Old 01-25-2020, 01:39 PM   #1
vazquez130
vazquez130 is an unknown quantity at this point
s14 Changing language on radio (Eclipse AVN2205d)
so i just bought a RHD s14 and it came with a eclipse avn2205d radio and i was trying to see if theres any way of changing the language from japanese to english.
vazquez130 is offline   Reply With Quote
Old 01-26-2020, 09:11 PM   #2
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Use a smartphone with Google Translate and use the camera feature to translate what you are seeing on screen. Look for Settings or Set Up and Language.
Old 06-17-2020, 07:09 PM   #3
bobocat
bobocat's Avatar
bobocat is an unknown quantity at this point
I think that there should be an option to reprogram the system. Or you can also try to use technical translation services https://isaccurate.com/technical-translation-services, maybe they will help in solving your problem by localizing the system. Also, I think you should look for information about this problem somewhere else. I think that you are not the only one who came across this.
bobocat is offline   Reply With Quote
