Old 11-22-2020, 03:13 AM   #1
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
Megasquirt/Axles/Injectors/FLCA/Coils/Aerocatch/BBK/Bee*r/SR trans.. just come look
Hey everyone, I'm condensing all my shit to a single thread. Any questions, ask away!
Two sets of 3x2 axles
Neither sets have torn boots. One set is from my prev setup (went 350z axles) and the other came off a 180sx.
80$ each set
OEM SR20 coils
I bought them brand new back in 2015. I put about 10k miles on them before I lost my chassis. They've been sitting in a box since then. I'm going standalone with upgraded coils and don't have any need for them.
180$
Wiring specialties coil pack sub-harness
same condition as coils
30$
S13 VSS
Came from an SR trans
150$
Aero catch locking hood pins
It will come with both keys, new hardware, and new pins. I went with the "carbon look" ones like the ricer I am. I literally just took the carbon latches from the new kit I bought and reused all my hardware. So the hardware bag is unopened and you have the stencil from the packaging. Nismo decals for extra coolness. [emoji1787]
80$
Nismo shift pattern emblem (5 speed)
I went cd009, so obviously that doesn't work anymore for me.
5$
Nismo shorty clutch line
This was from when I had my SR trans
40$
Togue Factory S14 silver valve cover nuts/washers
I wanted black hardware instead [emoji2371]
SOLD
SOHC MAF
Works perfectly, it's pinned for use on an SR
40$
DIF Z32 rear conversion lines
Brand new
40$
Philips daylight 9 DRL kit
These are quality drls that you will actually see in the daytime. I was going to use them, but I bought 78 works headlights.
70$
No name electric fans 14/12 inch
40$ 12
60$ 14
Tein hard outer tie rods (M14)
Brand new
SOLD
Mishimoto baffled oil catch can
Needed to use a different style of can for my car
100$
Battery cut off switch
10$
MS2PNP SR20
I never personally used it (just powered it up to communicate to it). I want to get a different standalone. Comes with IAT/bung, CAS disc, and optional 26 pin input harness (NIB).
600$
P2M 550cc injectors. I used these along with a rom ECU I had. I never had any issues with them, I think I put around 8k miles on them. They're still in my fuel rail.
200$
Everything below this was from one car. The SR lost is main bearings, and these are all being sold off it. Everything is in working order.
N60 MAF
80$
E5 ECU.
ROM tuned for N60/ 370cc injectors/ T28
180$
370cc injectors
One of the injectors has an epoxy repair on the top. The side of it cracked off being removed from the rail. They can be installed and function perfectly.
100$
SR Trans- You will need to swap all your sensors and shifter over. The front cover has been resealed. SOLD
Nismo fuel rail adapter- Went top feed SOLD
Authentic Bee R rev limiter- Went standalone and no longer need. SOLD
Tomei type s FPR- nothing wrong with it, just want to utilize Radium hardware. Comes with fittings shown. SOLD
Agency power clutch line- I made a custom hardline and don't need it. SOLD
Gktech SR water neck adapter- Package opened and that's it. I ended up not needing it. SOLD
Pineapple subframe tilt bushings- For the S13 guys, control your anti squat with these guys. I've heavily modified my subframe, and don't need them. SOLD
Unique auto creations s13 wiper motor cover- I have shakitto shock tower braces and can't use it anymore. SOLD
Deatschwerks 370cc injectors- Purchased new in 2015, and they have about 10k miles on them before I went to 550cc. SOLD
CTSV first gen 4 piston (loaded)
Z1 sprinkle slotted two piece Z33 track rotors
Stop tech street performance pads
ZERO MILES on all parts. The calipers are shaved for the ctsv brake swap.com brackets. I will not be selling my brackets as I had modified them (heavily) for my GK tech knuckles (they're gone). All you need for the fronts are brackets of your choosing (ctsvbrakeswap or G2 carbon), and 300zx conversion lines of you don't already have them.
450$ for rotors SOLD calipers
Techno toy tuning fully adjustable S13 FLCA.- Planned on using these, but I'm a GK tech whore and went all out when they did their sale. They've never been driven on, and I put dmax dust boots on the heims. All the other arms in the picture are sold already. SOLD
ER Spec magnaflow high flow cat It's been installed, but never had exhaust ran through it. I want to go with a different direction for a cat. SOLD
S13 subframe braces, coated in truck bed liner SOLD
RSR D1 bushing Kit SOLD
mr.nismo. is offline   Reply With Quote
Old 11-22-2020, 08:39 AM   #2
sash357
sash357 is an unknown quantity at this point
Is the brake setup just the front?
sash357 is offline   Reply With Quote
Old 11-22-2020, 12:09 PM   #3
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Yeah. I originally paired Z32 rears with them, but they're sold
Sent from my SM-N986U using Tapatalk
Old 11-28-2020, 01:07 AM   #4
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Added a couple things and pics
Old 12-14-2020, 08:25 PM   #5
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Added catch can/bump
Sent from my Note 20 Ultra using Tapatalk
Old 12-15-2020, 08:32 AM   #6
TheRealSy90
TheRealSy90's Avatar
Still have the EAC Wiper motor cover?
Such a good signature.
Old 12-15-2020, 08:27 PM   #7
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
I don't, sorry. Was waiting on payment before updating the thread.
Old 12-16-2020, 05:39 AM   #8
mr.32
mr.32 is an unknown quantity at this point
Would you ship the brake kit?
mr.32 is offline   Reply With Quote
Old 12-16-2020, 09:57 AM   #9
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Yes, the cheapest way to do so is two large flat rate boxes
Old 12-22-2020, 02:26 PM   #10
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Back upppp
Old 01-03-2021, 02:28 AM   #11
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Bump, added high flow cat
Old 01-09-2021, 12:30 PM   #12
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Bump, as I'll be in the la area tomorrow if people want to meet up for any of this
Old 01-18-2021, 02:08 AM   #13
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Lot more shit added
Old 01-26-2021, 08:53 PM   #14
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Back up
Old 02-02-2021, 10:07 AM   #15
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Added more things
Old 02-13-2021, 09:50 AM   #16
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Added more stuff again lol
Old 02-13-2021, 04:33 PM   #17
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
Was looking for a tomei fuel pressure
Might be interested
Also maybe the CAT
I?ll let you know
andisan is offline   Reply With Quote
Old 02-13-2021, 04:44 PM   #18
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Might be interested
Also maybe the CAT
I?ll let you know
Sounds good.
Old 03-01-2021, 12:12 PM   #19
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Back uppp
Old 03-14-2021, 09:53 PM   #20
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
T3 arms sold!
Old 03-26-2021, 09:20 PM   #21
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Back up...
Old 04-12-2021, 06:07 AM   #22
adictd2b00st
adictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to behold
Send a message via AIM to adictd2b00st
$30 shipped for that coil pack sub harness?
adictd2b00st is offline   Reply With Quote
Old 04-13-2021, 09:54 AM   #23
DRIFTER-M
DRIFTER-M's Avatar
DRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of light
Send a message via AIM to DRIFTER-M
Maybe I missed it, but the RSR bushings are for what car? Thanks
I Love Drifting Thread > Drifting is Stupid thread
DRIFTER-M is offline   Reply With Quote
Old 04-13-2021, 11:27 AM   #24
S14_king
S14_king is an unknown quantity at this point
Do you still have the calipers?
S14_king is offline   Reply With Quote
Old 04-13-2021, 12:08 PM   #25
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Yessir
Old 04-13-2021, 12:42 PM   #26
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
For an S13, sorry! That's my fault
Old 04-13-2021, 03:24 PM   #27
S14_king
Originally Posted by mr.nismo. View Post
Yessir
How $$ to be shipped to 94080
Old 04-18-2021, 12:36 AM   #28
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
FPR, Bee R, and calipers sold!
Old 04-19-2021, 09:05 PM   #29
DRIFTER-M
DRIFTER-M's Avatar
Could you do $100 shipped for the RS*R bushing set? PM me if that's ok. Thanks!
Old 04-20-2021, 12:14 PM   #30
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Bushing kit sold!
