Old 09-28-2012, 01:30 PM   #31
stephens14sr
stephens14sr is an unknown quantity at this point
i had the same problem recently. got a new fuel pump, redid the timing, and got new plugs and gapped them down to .021 now it runs great.
Full 2014 build progress www.handicapmafia.wordpress.com
stephens14sr is offline   Reply With Quote
Old 09-29-2012, 02:12 PM   #32
Jesse SR20
Jesse SR20's Avatar
Jesse SR20 is an unknown quantity at this point
Are you sure it's not a boost leak ? It certainly sounds like one.
You say there isn't a leak, but how did you test for one ? Did you pressure test it, or just look at it ? You can't visually inspect for boost leaks.
http://zilvia.net/f/image.php?type=sigpic&userid=64204&dateline=132878  0706
Jesse SR20 is offline   Reply With Quote
Old 10-09-2012, 07:46 AM   #33
Midnight Shift
Midnight Shift's Avatar
Midnight Shift is an unknown quantity at this point
SORRY for reviving a thread that was a few months old! I had the SAME thing happen to my car for over a year, I couldn't figure out what it was. I then had an engine knock so bad, that I replaced my SR.
Even with the new engine, when I would get into boost, it felt like it wasn't getting enough fuel, or like a boost leak. so I did boost leak tests, tried different MAFS, TPS, Coils, etc! I even changed the fuel pump! Recently it was getting really bad, especially on a not-so-smooth road! It would sputter and almost die out on me!
My friend told me he had the same problem about a year ago. What it turned out being was the ground on the fuel pump. I wasn't being grounded well enough caused it to not allow the fuel pump to run at full capacity! So, I just sliced in a wire and grounded it straight to the chassis, and my car was boosting and running like it's never run before!!!!! Try it out! It is the Black/white wire in your trunk that leads to the fuel pump!
So, 1 wire cost me a new fuel pump, and an engine swap!
Apparently, this can be a little bit common on S13s (I have a coupe!) So, give it a try, it can't hurt to do so!
Midnight Shift is offline   Reply With Quote
Old 02-23-2019, 08:21 AM   #34
Selivince
Selivince is an unknown quantity at this point
Hi, just wondering if this Problem ever got solved? As I'm having the Exact problem on my S14
Selivince is offline   Reply With Quote
Old 02-23-2019, 09:21 AM   #35
ultimateirving
ultimateirving's Avatar
Coil packs, spark plugs and gap size or fuel pump. These seem to be the common culprits. What have you tried ?
Z32 with lq4 swap
Old 02-25-2019, 08:25 AM   #36
jedi03
really sounds like boost leak to me...had hose pop off goin onto the freeway and acted like this...no boost, could accelerate just fine...hit boost, sputtering drop in power etc...
