Old 06-25-2019, 03:09 PM   #1
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
SR20DET vacuum line woes
Hey guys I need some help. I have a blacktop Sr20det that I am swapping into my Datsun pickup. I am currently dealing with the vacuum/boost lines. On the throttle body, there are two upper nipples. I have the left one going to the FPR and tee’d with my boost gauge. The right one goes to my BoV. It seems I only have vacuum at those ports. My bov will stay wide open during idle and when I rev it, it closes. My boost gauge will only read in vacuum and never see boost. What can be causing the vacuum only issue? Thanks
lexus baby
5t341tH is offline   Reply With Quote
Old 06-26-2019, 08:11 AM   #2
jedi03
are you looking for boost with no load? it wont pickup much while you are sitting there...the engine is in vacuum when idling and your BOV is designed to open when off throttle...sounds like your spring may be to soft if its opening just sitting there tho as its supposed to open whenever you let off the gas...what boost are you getting when you have a load and do you have a way to test the guage as i have seen many fail over the years...
Old 06-26-2019, 04:00 PM   #3
5t341tH
5t341tH's Avatar
This is a new swap so all parts I have are new. At idle, my tail bov is wide open. Also the same when I bolt on the Hks. I’ve driven around and it still shows no boost. I will only see vacuum and 0psi. My gauge is innovate motor sports scg1. I believe it used a map sensor. I have that tee’d into the fpr line
lexus baby
Old 06-27-2019, 08:22 AM   #4
jedi03
http://www.frozenboost.com/bov-a-bov.html what are your compression numbers? secondly are you hearing the turbo spool while you accelerate or does it just barely function?
Old 06-27-2019, 02:45 PM   #5
TheRealSy90
TheRealSy90's Avatar
There are vacuum only ports and vacuum/boost ports on the sr20 throttle body and intake manifold.
Such a good signature.
Old 06-29-2019, 05:30 PM   #6
5t341tH
5t341tH's Avatar
How can I tell if my turbo is spooling? This is a brand new s15 t28. When I first started it up after my swap, I could hear it spool. But now I don’t hear anything. What should I check?
lexus baby
Old 07-01-2019, 12:07 AM   #7
Kingtal0n
Kingtal0n's Avatar
1. pressure test the plumbing from the compressor cover through the engine
2. get a vacuum/boost gauge
Old 07-02-2019, 03:46 PM   #8
5t341tH
5t341tH's Avatar
Nvm it is working. Just strange that during low speed driving in the parking lot, it never shows boost. Only when I drove it on the streets did I hit boost. 7psi is the norm with just the wastegate correct? I still question why my Tial BoV stays wide open when idling? It causes the engine to idle like crap and want to die.
lexus baby
