Old 01-04-2018, 11:03 PM   #1
Jayhipter
Jayhipter is an unknown quantity at this point
No spark, no fuel after rebuilding head
I searched forums with tags and keywords from other people problems to get help for days but none helped me out
So
I need your help guys, so i rebuild the ka24de head, had it machined. Slapped it back on the car. Car ran like a beast before no CEL no problems . Rebuild it cause it needed valve seals so i figured while i gotta take the valves and springs out, might as well put new springs guides, valves in
Long story short...
I slapped it back on the car... no spark, or fuel
My compression went up from 160 cold test to 181 cold test steady in each cylinder after the rebuild cold start, tested in 27 degree snow weather.
I know minimum is at 150 so im at 181
However, i have no spark or fuel... i do not hear the fuel pump priming. I tested voltage on the sending unit, i tested the spark plugs with my tester, the light doesnt blink so i have no spark.. i noticed my engine light in the car doesn't even come on when i turn the key to on position... i feel like its a ground issue somewhere cause everything is new since i got it 4 months ago and put new parts on last week which ran great before the headgasket swap and disconnecting all the grounds, idk maybe i missed a ground somewhere , i replaced plugs, wires, pump, clean tank out, water pump & more.. Pretty much a tune up so i can have a reliable s13
I got compression 120k miles, 1992 nissan 240sx ka24de 181 all cylinders
No spark
No fuel pump prime
No 5 sec CEL light bulb at all lights up on the key start position (did before i pulled the head out , i got another cluster in my house to verify)
When i turn the key. I got crank no start, no fuel no spark. I will check the ecu tomorrow to see if it's getting voltage
Everything was perfect before no CELs , so i feel its a ground issue.
However i did break the old brittle knock sensor so i junkyard a 95 altima since nissans are interchangeable for right now until the one i ordered comes. But still that shouldn't stop it from starting. Just manages the engine timing and signals it back to the ecu to run correctly
Thank you for reading and replying!
Jayhipter is offline   Reply With Quote
Old 01-04-2018, 11:05 PM   #2
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
Check to make sure your ECU is completely plugged in, make sure you’re getting power to it and there’s no broken wires anywhere
nisileighty is offline   Reply With Quote
Old 01-04-2018, 11:12 PM   #3
Jayhipter
Thanks! Okay tomorrow i will give that a try. Now thinking about it i did re route the 0 guage wire to the battery. Possible that i knocked the ecu connector loose? Or is it a bolt that hold it together
Old 01-04-2018, 11:16 PM   #4
nisileighty
It’s a bolt. What do you mean you routed it to the battery?
Old 01-04-2018, 11:27 PM   #5
Jayhipter
Relocated the battery to the trunk the first week i bought the car. But while i had the head out last week. I decided to clean up the wire route, so I tucked my 0 guage wire through the passenger fire wall into carpet, through kick panel by the ecu box and made my way to the trunk where the battery is. But I didn't touch the ecu
Old 01-04-2018, 11:33 PM   #6
nisileighty
Did you put the ground back on from the intake manifold to the chassis? And from behind the head to the firewall?
Old 01-04-2018, 11:34 PM   #7
anthony_240
anthony_240's Avatar
anthony_240 is an unknown quantity at this point
Did you put the ground back on the head ? By the exhaust manifold , and check the relay behind your ecu, your eccs relay can cause a no fuel no spark . Ask me how I know haha
anthony_240 is offline   Reply With Quote
Old 01-04-2018, 11:39 PM   #8
Jayhipter
Yes. The ground that is on the lower intake correct?
So far i checked
Ground on intake
Braided wire Ground on exhaust side
Small ground by injectors on wire harness
Theyre all connected not less im missing grounds??
Old 01-04-2018, 11:40 PM   #9
nisileighty
Okay. Did you remember to ground the battery - terminal...? Lol
Old 01-04-2018, 11:44 PM   #10
Jayhipter
Didn't know it was a fuse behind the ecu. Lol i hope that's it dude. This sh** driving me hella crazy right now. I just want it back running i miss driving it
Old 01-04-2018, 11:48 PM   #11
Jayhipter
Yes lol. I got distributor power block under the hood And a circult resettable breaker switch near the back. Everything electrical works like radio, pop up headlights horn turn signals. Just crank no start no spark no fuel
Old 01-04-2018, 11:48 PM   #12
anthony_240
Yea there is a relay back there , check it by bench testing or swap it for a known working one perhaps an AC relay. This drove me nuts on the track one day, took me 10 min to fix it after I towed it home
And in my s14, there is a ground on the exhaust side, that grounds out on to the firewall, I’ll snap a pic in the morning
Old 01-04-2018, 11:51 PM   #13
nisileighty
I’m willing to bet it is the ECCS relay. I bet an exposed wire or + was touched during the relocation and shorted. The relay will always fry itself before the ECU like a safety measure.
Old 01-04-2018, 11:53 PM   #14
anthony_240
Yea dude I’m sure that’s what happened too.
Old 01-04-2018, 11:53 PM   #15
Jayhipter
Thanks homie. I can go to sleep feeling better knowing i got solutions. I knew signing up for this app would be hella helpful lol
Old 01-06-2018, 09:07 AM   #16
Jayhipter
Alright guys.. so its hella cold here so I been on and off fixing the car. I jumped EGI & EGI Pump relays.
After jumping EGI Pump relay. Pin 2 & 3, Then key position on. I hear the fuel pump priming in the tank
After jumping EGI relay. Same pin locations I hear a click ONLY after i disconnect the wire
Still no spark no fuel. Still no check engine light, oil light when i turn the key to on position, brake light and everything else turns on
All my grounds look good. Unless i forgot putting a ground wire backwhen putting the head on
This so weird. The car getting spark n fuel was perfectly find before i pulled the head
Old 01-06-2018, 09:33 AM   #17
Jayhipter
Update: just went to the car. Took the ECU out. Twisted it into diagnosing mode. The RED light doesn't come on at all. So no power to ECU is my problem
Old 01-09-2018, 03:07 PM   #18
Jayhipter
SOLUTION for everyone who needs future help
SOLUTION: Distributor wire rubbed against the head. Blew Eng cont 25a fuse. Blew a circuit in the ECU that sends signal to spark and give fuel to the car. Which was why i did not have fuel or spark.
I fixed the wire by cutting & heat shrink wrapping it and re soldered the ecu. That fixed everything
Old 01-09-2018, 03:22 PM   #19
Jayhipter
Pictures of fixing the problem
Solution fixed: CEL comes on. Fuel & spark is back. Hope this helps anyone in the future
Old 03-02-2019, 02:04 PM   #20
ferlepo
ferlepo is an unknown quantity at this point
I have the same problem my friend! do you have any photo???
ferlepo is offline   Reply With Quote
