Old 08-23-2018, 10:25 AM   #31
Kingtal0n
Kingtal0n's Avatar
Another example from other thread
Pretty easy to see torque scale with boost. Just focus on torque because that is cylinder fill, which can only be 100% max. The engine clearly makes a max VE approaching 5500rpm where boost stops rising, max VE = max cylinder fill. Cylinder fill likely stays up after 7k because amazing VE head, but the turbo runs out of flow rate so the air loses density and power levels off. At that point is when we start to consider power and max flow rate and all of that because its the turbo's job to provide the dense air at high flow rates, and if can't keep up with the engines ability to flow then the only thing you can do is install larger turbo if you wanted more power. But max torque isn't going to get better with larger turbos or more head flow than this because adiabatic efficiency of compressors is pretty much standard as long as you are within the specific range the turbo prefers, and head flow rate isn't going to increase cylinder fill beyond 100%.
Old 08-23-2018, 10:52 AM   #32
Kingtal0n
Kingtal0n's Avatar
EVO makes 550ft*lbs, 32-36psi, E85, 2.0L
The guy who claims 370ft*lbs of torque at 17psi is also basically saying that an extra 18psi of boost, 0.2L of displacement and E85 is only worth 155ft*lbs of torque
When we know E85 plus 0.2L is worth around 50-70ft*lbs in and of itself, is like saying an extra 18psi is only good for 80-90~ ft*lbs of torque (non logical)
I looked through the srve thread and there does not seem to be anyone running lower boost pressures to compare with.
However it is extremely easy to find N/A Setups which clearly show 100% cylinder fill at 0psi of boost
sr20ve
sr20ve
sr20ve
sr20ve
Notice no matter what they all approach 150 ft*lbs at 0psi, approaching 100% cylinder fill with typical gasoline. In calculus, we would call this a"limit".
You can approach the limit, and be under the limit.
To use this math to your advantage simple multiply in the pressure ratio to find new torque, taking into account any friction, adiabatic efficiency, fuel quality
for example:
If I wanted to know how much torque at 15psi of boost I could say
15/14.5 = 1.034 + 1atm = 2.034 total pressure ratio
150*2.034 = 305ft*lbs
now, lets account for losses such as friction and adiabatic efficiency, say we lost 5% due to non component head losses (pump head loss from airpath friction, intercoolers, etc) and another 1% due to slight temp rise persisting after a non-perfect ambient temperature intercooling and 4% from other sources we can't imagine all of them, exhaust gas pressure pumping loss or something. Realize that there will be some additional losses. It doesn't matter exactly what they are, only that we expect some form of degraded output, it might even be a different percentage at each individual RPM. You can spend alot of time and effort lowering that percentage and improving efficiency, and even the atmosphere from day to day will influence so it isn't always the same number day to day either. Lets figure 10% for our rough calculations next though to keep it simple.
305 * .90 = 274ft*lbs of torque
Lets do it for 18psi now
18/14.5 = 1.24 + 1atm = 2.24
150*2.24 = 336ft*lbs
minus 10% for losses as above
336 * .9 = 302ft*lbs
Remember we are already working with torque at the tires so no need to compute drivetrain losses. Just keep in mind losses maybe higher in RWD platforms by a couple percentage.
If we removed the intercooler completely our adiabatic would be only something like 70%, it could be 20% less torque at the same boost when IAT would be much higher going into the engine (it comes out of a compressor 250*F or more at the pressures we are talking) and therefore air density would be lower. This why N/A torque comparisons are so powerful; they give you the torque production limit of a given displacement engine when the intercooler is 100% efficient (no boost, no intercooler) but there may not always be minimal air pathway resistance/friction and different engines have different frictions (some are lighter like Honda). There is typically some air heating as the air moves through the engine bay (so not quite ambient temp) and it could indeed be cooler coming out of an intercooler at ambient temp. Also remember the power lost on the intake stroke is used to draw air into the engine is heavily compensated for in a turbo application because of the kinetic energy of the incoming air stream towards the engine.
Old 08-23-2018, 11:39 AM   #33
Kingtal0n
Kingtal0n's Avatar
And just for good measure
Guess how much boost
http://nissanroadracing.com/forum/en...no-e-85-gt2868
breakdown
Old 02-15-2020, 09:23 AM   #34
jr_ss
Originally Posted by Kaisen View Post
I don't really know the maths behind it hahaha. Perhaps I should bring it to another tuner to take a look at it again, meanwhile I'll upgrade the injectors. The current tuner set it at 1.6 bar of boost.
How are my numbers so far apart from this following build, his is also a 2L build if Im not wrong:
http://zilvia.net/f/showthread.php?t=453229
http://zilvia.net/f/showpost.php?p=5...&postcount=453
This person as well:
http://zilvia.net/f/showthread.php?t=532438&page=5
http://zilvia.net/f/showpost.php?p=5...&postcount=142
@Kaisen, did you ever resolve your issues?
Old 02-22-2020, 08:57 PM   #35
Kaisen
Kaisen is an unknown quantity at this point
Hello! Kinda just accepted that the dyno is just a heartbreaker hahaha. Afterall it's a tuning tool and the car drives just fine and pulls hard. I have a friend who's driving an Evo X with some modifications and he's doing 350hp on the same dyno but on another dyno it reads 500. I'll probaby get a meth kit and cams and boost it till 2bar just to see how far I can push it.
Any updates on your car? Your thread is by far my favourite VE build!
Kaisen is offline   Reply With Quote
Old 02-24-2020, 06:06 AM   #36
jr_ss
No updates other than the car being reunited with me after two years. I’ll start tinkering with it again, time allowing. I have some upgrades planned for it and possibly a sleeved Mazworx block too. MORE POWA!
Old 02-24-2020, 07:21 AM   #37
Kaisen
Do update if there's any! Always a joy to read your build!
Old 06-06-2020, 01:23 PM   #38
jr_ss
Originally Posted by Kingtal0n View Post
this
is more than 17psi, or it was run with an extraordinary fuel that allowed a massive increase of ignition timing. 2.0L pump gas 93 octane with 17psi make 300 ft*lbs all day. Doesn't matter what 2.0L
This is more like 21-22psi or it has E85 or something. Even with E85 i don't see an extra 70 ft*lbs happening though. lol at spark blowout at 17psi btw. I've had it happen with a .028" gap on a copper plug at... yep 23psi of boost.
again, I have no idea what cam/tune you have. But you can clearly investigate for yourself every legitimate 2.0L in history pretty much produces the same amount of torque at the same air pressure because the cylinder total volume can only be the same size each time it fills. Air density plays a role obviously the larger the turbo the more dense the air will be at the time, which is why we use compressor map before purchasing turbo. Also remember E85 changes things a bit. FP turbo EVOS make 550ft*lbs but also AWD and run 32-36psi of boost E85 on 2.0L try a cross examination of theirs at 17psi to see what I am saying, you want double the torque you double the density with the same cylinder volume.
That is my dynograph and it was between 19-20psi on 93oct. Timing was not extreme.
Old 06-11-2020, 06:24 AM   #39
Kingtal0n
Kingtal0n's Avatar
Where is the datalog showing exact psi
Our eyes can't tell the difference between 21 and 23 on a typical gauge at the exact instant the engine hits peak torque on a dyno
Also keep in mind that most gauges vary 1-3psi , so unless you have a gauge and a datalog, or two gauge or two datalogs, you don't know what kind of error is in the reading. And there is always error term.
And finally the fact that pressure is highest near the compressor and lowest near the cylinder. If you saw 21psi at the intake through a properly sized intercooler that could very well be 26psi at the compressor. So not only is there error in the gauge, there is variance according the measurement location.
From looks of the graph I think it peaks 22 to 25psi and falls off to 20psi by redline
your original quote was 17psi though iirc and it really fucked this guy up thinking hes going to get 350ft*lbs at 17psi is a joke from any 2.0L
With a small turbine It takes 25-28psi to get that kind of torque out of a typical rwd sr20.
so first you say 17 and now it became 20, suddenly. And I bet its really 23.5 falling to 20 or something. Just be careful with ur numbers. Its very common or typical for people to make several passes, raising the boost gradually to the point where they no longer even know what the boost curve looks like or how much boost they are running. Even I am guilty of doing that while frazzled on a dyno session with my own vehicle. But when you are finished with all that, looking at the graph, don't go online and make up a boost number just because you don't have a recording of what it really was, that guess will get people's feeling hurt when they copy your setup and it only makes a fraction. Better just to say you aren't sure than use 17psi as a go-to guess.
Old 06-11-2020, 06:47 AM   #40
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
lol at the fact that you think jr is running analog gauges. What is this, 1926??
He is on a Haltech with proper data acquisition so I am pretty sure the numbers are accurate.
I am going to harp; the VE allows one to run very low boost numbers to achieve staggering results on pump......akin to the Honda boys. The head flow, it's ability to resist knock (which is all in the head design) and the different coolant jackets to the standard VE head, all contribute to a heat that is much less knock prone than any DE head and allows you to get away with alot on pump.
King, please lay off the blanket statements.....
Old 06-11-2020, 02:40 PM   #41
Kingtal0n
Kingtal0n's Avatar
We had this discussion already.
There is nothing you can do to the head of a 2L engine to make it produce more torque other than raise compression ratio.
I can make that blanket statement because it is true.
That is a fact across all platforms, all 2L engine in the world must abide by physics. 1982 - 2020 it hasn't changed much. DI improved things a little but we aren't going there.
Boost adds roughly 10ft*lbs per psi (gasoline; w/ ambient Intake air temp), regardless of what the head flows or what kind of 2L engine we are talking about, near peak torque/BSFC.
The fact he reported 17, and now suddenly 20, is highly suspect of 'guessing' and no actual data logs or reports to go from. And even then it is impossible to say whether the sensor is accurately calibrated without a second sensor. Or where the pressure data is being taken from, compared to other locations.
Last edited by Kingtal0n; 06-11-2020 at 03:24 PM.. Reason: added "gasoline & ambient IAT" to be specific
Old 06-11-2020, 07:29 PM   #42
jr_ss
Dude you need to lay off the pipe man. No one reported 17. You manifested a number and rolled with it. That is MY dynograph and the car is setup to run 19-20psi. Sure, there maybe an initial boost spike when the turbo lights off, but what car or turbo setup doesn?t see a slight spike(1-2psi) until the solenoid catches it. Hell even your internal gates spike. The Haltech controls boost very well and maintained 19-20 throughout the pull, without spikes. It?s on 44mm gate as well.
My boost gauges (Haltech and Defi) tee off the same vac line and are within 1psi of each other, in-fact, my Defi reads slightly higher than the computer. It doesn?t matter what pressure comes out of my turbo, what matters is what is being ingested by the motor. All that data provides is how efficient your intercooler is. There is and will always be a pressure drop across them. Your argument is invalid here.
You can sit here and throw all your mathematical figures at it and still come to the same conclusion, you?re wrong. If you have no experience with a VE head, perhaps you should get some. At the end of the day, I?m not going to post a data log for you, to legitimize myself, for your satisfaction. You can take my word for it or don?t. Personally, I don?t care what you do.
Old 06-11-2020, 07:39 PM   #43
Kingtal0n
Kingtal0n's Avatar
never said it was impossible just to be careful with numbers. I thought the thread op said your graph was at 17psi thats where I got it from.
For an sr20 engine to make an extra 50-70 ft*lbs of torque (360 instead of 300 at 19psi) there are many things you could or would have to do.
Working backwards that is like a 4L engine making 5.3L engine torque (360ft*lbs). It doesn't add up. Something is wrong, where did the extra 1.3L come from?
You can put aftermarket heads, cam, intake, exhaust, all the mods you want and it will never make more torque than the same 100% peak because you can't go over 100%.
Maybe you bored and stroked the engine to 2.4L and just forgot. Or had a 50 shot of nitrous on it.
Honda makes the most efficient engines on the planet, lets see what their 2L does at 19psi...
With E85
https://www.maperformance.com/blogs/...2k-on-our-dyno
wow look at the Honda go
This is 1.8L AND E85 , you can clearly see the resemblance to all the others (torque)
https://honda-tech.com/forums/forced...-tune-2820252/
Its missing .2L so add 10% torque to what you see to compare with 2L
I'll keep looking though
heres 2.4L KA24DET
13psi of boost
http://www.ka-t.org/forums/viewtopic.php?t=45339
Intersting. Creeping on 320ft*lbs with .4 extra liters but 6psi less boost.
Lets work backwards to see if it makes sense with what we already know
Go from 2.4L to 2L so subtract 20% torque: (320 * .8) = 256ft*lbs,
now lets add the boost: for every 1psi we add roughly 10ft*lbs so lets count it out,
13 -> 19psi = 6 psi so +60ft*lbs to 256ft*lbs = 310ft*lbs of torque from 19psi at 2L !! Imagine that
Isn't it funny how no matter what engine we look at from what car, around the world
Old 06-11-2020, 08:05 PM   #44
jr_ss
I can tell you though, I've seen lots of cars run on the dyno here. hundreds, thousands, idk. And I see them raising that boost, 20, 22, 25, 28. and then go on the forums and say it was 18psi.
Happens every day.
Nope, still a 2L, even with 86.5mm pistons.
I hear what you?re saying, but I have nothing to gain by lying about what my car made/makes. Oh, this was on P11 cams as well, the worst cams for the VET setup. Remember, VE on this motor is far different than the DET. Have you seen what a factory VE head flows without modification? If I recall correctly, my intake CFMs were 273 and the exhaust was 196.
Old 06-11-2020, 08:08 PM   #45
Kingtal0n
Kingtal0n's Avatar
2.4L at 18psi:
http://www.ka-t.org/forums/viewtopic.php?t=38282
So your 2L makes 2.4L torque? Where did the 0.4L come from? magic?
cams, exhaust, intake, makes no difference. Displacement is, there is no replacement. It doesn't match what is typical, is all
2L at 18psi again, volkswagon this time
https://www.getunitronic.com/ecu-tun...012-stage1plus
Oh look 325ft*lbs and its not even a dynojet.
Think about that for a minute.
They clearly fudged the numbers up a little to sell their product, and its higher than any other 2L i've ever seen because its NOT a dynojet and was fucked with, and STILL its 30ft*lbs less than what you are suggesting a 2L will make!
Mitsubishi, gasoline, 2L
https://www.evolutionm.net/forums/ev...93-octane.html
355ft*lbs of torque... at 27psi of boost!
ur telling me you make what a 2.4L engine makes, that sr20VE makes what a 4g64 makes at 27psi, with just 19psi... it makes the 4g63 engine look like garbage! When we all know 4g63 is king. Or so I heard
Can it be that good? to beat every other engine ever made? Realistically I hope so because I will use it immediately. Can anybody find more graphs?
Old 06-11-2020, 09:37 PM   #46
jr_ss
So I guess these guys are lying about their 36x ftlbs of torque too. Top one is Almost the exact same setup and head. The bottom is my components before I owned them. Spend some time in the VE thread too, educate yourself. Math is math when your formulas are right...
https://zilvia.net/f/showpost.php?p=...7&postcount=46
Old 06-11-2020, 10:50 PM   #47
Kingtal0n
Kingtal0n's Avatar
can you please link the examples so I can find them, dynojets are all the rage
Old 06-12-2020, 07:46 AM   #48
jr_ss
This is old data. These motors/setups have become far more prevalent in the last 10yrs. Here is the link to the post for the top Dyno. You can search to find his original post. The second dynograph is from 2009-10 when the VVL setup was just becoming available. I don?t have a post for it. Again, this is old data.
https://www.sr20-forum.com/forced-in...48#post!952948
Old 06-12-2020, 01:30 PM   #49
Kingtal0n
Kingtal0n's Avatar
Thank you, lets delve shall we
first this graph was created at 11psi of boost, according to the owner
Lets see if it follows the 10ft*lbs per psi rule:
take 260ft*lbs and remove 11*10 = 150ft*lbs at 0psi,
this is what we expect from the 8.5:1 gasoline engine N/A platform with 0psi of boost.
So far so good.
Before moving on let us acquire a direct turbo comparison so we can effectively determine efficiency (since precision does not release compressor maps)
Here is a random 2.2L Honda (very efficient engine?) with high compression (11:1) using 14psi of boost on that turbo
https://www.s2ki.com/forums/s2000-fo.../#post24603727
WTQ: 315RWTQ is claimed
Lets use two of them because idk what dyno the first one has
https://www.s2ki.com/forums/s2000-fo.../#post24272158
Motor: F22c
Compression Ratio: 11.0:1
Specs: Bone Stock
Injectors & cc: Injector Dynamics 1000cc
Fuel Pump: Walbro 450
EMS: Hondata Kpro V4
Fuel: 93 octane, no meth
PSI: 15 PSI
WHP: 521WHP
WTQ: 360WTQ
Dyno: Dynapack
So same engine same compression but 45ft*lbs extra using dynapack dyno.
both 93 octane so thats good. 2.2L engines, 6262 turbo.
pull 10% from those due to the extra .2L of displacement and we should neglect compression for now, but remember it is higher
we get 315 * .90 = 280ft*lbs for the first and
360 * .90 = 320ft*lbs for the second (dynapack dyno)
In theory with 2L that is what they would have made at 15psi of boost w/ 11:1 compression
Does that fit 10ft*lbs/1psi ?
Lets see, 280 - 15psi = 280 - 150ft*lbs = 130ft*lbs rwtq
320 - 150 = 170ft*lbs rwtq
In the first case, unknown dyno, I would say it looks a little low. The 2L should have given 150ft*lbs so I believe the engine is stuffed (not optimized for performance). Which the owner clearly says "stock engine parts" so this fits. Plus maybe it was a mustang dyno or something like that which reads lower than dynojet. The numbers don't need to be exact; they just need to fit our solution curve that all engines fit.
next 170ft*lbs seems a bit high, but its on a dynapack which might read high by 20ft*lbs this time around. Or the dyno might read low and we are just seeing what 11:1 on boost can do.
Either way, they both come very close to the rule of thumb of 1psi per 10ft*lbs of torque.
We expect a bit more torque per psi on high compression engines.
We do NOT expect more torque for any other reason. Either psi of boost, or compression ratio, those are the factors here. The VE cannot be improved above 100%; it can only go DOWN. That is why low numbers are 'fine' but high numbers are 'impossible'. Every engine must fit this rule of thumb.
So now lets look at the 6262 turbo on 2L example with "19psi"
That exact same engine made 260tq with 11psi so if we extrapolate:
350 - 260 = 90 = 9psi required extra
11 + 9 = 22psi of boost required to reach 350, so lets say 23~psi of boost for 360ft*lbs
Looking closer, we see that there is a power dip in the RED curve which correlates to this boost number:
The power onslaught was so severe, boost went to 24psi momentarily before dropping back to 19psi
So here is what I see. The boost comes on to 24psi and it makes 350-360ft*lbs of torque. Which makes sense.
Then for the rest of the run, it seems like the gauge is inaccurate, or the owner wasn't still paying attention, or the owner is making the assumption that it was 19psi, or the owner wasn't sure. Or something along those lines. My gauge is cheap and it does the same thing in the car, but the datalog shows differently, so we dont know the actual boost without some kind of log and a standard.
Without the data to compare, we have no way of knowing. I do know one thing though, there is alot of mystery surrounding those numbers, and if what the owner says is true "24psi" is the ticket to making 350-360ft*lbs on a 2L engine, definitely fits our 10ft*lbs/psi rule, and definitely shows up on that graph.
Another thing to consider is that the engine in that run used a JWT computer, which uses obnoxiously high timing values. That is why the graph is so spiky/wavy even with smoothing=5.
Normally, a graph with proper timing will be smooth, especially with such a small engine and good tight, lightweight parts tuned well is smooth.
but that graph is absolutely all over the place. It goes up, down, a LOT more than we can see, it is 'saved' by smoothing=ALOT.
Well, those spikes cause erroneous torque and power readings. The dyno takes any 'peak' as it's peak number. This is an easy way to generate a falsely high number from any dyno by accident.
So with the smoothing at 5, we still see crazy spikes, that is going to have an impact on the numbers throughout the run, because the engine was pushing harder sometimes and other times struggling for a moment, then pushing again hard, the cylinder pressure was all over the place. So this is not a good representation of torque output from an engine, we should not use this graph (or any dynojet at smoothing=5) for our analysis. However I understand the fundamental lack of sr20VE graphs (which is why I keep including random engines to make our "pool" of dyno graphs useful) so we are making do with whatever we can get.
So kick that around for me and look back at what 2.2L does and play with the math a little bit to see for yourself.
lets take the 2.2L at 15psi that made 320 @ 2.0L and try again with 11:1 compression (highest torque possible at 2L with 6262 turbo)
here goes
320 @ 15psi + an extra 4psi = 320 + 40ft*lbs = 360ft*lbs of torque at 19psi with 11:1 compression at 2L
See what I am getting at here, there is no very little evidence that a 2L engine with 8.5:1 compression made by nissan can produce 360 ft*lbs at 19 psi when it takes engines like a Honda with 11:1 compression and super light drivetrain to hit that region of torque. And even then it is so rare, most of them are 2.2 or 2.4L.
I am all for fudge factors, but not convinced so far. Will need to see a few more dynojets of VE engines before I am convinced, thats all. Maybe the truth is out there.
Old 06-12-2020, 05:56 PM   #50
Kingtal0n
Kingtal0n's Avatar
This is what the dynojet is telling me about 2L on gasoline
Some boost controller sinusoidal activity is typical when the state-space type of boost controllers are improperly configured to respond fast enough.
So it is very easy to see what is happening. The boost rockets to some value, the controller over compensates, and it falls off, then the controller re-compensates back to the original value, over shoots again slightly, overcompensates, back and forth a couple times until it settles out near the original starting value but without overshoot and over compensation.
This is a very typical control system behavior. And since we know engine torque follows boost pressure when VE is a flat number, which is clear and easy to tell from the flat torque curve, we must conclude that whatever the initial boost pressure number is (24psi) is the same across the board, because torque is a flat line there which tells us the engine isn't losing efficiency until after 8,000rpm which is consistent with what we know about the SR20VE head.
Old 06-13-2020, 08:18 AM   #51
jr_ss
There’s an overwhelming amount of dyno graphs out there that prove your formulations are flawed. I think this one is the icing on the cake... These motors respond well and perform when boosted. You can not deny this.
https://www.driftworks.com/forum/thr...670wnm.268847/
Edit* Here is the landspeed racer dyno. Gasp! 1.5l making 400ftlbs of torque...
Old 06-13-2020, 05:27 PM   #52
Kingtal0n
Kingtal0n's Avatar
There?s an overwhelming amount of dyno graphs out there that prove your formulations are flawed. I think this one is the icing on the cake... These motors respond well and perform when boosted. You can not deny this.
That is not a dynojet bro. It also clearly says "flywheel torque" which is a dead give away that they are working backwards from RWTQ and RWHP with a number that somebody put into the computer at random (nobody actually knows what their drivetrain losses are, they can put whatever number they feel like)
We only use dynojet because they cannot be fooled. I can hex edit or adjust the torque from any other dyno, such as that one, to read whatever I want.
I could show you right now a 2L engine making 1000ft*lbs naturally aspirated. shocker
So far my dynojet predictions match every single 2.0L on the internet that I have found. Not one flaw with my formula or reasoning.
and so far the only thing you have shown me is 1 person who claims 24psi made 360ft*lbs of torque, which I also believe.
Send more dynojets of SR20VE and I will knock em down one by one. Don't try to fool me with other dynos lol. What do you think I am... noobie city over here
I want you to think about something very carefully. Energy comes from fuel, not boost. The boost just increases air density so you can inject more fuel.
Therefore, a/f ratio has a dramatic impact on torque, as does inlet air temperature.
If we hold those two variable constant, and assume ambient underhood air temp (100*F~) and typical gasoline ratio of "plenty of fuel" 11.5:1, what other factors remain?
There is displacement, Volumetric efficiency, compression ratio, and air density which is a function of air temp (a constant we are holding) and pressure (the boost pressure we are given as a constant).
Peak torque is typically achieved around 100% VE on all engines designed after 1982 as a constant 95 to 100% given, stock truck 2.4L KA24, stock truck 5.3L, stock 2JZ, stock SR20, all make near 95 to 100% VE so it is another constant we can ignore.
Notice how engine flow rate or head flow rate, or anything to do with the head beyond VE (which is constant) has absolutely nothing to do with torque output.
therefore it is impossible for anyone to take any 2L in the world, and get more torque from it given those constraints. It is thermodynamically, energetically, very unlikely without some novel technique (such as Direct Injection algorithms) to alter the BSFC and thermal efficiency of a power plant.
This is the same way engineers use modelling to determine power plant consumption, heat loss, shaft power, etc... That is, by holding some variables constant and looking what happens to the other ones.
In a more simple example, just use your imagination. Fill a cylinder to 100% capacity with the piston in opportune position and then fire the plug and measure the force generated by the piston's descent.
if you do this over and over with a 0.5L (1/4 of a 2L) cylinder you will find that no matter how many times you do the same experiment, it will generate the same torque or push given all identical starting conditions.
changing the "head" (cover over the cylinder) will not affect the torque unless it disturbs the compression ratio or efficiency of combustion. And even then the difference will be slight, and all heads made by Nissan after 1982 and all Heads made by Chevrolet made after 2002 contain the same cylinder head technology "fast burn" so there is little difference, nothing better has come along since for gasoline, and even if it does it will only be less than 1% superior.
why is that? How can I say that?
We know this because combustion has reached a pinnacle in our society. That is, thermodynamics has extracted all of the available energy (within 1% of what it attainable due to countless studies over the last 40 years by scientists and engineers on typical port injection engine platforms) regardless of who manufactures the engine because all engines in our modern time make use of similar computer modelling which puts the efficiency of every modern engine right near its calculable limit (the limit defined by calculus) of what is possible with gasoline.
This why no matter whether we check 1995 or 2015 or 2020 the fuel efficiency on modern engines and cars has not gone up by much if anything it has gone down due to stricter emissions regulations! That is to say that, if they could squeeze more than 1% or 2% from any modern gasoline engine it would have shown up as an improved fuel economy model, yet new corvettes and new Toyota supras with all their modern combustion gadgetry still provide a measly 15mpg to 22mpg or whatever, the same in 1995 and 2015. They are at the limit of efficiency!
Old 06-13-2020, 07:16 PM   #53
Def
sigh... Zilvia...
A given amount of torque for a given displacement and intake MAP only works if the engine VE is constant. An SR20VE head will have way higher VE than a DET head. I personally saw ~10-14% higher on my old S13 in boost with the exact same turbo manifold, turbo, exhaust, intercooler setup. Only change was the VE. The VE needed more injector duty cycle at the same boost on the high cams everywhere to get the same AFR.
So if the boost is the same, the displacement is the same, but it needs 10-12% more fuel at the same RPM... what's happening to the torque? That's right, it went up.
I think you'd be surprised looking at old engines with really poor volumetric efficiencies and how much torque they generated per liter of displacement. You're likely just used to looking at late 80's, early 90's engines designs with all similar peak VEs (SR20DET, 4G63, 3S-GTE etc.).
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 06-13-2020, 07:54 PM   #54
jr_ss
Originally Posted by Def View Post
sigh... Zilvia...
Thank you. I was hoping you?d respond...
Old 06-13-2020, 10:50 PM   #55
Kingtal0n
Kingtal0n's Avatar
sigh... Zilvia...
Your BS cannot confuse me. Your post contains no useful information or proof of anything.
Show some data, show some graphs.
Here is an entire thread of dynojet data for SR20VE engines:
https://www.sr20forum.com/threads/th...o-post.184824/
ALL Of the dyno jets follow the trend of 150ft*lbs max for sr20VE Naturally aspirated. They ALL follow the same rule of 1psi per 10ft*lbs of torque. 14.5psi of atmospheric pressure @ 100% VE = 145ft*lbs of rwtq on a dynojet. This rule is for all 2L engines. No matter what is done to them, it is the same maximum limit.
I've examined around fifteen or twenty dynojet curves in this thread alone and all of them follow the same rule.
There has not been a single any significant difference between any of the engines from any manufacturers. Sr20VE and sr20det and 2jzgte and LM7 and LQ4 and L33 and (name any engine made after 1982) can achieve 95 to 100% VE with very simple mods, and many do it stock, some even trap higher VE with the OEM camshaft due to high inlet port velocity at low rpm with small diameter intake ports helping supercharge the cylinder. This is therefore a given and assumption for all engines, stock LM7/SR20VE/SR20DE/2JZGTE can do 95% to 105% VE easily, installing a long duration aftermarket cam actually can hurt their VE and drop torque and cylinder pressure.
Old 06-14-2020, 12:01 AM   #56
Kingtal0n
Kingtal0n's Avatar
Dynojet data for sr20ve vs sr20de engines:
SR20VE with a stock cam, near 90% or 100% VE easily due to excellent design
SR20VE with what I assume is some kind of "cam upgrade" making nearly the same exact VE and thus torque:
The Volumetric efficiency(VE) did not improve much, and as expected with a 'cam upgrade' the cylinder pressure is lower in some early rpm area because Volumetric Eff suffers in the low RPM ranges due to the effect of a larger cam on almost all engines.
Next, SR20DE engines fully modded out to show near 100%Volumetric Efficiency for comparison:
Conclusion:
All 2.0L engines whether sr20de or sr20ve produce similar peak Volumetric efficiency, and we can tell this by comparing their peak torques with each other. The DE engine is not inferior to the VE Engine in terms of cylinder pressure, torque capability, or Volumetric efficiency (also called VE).
Despite an overwhelming number of variables which interplay with dynojet (humidity, temp, altitude, engine wear, age, etc...) ALL 2.0L engine display similar Volumetric efficiency and Torque capability regardless of manufacturer or model.
Old 06-14-2020, 05:10 AM   #57
RalliartRsX
Trader Rating: (32)
I stopped listening or caring when king constantly made all these assumptions (engine must be old, wrong dyno, etc. regardless of what the actual poster of the results state) to FORCE his narrative
Lol. Why do you guys keep resounding? All 2 liter engines produce the same VE is a whole bunch of bullshit when we are talking turbos and the heads ability to "efficiently" fill cylinders (read k series, VE or B series heads)
King has never dealt with a head or turbo that is able to fill engines way above 100% VE......lol.
Yeah next....
Old 06-14-2020, 05:39 AM   #58
RalliartRsX
Trader Rating: (32)
It funny, jr I had a written up a post and mentioned the LSR car. The browser stopped responding and I didn't bother to waste my time
King, that is NOT flywheel HP.
https://5523motorsports.com/road-wor...s-unstoppable/
Here is a pic of Nick and JWT on the (chassis) dyno.........
Old 06-14-2020, 05:45 AM   #59
RalliartRsX
Trader Rating: (32)
Also, not all engines are able to fill to same VE at the same RPM. Also, pressure is essentially forcing more air mass into the same volume. PV = NRT. As Pressure increases, SO does Temp for the SAME volume.......
The VE head has the ability to flow MORE MASS of air vs a DE or DET head, hence it is able to get closer to 100% VE without a turbo. Add a turbo, and the above (albeit very simplified) equation comes into effect....
Old 06-14-2020, 06:30 AM   #60
jr_ss
Yeah next....
My problem with it, is he is spreading misinformation about what a specific motor with a specific head can produce and he’s wrong.
All his math formulas and knowledge yet he still isn’t open to expand his mind and think outside of them. That perhaps, something has changed and has allowed the increase of torque vs dismissing it and calling it bullshit. .
I find it extremely amusing that he dismisses Def and calls his claims bullshit, when we all know who Def is.
He also talks about researching but goes on to regurgitate his rhetorical nonsense instead of researching himself...
Anyway, King these are legitimate power levels and real world data. As I said before, take it or leave it. At this point, I realize you cannot think outside of the box. It’s always going to be black and white for you.
