03-14-2015, 11:07 AM | #1 |
Z32 caliper bridge bolt size
Hi everyone. Yesterday I noticed that one of my bridge bolts that holds the 2 halves of the caliper together had backed out and is now gone and lost for the ages. The other 3 have been re tightened and seems to be keeping everything in good order. I need to find a replacement for the 4th bolt. However Nissan doesn't list this with a part number because the caliper isn't supposed to be split. My question for everyone is, what are the specs for this bolt? Anyone know the length, diameter, thread pitch, etc? I don't want to take off another bridge bolt for fear further damaging the caliper. Has anyone with crap caliper laying around can take some measurements for me?
03-15-2015, 06:37 AM | #6 |
m10 x 1.25 pitch
length of the bolt including head is 106.75mm length of shank and thread 96.5 threads are 31.5mm So any 14mm m10x1.25x100 should work (100 being 100mm in length). Bear in mind you will probably have to get a separate washer so that will reduce the length by a few mm. I've found it hard at times to find those flange bolts in certain sizing. Look around and see, I'm sure you can easily find a replacement that will work. |
02-28-2019, 07:30 AM | #8 |
https://www.clipsandfasteners.com/1-...-p/pm33327.htm
This Bolt Works, Just need to the Add some threads |
02-28-2019, 02:53 PM | #9 |
Old thread......
