Old 03-03-2019, 02:55 PM   #1
bardabe
bardabe's Avatar
SR20VET VVL Turbo Partout by 5523 Motorsport | Bardabe Performance | JWT
Hey Guys,
This year i have lots going on, I originally thought I'd be able to finish my Neo VVL competition time attack car, my move to Texas and get my R32 GT-R going. Unfortunately i took on a bit more than I could chew on all while maintaining my sanity. With that said I'm cutting the stable down to one shop car rather than 3 and so the SR20VE is one of the projects that will go.
The engine is brand new and currently not assembled, everything is still sealed in bags from the second to final assembly process. This means one last wipe down and inspection putting everything on the assembly bench and then put it all together. All parts are brand new, never been used. Everything has been blue printed and recorded I was planning to compete with this engine in both GTA & Gridlife so it was built for reliability and response.
Lot of all parts to assemble short block $SOLD
JE Pistons 86.5MM (WPC Treated)
K1 Technologies Rods (WPC Treated)
OEM Nissan SR20VE N1 Oil Pump (WPC Treated)
Brand New Nissan Timing Components
Brand New Nissan Block Breather Vent
Brand New Nissan Block water Pipe
OEM Nissan Main Bearings (WPC Treated)
OEM Nissan Rod Bearings (WPC Treated)
OEM Nissan Thrust Washers (WPC Treated)
OEM Nissan Oil Squirters
OEM Nissan Crankshaft (WPC Treated)
S14 SR20DET Block
OEM Nissan Main Bolts
All new Freeze plugs, welch plugs and tapered pipe plugs.
Machine work done:
Oil feed for VCT has been tapped for 1/16 NPT Plug on block
Rear Oil Drain on Block was tapped for 1/2NPT Plug
Block was Torque plate honed
PDC Surfaced and matched with front cover.
Checked for main bearing journal straightness
Crankshaft was Cleaned, Mag'd for cracks, detailed, checked for straightness, chamfered oil passages, balanced with complete rotating assembly, and detailed.
Complete Rotating assembly was balanced
The following parts have been WPC treated for longevity and added insurance.
Pistons
Piston Rings
Piston Wrist Pins
Connecting Rods
Bearings
Thrust Washers
Crankshaft
Oil Pump
Oil Pump Housing (inside)
Oil Pump Driver
Timing Chain Sprocket (lower)
Crankshaft
VVL Swap parts
Brand New Nissan P12 CAS $275
P11 Lower Manifold & Upper manifold with accessories (iacv, throttle body etc) $150
Cooling Parts:
Brand New S15 Water Pump SOLD
Nismo thermostat (used) $50
Yashio Factory Water Pump Pulley SOLD
Other parts
Brand new P11 Valve Cover $100
I accept all forms of credit card, venmo, and cash as valid payment option. Only checks that will be accepted is verified cashier's check. (and will only release engine once the payment has cleared my bank institution)[/B]
here is currently where the engine stands.
Any questions or concerns please do not hesitate to reach out, ( [email protected] or (951)708-1648 )I'll do my best to answer any questions serious buyers may have.
Review Thread
bardabe is offline   Reply With Quote
Old 03-03-2019, 03:18 PM   #2
Supergoji
Supergoji's Avatar
Supergoji is an unknown quantity at this point
Send a message via AIM to Supergoji
Omfg somebody buy this
www.NYZC.net
Supergoji is offline   Reply With Quote
Old 03-03-2019, 07:19 PM   #3
Kouki_monstr
Kouki_monstr's Avatar
Kouki_monstr is an unknown quantity at this point
Legit dude, no short cuts , attention to detail, buy with confidence! Good luck buddy
97 Kouki- Third times a charm Instagram@Koukimonstrr
Kouki_monstr is offline   Reply With Quote
Old 03-03-2019, 11:07 PM   #4
tacotacotaco
tacotacotaco's Avatar
tacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfection
Send a message via AIM to tacotacotaco
fuck let me sell a kidney
tacotacotaco is offline   Reply With Quote
Old 03-04-2019, 01:04 PM   #5
2_Liter_Turbo
2_Liter_Turbo's Avatar
Trader Rating: (28)
2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough
Feedback Score: 28 reviews
Is the head machined for larger head studs, or factory sized (saw that you had mazworx studs, so I was unsure if they were the oversized ones).
96 S14: Grip Track Car
90 R32: Bucket List Car
92 S13: Just for Fun Car
Instagram: @SS.Maxey
2_Liter_Turbo is offline   Reply With Quote
Old 03-04-2019, 01:38 PM   #6
bardabe
bardabe's Avatar
credit cards won't have as big of an impact on your health lol
Factory sized studs, Both Nick & Clark saw no need to go oversized.
Review Thread
Old 03-06-2019, 01:29 PM   #7
bardabe
bardabe's Avatar
Cylinder Head Pending to 2_Liter_Turbo
That means, Block & All other VVL Swap components are up for grabs. Will modify original post of clutter to make it cleaner for you guys to read.
Review Thread
Old 03-07-2019, 06:51 AM   #8
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
This... is.... bad... fucking....ass!
da_crew10 is offline   Reply With Quote
Old 03-08-2019, 03:12 PM   #9
bardabe
bardabe's Avatar
Updated List. To the top!
Review Thread
Old 03-09-2019, 04:51 AM   #10
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
why can't you sell this in the fall when cash is plenty for me. jaun if no one buys this coming fall i'll hit you up for the complete short block.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 03-09-2019, 09:55 AM   #11
d9m13n
d9m13n's Avatar
d9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really nice
If I hadnt just dropped everything off at my machine shop the bottom end would be mine..
Ive been really stoked on this build since I first started following the build thread, sad to see it wont come to fruition. Best of luck with the move and the r32!
That wing looks as effective as the electoral college.
d9m13n is offline   Reply With Quote
Old 03-11-2019, 11:14 PM   #12
bardabe
bardabe's Avatar
Just put it on the credit card, pay it off in the fall.
Yeah dude I’m bummed I had to do this but have to focus on the bigger picture. Which means personal cars don’t get as much time or money.
Head is sold , short block and VVL parts are still available.
Review Thread
Old 03-13-2019, 10:53 PM   #13
bardabe
bardabe's Avatar
bump.......
Review Thread
Old 03-18-2019, 07:24 PM   #14
bardabe
bardabe's Avatar
.... short block part out fuck it.
Review Thread
Old 03-20-2019, 10:10 PM   #15
bardabe
bardabe's Avatar
to the tooop.
Review Thread
Old 03-22-2019, 07:03 PM   #16
stack-kat
stack-kat's Avatar
stack-kat is an unknown quantity at this point
Nooooo dont leave [emoji22]
Sent from my SM-G955U using Tapatalk
stack-kat is offline   Reply With Quote
Old 03-28-2019, 10:11 PM   #17
bardabe
bardabe's Avatar
sorry buddy, california doesn't like tuning shops gotta go.
BUMP someone has to need an engine.
Review Thread
Old 04-03-2019, 03:18 PM   #18
bardabe
bardabe's Avatar
well parts are going up on ebay.
Review Thread
Old 04-04-2019, 09:47 PM   #19
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
If this was for sale 6 months ago, I would of snagged it!
Dboyizmlg is offline   Reply With Quote
Old 04-16-2019, 12:58 PM   #20
HayabusaKLR
HayabusaKLR's Avatar
HayabusaKLR is an unknown quantity at this point
You have a PM on the long block!
'11 CTS-V coupe...runs low 10s
'98 240SX...2JZ soon
HayabusaKLR is offline   Reply With Quote
Old 04-16-2019, 01:20 PM   #21
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
he sold the head already
Old 04-16-2019, 01:40 PM   #22
HayabusaKLR
Got it, damnit. Still interested in the built short block.
Old 04-16-2019, 01:53 PM   #23
brndck
brndck's Avatar
its still a damn good deal on the short block.
Old 04-17-2019, 09:15 AM   #24
HayabusaKLR
100% agree, trying to get ahold of him but no luck yet. Hoping it hasn’t been parted out yet.
Old 04-17-2019, 09:46 AM   #25
2_Liter_Turbo
Trader Rating: (28)
Definitely give him a minute, he is in the middle of a big company move, so he's been slammed! Real good dude to work with.
Old 04-17-2019, 10:13 AM   #26
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Sent him a text. If he hasn't already spoken to you, he should be heading your way shortly
Old 04-17-2019, 04:50 PM   #27
bardabe
bardabe's Avatar
You have reply good sir thank you for reaching out!
I did it went to a good home though.
I see the light at the end of the tunnel it’s getting brighter. Much appreciate the kind words sir!
Thanks dude! You’re rad much much appreciated.
Review Thread
Old 05-29-2019, 12:50 PM   #28
bardabe
bardabe's Avatar
bump, pictures added parting out entirely at this point.
Review Thread
Old 06-03-2019, 07:33 AM   #29
jbrowne
jbrowne is an unknown quantity at this point
Price on ATI Damper?
jbrowne is offline   Reply With Quote
Old 06-03-2019, 10:30 AM   #30
2_Liter_Turbo
Trader Rating: (28)
It's been sold.
