Old 08-21-2020, 07:07 AM   #1
Hayaiguy808
Hayaiguy808 is an unknown quantity at this point
Parasitic drain?
Hey guys I've been having a battery drain since I got my car it's a 1998 s14. Tested all my fuses in the kick panel with a multimeter and found two 10A fuses reading high. One being the room lamp fuse and the other is the tail lamp fuse. I pulled both fuses out and it seems that the battery draw has stabilized but how do I find the actual problem and fix it? Do I just rip apart the interior and inspect all the wiring? Any help would be appreciated thank you!
Hayaiguy808 is offline   Reply With Quote
Old 08-21-2020, 05:27 PM   #2
S14rebuild
1...welcome
2... there is a tech section for these questions (mods move please)
3..whats the concern with the draw? Is ur battery going dead overnight? Whats the condition of battery, and charging system?
4.... as for the interior light fuse, start disconnecting things tonsee if the draw goes away..(dome light, map lights, door jamb switches)
5... repeat same steps for tail lights, corner lights, and tag lights
Old 08-22-2020, 02:55 AM   #3
Hayaiguy808
Sorry I thought I posted in the tech section. But yes battery has been draining overnight. Battery is brand new (less than a month) and it's currently on the 3rd battery so far so I know it's not the battery and also the alternator is charging it up. I've removed all interior bulbs but I'll check the door switches
Old 08-27-2020, 08:39 AM   #4
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
check grounds, there's many of them. i had the same problem but it's a slower parasitic drain. soi'll if i'm not driving i would disconnect the battery in all. or use a battery tender
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 08-27-2020, 08:47 AM   #5
PoorMans180SX
PoorMans180SX's Avatar
Here's how to diagnose that.
https://testmeterpro.com/parasitic-d...-a-multimeter/
