Old 07-18-2019, 02:37 AM   #22741
2FT
2FT's Avatar
2FT is an unknown quantity at this point
Hey y'all. Buttoning up some stuff on my KA-T. I have a s14-a, and I'm looking for the Power Steering Pump Banjo Bolt. I'll attach a picture. I have the Chase bays power steering kit (for the 240) and it says it's supposed to work so I assume I just need the Banjo Bolt to seal it up.
Also:
Does anyone know the driver side seat rail to chassis bolt size&thread?
Picture of my power steering pump!
2FT is offline   Reply With Quote
Old 07-18-2019, 10:52 AM   #22742
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
What other side mirror glass fit s13 housings? To my knowledge its...
3rd Gen maxima (Blue tint)
Z32
G20.
Is that it? I plan on going to the junkyard to stock up since I dont want to get new mirrors.
ZenkiKid is offline   Reply With Quote
Old 07-18-2019, 12:44 PM   #22743
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Z32
G20.
why not go to a glass shop and have a new one made? its not rocket science.
Old 07-18-2019, 02:16 PM   #22744
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
Or just buy it new from Nissan?
https://www.nissanparts.cc/oem-parts...b3J5IFBhZ2U%3D
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
Old 07-20-2019, 05:44 AM   #22745
180sx_
180sx_'s Avatar
180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about
Alright, I've done heaps of googling and searching but nothing helped so don't get mad at me please...
My 180sx is factory auto so it beeps when you're in reverse and it annoys the shit out of me. People have said there's a rectangular shaped module under the dash above the pedal boxes and to unplug it.
Problem is, I can't even find it.... Anyone else been through the same issue?
Sent from my SM-G935F using Tapatalk
180sx_ is offline   Reply With Quote
Old 07-22-2019, 05:06 AM   #22746
marc-s13
marc-s13's Avatar
marc-s13 is on a distinguished road
Anyone know what sits closer for an S13?
Works Bell Short Hub (618S)
NRG Short Hub (SRK-140H)
Thanks.
marc-s13 is offline   Reply With Quote
Old 07-22-2019, 05:07 AM   #22747
marc-s13
marc-s13's Avatar
Thanks.
Old 07-22-2019, 10:32 PM   #22748
dsastr_clan
dsastr_clan is an unknown quantity at this point
Question
I'm running a redtop sr with a SOHC but it isnt holding idle and it runs pretty crappy.
Does the SOHC maf will make the SR run and when Im actually driving the car, the car drives fine. But, can the SOHC maf make the SR run crappy?
dsastr_clan is offline   Reply With Quote
Old 07-22-2019, 10:41 PM   #22749
dsastr_clan
Question
Old 07-23-2019, 10:56 AM   #22750
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
so i bought a vehicle that was a respray (maaco special). its actually one of the better maaco paint jobs ive seen, but the painter and/or prepper did a shit job masking certain things off. so i have some light over spray on my windshield and some of the weather stripping.
how would you go about removing this paint? can i use acetone on glass and not have it cloud up? what about the rubber window trim? wont the acetone dry it out?
thank you in advance. i see some of the paint on the windshield when im driving and it drives me crazy.
jumpman2334 is offline   Reply With Quote
Old 07-23-2019, 01:46 PM   #22751
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
For the glass you can use a razor blade and/or 0000 fine steel wool. Depending on the paint type used, you may not be able to get it off the trim.
Old 07-23-2019, 03:12 PM   #22752
jumpman2334
thank you.
Old 07-24-2019, 09:12 AM   #22753
180sx_
180sx_'s Avatar
thank you.
Glass cleaner/soapy water should do it! Also could use a clay bar to get as much contamination off [emoji106] good luck with the trim! Let us know how it goes
Old 07-24-2019, 01:10 PM   #22754
jumpman2334
a clay bar for the trim? im not so much worried about the glass (its easy but i just thought id lump it in there). its the trim im worried about. its a 99 and im assuming the trim is from the factory so its old.
i am aware that i would probably be better off buying new trim, but im trying to see if i can save this trim. its only in a few spots. im also wondering if i can get a flat plastic pry bar or something underneath the trim to try to slightly deform it to get the paint to chip, crack, flake, etc.
thanks again.
Old 07-24-2019, 01:50 PM   #22755
[240sx]
[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute
^^ What car did you buy? Not that that'll help, but I'm curious, and this is the small question's thread so...
[240sx] is offline   Reply With Quote
Old 07-24-2019, 01:56 PM   #22756
jumpman2334
its a 4runner.
Old 07-24-2019, 05:20 PM   #22757
180sx_
180sx_'s Avatar
thanks again.
I was meaning clay bar for the windows
Old 07-26-2019, 09:29 AM   #22758
jumpman2334
okay, i will give it a shot this weekend. thank you!
Old 07-30-2019, 11:08 AM   #22759
Crazyced
Crazyced's Avatar
Crazyced is an unknown quantity at this point
I searched a little but didn't find anything. What's the difference between the Open and Viscous diff for S13 and s14? And I'm talking about physical differences, not how they work.
Reason being Tomei and Kazz says they have different part number LSD fitting previously open or viscous diffs and I'm wondering if it's the axle splines that are different or the casing itself or something else.
Crazyced is offline   Reply With Quote
Old 07-30-2019, 12:47 PM   #22760
Drama
Drama is an unknown quantity at this point
It's the length of the output shafts and c-clips that are different
Drama
Drama is offline   Reply With Quote
Old 08-02-2019, 08:22 AM   #22761
DarkSlide77
DarkSlide77's Avatar
DarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really niceDarkSlide77 is just really nice
I’ve been on this site for years and never once asked a question, so I hope No one will get mad. I’ve searched....
I bought some brick S13 Silvia headlights (with the rectangular bowls) but it didn’t come with any of the socket “seals” on the back. I don’t know where the hell to get them.
1- do I need these seals on both the smaller and larger socket holes? The smaller socket has this cup-like boot on it, but no seal underneath it.
2- do I NEED to buy those little plugs if I’m going H4 bulbs? Basically, Is there a bulb I can get away with not buying the plugs?
I just want it to work and be fairly watertight. Don’t care which bulbs I get, whatever works is fine with me. Those little bulb plug are expensive as hell and I’d rather avoid buying them if possible. Huge thanks
DarkSlide77 is offline   Reply With Quote
Old 08-02-2019, 08:25 AM   #22762
DarkSlide77
Yo Drama! I’m in El Paso too man. You know anything about these kinda headlights?
Old 08-02-2019, 09:04 AM   #22763
TheBlackHand
TheBlackHand's Avatar
TheBlackHand is an unknown quantity at this point
Do you mean the plastic rings that lock the rubber seals in or do you mean the rubber seals that keep dust & water out of the headlight?
1. If you mean the rubber seals for keeping out dust & water then yeah, you would want to have those unless you don't mind the inside of your headlights getting filthy.
If you mean the circle plastic rings that lock the seals in place then no, you can get away without using those. I've owned a pair of dual projectors & bricks that were missing these and it never caused any issues.
2. You mean the small wiring harness for both bulbs? Just buy H4 LED conversion bulbs which will plug straight into your factory harness. This would mean you'd have to make a harness for the H3C high beams though.
There's write ups here on how to wire the high beams/fog lights (for projector headlights) to your headlight up/down button in the cabin.
TheBlackHand is offline   Reply With Quote
Old 08-02-2019, 09:18 AM   #22764
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
Let's say I wanted to turbo an N/A Z32's VGDE engine. I have seen write-ups on what you might expect regarding cost & performance if you use OEM parts. But everyone knows the OEM breathing components are really restrictive on the VG30. Anybody got any idea what to expect if someone wanted to go straight to using all the required bolt-on, but aftermarket breathing mods right out the gates? I'm talking like Z1 exhaust manifolds & piping, Ashspec massives smics, etc... paired with either stock twins or T28s? I've been coming up empty so far in my search.
"Simplicity is the key to brilliance." - Bruce Lee
simmode1 is offline   Reply With Quote
Old 08-03-2019, 09:48 PM   #22765
DarkSlide77
Yeah that’s exactly what I needed to know, thanks man. One thing I don’t know still is where to get those “seals” for the back. Can’t find them. I’ve heard they might be interchangeable with r32. Not sure.
As for your reply to #2, Na I don’t mean the wiring harness, it’s literally like a small squarish block that has male plugs sticking out of it. Think of an iPhone charger block.... not sure if I explained that well lol but it looks like you plug the sub harness into the block and the block plugs into the bulb. It seems to lock into place with the metal in the socket hole.
Old 08-09-2019, 09:09 PM   #22766
Standard
Standard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud of
^ Are you referring to an adapter socket? Are they H1 bulbs? Not familiar with Silvia headlights, like this?
Standard is offline   Reply With Quote
Old 08-13-2019, 12:42 PM   #22767
Jacob Butler
Jacob Butler is an unknown quantity at this point
One of my header bolts snapped off in the head, y'all think a helicoil would be a viable solution for this or nah
Jacob Butler is offline   Reply With Quote
Old 08-13-2019, 02:18 PM   #22768
hotrodjoseph
hotrodjoseph's Avatar
hotrodjoseph has a spectacular aura abouthotrodjoseph has a spectacular aura abouthotrodjoseph has a spectacular aura abouthotrodjoseph has a spectacular aura abouthotrodjoseph has a spectacular aura abouthotrodjoseph has a spectacular aura about
Yes, first try to extract it by welding to it and trying to spin it out. If not a helicoil will do. Thats what most people do.
Instagram:https://instagram.com/jpacione/
hotrodjoseph is offline   Reply With Quote
Old 08-13-2019, 05:18 PM   #22769
DarkSlide77
Yes sir, that’s exactly what I was looking for but I gave up on that because I found that H4 bulbs already come with that adapter. On top of that they’re supposed to be brighter. What seems to really be hard to find is the rubber seal on the circular openings on the rear of the headlight. I believe they are called “sockets”. There’s a rubber circular seal that’s supposed to go on the back of them to seal it from water etc.
Dang. The site won’t let me upload a pic to show you. Maybe I’ll try to add a link.
What is the link to that adapter anyway just in case??
Old 08-13-2019, 05:24 PM   #22770
DarkSlide77
https://www.ebay.com/i/233232838623?...gaAkHfEALw_wcB
This is the link just to see the circular rubber seals that are on the back of the Silvia headlight. The best way I would describe it is like a grommet kinda. If anyone has any idea where to find these or find another way to deal with it I’d like to hear it.
