kept it active by kinetic energy. You need to seal the metal before using the tank again. The POR15 kit with "Marine Clean" prior works great.
P.A.T.T.
duballstar37 is offline   Reply With Quote
Old 11-13-2019, 07:52 PM   #22917
mau5trap
mau5trap's Avatar
mau5trap is an unknown quantity at this point
Send a message via AIM to mau5trap
So, what's the verdict on 240sxconversions wheel hubs?
mau5trap is offline   Reply With Quote
Old 11-21-2019, 09:29 PM   #22918
mint40
mint40 is an unknown quantity at this point
So I recently bought a electronic fan controller from mishimoto. I have for the most part everything figured out. My question is the yellow wire requires 12v ignition. Is there any where in the bay I could tap into for that? It already has a constant power wire. Also the green wire it says hook up to the positive on my ac compressor. (Ka24de ac on a sr) does that mean the plug that goes straight into the compressor and just take from the positive on that or? Could that also mean the old fan wiring harness on the chassis?
“ 14. a/C override - using the blue wire tap provided, attach the green wire to the positive lead on the air conditioning compressor. “
mint40 is offline   Reply With Quote
Old 11-29-2019, 10:15 PM   #22919
Presto
Presto's Avatar
nevermind I researched
Old 12-04-2019, 05:22 PM   #22920
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
Originally Posted by mint40 View Post
So I recently bought a electronic fan controller from mishimoto. I have for the most part everything figured out. My question is the yellow wire requires 12v ignition. Is there any where in the bay I could tap into for that? It already has a constant power wire. Also the green wire it says hook up to the positive on my ac compressor. (Ka24de ac on a sr) does that mean the plug that goes straight into the compressor and just take from the positive on that or? Could that also mean the old fan wiring harness on the chassis? “ 14. a/C override - using the blue wire tap provided, attach the green wire to the positive lead on the air conditioning compressor. “
Basically it's asking to tap the A/C compressor ON wire, so that when the A/C compressor gets power to turn on, the fans ALSO get power to turn on.
--So whether you get that directly from the compressor or get it from the original harness wire, the outcome will be the same. FAN ON when COMP ON.
If you cannot find a diagram of this, you can probe the compressor connector to see what wire gets B+ (12v) when you command A/C on. (press the AC button)
As for the 12v ignition ON source, you could essentially get that from anything in the fuse box that gets power when key on.
But I'm sure you've already figured this all out since it's been over 10 days.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Copyright © 1998 - 2019, Zilvia.netô
