Old 02-20-2019, 11:12 AM   #1
Brandon240sx
Brandon240sx's Avatar
Brandon240sx has made poor choicesBrandon240sx has made poor choicesBrandon240sx has made poor choicesBrandon240sx has made poor choicesBrandon240sx has made poor choicesBrandon240sx has made poor choicesBrandon240sx has made poor choices
Impossible to find bolt size thread
Does anyone know the size of the rocker arm bolts and the bolts for the camshaft hold down? My bolts seemed to have grown legs and walked away. I’ve searched all over, high and low and cannot find a thing. Searched numerous forums, searched all over google and nothing. Only thing I was able to find is a Nissan part number for the replacement rocker arm bolts (1305840F10)
Brandon240sx is offline   Reply With Quote
Old 02-20-2019, 11:13 AM   #2
Brandon240sx
This is on a KA btw, forgot that piece of important info lol
Old 02-22-2019, 10:09 AM   #3
foreverdeath
foreverdeath's Avatar
foreverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the rough
I would assume m6x1.0 ~30mm. why not hit up a junkyard and steal on out of a pre 02 altima or pre 04 frontier?
foreverdeath is offline   Reply With Quote
Old 02-22-2019, 11:37 AM   #4
Krusty_s13
Krusty_s13's Avatar
Krusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud of
TYPICALLY, if a 10MM socket removes it, its a M6 bolt. Nissan religiously uses a 1.0 pitch.
I would compare it to what foreverdeath said, seems like it would be the right length.
M6 x 1.0 x 30MM
Krusty_s13 is offline   Reply With Quote
Old 02-22-2019, 01:17 PM   #5
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
find some spare bolts you have laying around and try to thread them in. once you find the right one, measure it with a thread gauge to get the pitch. you can then run it though a die to see the shank dia (or take it to the hardware store with you and run it through their sizing guides).
as for the shank length, take your cap, put it on the cam, use the tail/end of a micrometer and determine the overall length. if its, say, 30mm, use a 25mm shank bolt.
if you dont have these tools. buy them. in the meantime, take your head to a local hardware store and try to thread some bolts in. most places are pretty cool about it if you arent dicking up their hardware.
jumpman2334 is offline   Reply With Quote
