Old 01-13-2020, 09:33 AM   #1
mgbsr20det
mgbsr20det is an unknown quantity at this point
Can I wire speed sensor direct to ecu?
Hi I have a s13 SR20det in my MGB roadster , I want to setup the nistune launch control but need the speed sensor to talk to the ecu . Is this possible ? I have done a little research and it seems the speed speed sensor sends signal to the cluster and the cluster sends signal to the ecu. Is there a way to wire it straight from the speed sensor to the ecu as I have a gps speedo and dont have a s13 cluster ? Thanks in advance if you can help.
mgbsr20det is offline   Reply With Quote
