Old 10-10-2024, 07:59 PM   #1
carmaniac1993
carmaniac1993's Avatar
carmaniac1993 is on the path to ruincarmaniac1993 is on the path to ruin
*** Yellow SR20 S14 *** Built ~400hp, Z33 trans, XT7's, top mount, knuckles
SOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLD
Built SR20 ~400hp, Z33 Trans, Work wheels, full interior
DSLR pics, walk around vid w/ engine running, mod lists, and some phone pics:
https://drive.google.com/drive/folde...uH?usp=sharing
In-car drift video:
https://www.youtube.com/watch?v=IoW0nPEk_NU
1995 S14 240sx
Car runs good, have owned since stock in 2009, I'm moving and would like it gone soon. Many extras and spares included. Additional mod details are in the pictures
Some highlights:
-Built SR, HKS cams, runs good, sounds good
-Porsche Racing Yellow paint
-Z33 6 speed trans (Mazworx, Serial9, ACT)
-Top mount Precision turbo
-Deatschwerks 850cc, Tomei FPR, Walbro 450
-Powered by Max coilovers and steer knuckles
-Work XT7's (two matching spares) 2x 17x9 +17, 4x 18x9.5 +22
-Welded 4.08 diff (Welded 3.5 Z33 diff/axle conversion available)
-Defi triple set gauges including boost, water temp, oil temp
Negatives:
-Pulls to the right while driving. Don't know why, it hasn't had
a solid alignment in around a decade. Good extra steering rack included
-A/C is not cold, likely leaking o-ring at the compressor (system is complete and used to work)
-Body kit (version select) is damaged/scraped up, most pieces are
included and can be repaired, quart of paint is included (front is taped up currently, won't last while at speed)
-The Defi water temp gauge temp sensor is not plumbed.
-one crack on the dash
Original odometer shows ~227k (doesn't work since the z33 trans install around ~1k miles ago).
The built SR block was installed around 2014 at ~ 219k miles and has been in the car since then.
Car makes roughly 400whp/300wtq on 20psi. It's been ran mostly between 10psi(gate) and 18psi
Extras included:
-Quart of yellow paint
-HKS Hipower exhaust
-Stock exhaust w/ cat
-Stock front and rear bumpers
-Front stock fenders, pair
-Zenki tail lights
-x2 extra Work XT7 wheels (6 in total)
-x2 17x10.5 mustang cobra wheels
-x2 16x8 +20 ROH wheels
-Good steering rack
-Pair of stock axles
-Starter
-PS pump
-Many Nissan oil filters
-Front crossmember
-Carbon GT mirrors
-Bottom mount passenger seat bracket
-Misc parts, corner lights, some other goodies
-Crank pulley, upper&lower oil pan, spare weather stripping for doors, spare sunroof motor
$17,500 for everything
Murfreesboro TN. I can help ship anywhere or deal locally. Probably better to pick up since the extra parts that are included. Cash or bank wire. Let me know if ya have a question!
Please text or leave a voicemail (I typically don't answer unknown calls) ** six15 four91 four377 ** My name is Steven
carmaniac1993 is offline   Reply With Quote
