Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Engine
Old 02-29-2012, 08:26 AM   #1
aptuned
aptuned is an unknown quantity at this point
USDM 240SX Replacement Parts
We carry a large assortment of Nissan 240SX Replacement Parts for the USDM 240SX and other Nissans.
Check out some of the parts we have in stock for the 240SX below:
A/C Condenser
A/C Expansion Valve
A/C Pressure Switch
A/C Receiver Drier
Acc. Belt Tension Pulley
Air Filter
Air Filter Perf. Kit
Air Mass Sensor
Air Temp. Sensor
Alternator
Alternator Brush Assy.
Antenna Mast
AT Filter
AT Filter Kit
AT Pan Gasket
AT Solenoid
Auxiliary Air Valve
Axle Nut
Blower Motor
Booster Check Valve
Brake Caliper
Brake Disc
Brake Hose
Brake Master Cylinder
Brake Pad Set
Brake Pedal Pad
Bypass Hose
Cam Plug
Cat. Converter Gasket
Catalytic Converter
Clutch Disc
Clutch Hose
Clutch Kit
Clutch Master Cylinder
Clutch Master Repair Kit
Clutch Pedal Pad
Clutch Slave Cylinder
Control Arm
Control Arm Bushing
Crank Position Sensor
Crankshaft Seal
CV Boot Clamp
CV Boot Clamp Kit
CV Boot Kit
Cylinder Head Gasket
Cylinder Head Gasket Set
Defroster Relay
Differential Seal
Distributor Cap
Distributor Rotor
Door Contact Switch
Driveshaft Support
EGR Temperature Sensor
EGR Vacuum Controller
EGR Valve
EGR Valve Gasket
Engine Gasket Set
Engine Mount
Exhaust Flange Gasket
Exhaust Gasket
Exhaust Hanger
Exhaust Manifold Gasket
Exhaust Mount
Exhaust Valve
Fan Clutch
Flasher Relay
Fog Light Bulb
Fog Light Relay
Fuel Filter
Fuel Inject Cushion Ring
Fuel Injection Relay
Fuel Injector
Fuel Injector O-Ring
Fuel Injector Seal
Fuel Pressure Regulator
Fuel Pump
Fuel Pump Relay
Fuel Tank Cap
Hatch Strut
Headlight Bulb
Headlight Relay
Headlight Sealed Beam
Heater Core
Heater Hose
Horn Relay
Idle Control Valve
Idle Valve Gasket
Ignition Coil
Ignition Coil Wire
Ignition Distributor
Ignition Lock Assembly
Ignition Module
Ignition Switch
Ignition Wire Set
Input Shaft Seal
Intake Manifold Gasket
Intake Plenum Gasket
Intake Valve
Intermediate Gear
Knock Sensor
Light Bulb
Main Bearing Set
Multi Rib Belt
Oil Drain Plug
Oil Filler Cap
Oil Filter
Oil Pick-up Tube O-Ring
Oil Pressure Sender
Oil Pump
Oil Pump Gasket
Output Shaft Seal
Oxygen Sensor
Oxygen Sensor Nut
P/S Hose Assembly
P/S Pressure Hose
P/S Pump
PCV Valve
Pilot Bushing
Pinion Seal
Piston Ring Set
Pressure Plate
Rad. Drain Plug Gasket
Radiator
Radiator Cap
Radiator Drain Plug
Radiator Hose
Radius Rod
Relay
Release Bearing
Rod Bearing Set
Shock Absorber
Shock Bellows
Shock Bump Stop
Shock Mounting Kit
Spark Plug
Spark Plug Seal
Speedometer Sensor
Starter
Steering Rack
Steering Rack Boot Kit
Stop Light Switch
Strut Assembly
Strut Insert
Strut Mount
Sunroof Relay
Sway Bar Bushing
Sway Bar Link
Sway Bar Link Bushing
Sway Bar Link Washer
Tail Pipe Extension
Thermostat
Thermostat Housing Cover
Throttle Position Sensor
Tie Rod End
Timing Chain
Timing Chain Tensioner
Timing Cover O-Ring
Timing Gear Kit
Timing Guide Rail
Transmission Mount
Valve Cover Gasket
Valve Cover Gasket Set
Valve Stem Seal
Washer Pump
Water Pump
Water Temp. Sensor
Water Temperature Sender
Wheel Bearing
Wheel Hub Assembly
Wheel Seal
Wheel Stud
Window Relay
Wiper Blade
aptuned.com
aptuned is offline   Reply With Quote
Old 03-01-2012, 07:04 PM   #2
Chuvy
Chuvy is an unknown quantity at this point
you guys are based in reno?
Chuvy is offline   Reply With Quote
Old 03-02-2012, 01:34 AM   #3
Psycho 240 Freak
Psycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-known
Awesome, saved to my favorites so I can look up oem parts next time I need them.
Psycho 240 Freak is offline   Reply With Quote
Old 03-06-2012, 11:10 PM   #4
satal95
satal95's Avatar
Trader Rating: (24)
satal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud of
Feedback Score: 24 reviews
Can you get vert parts
Signature image exceeds allowable size.
satal95 is offline   Reply With Quote
Old 03-13-2012, 08:54 AM   #5
aptuned
Which vert parts are you looking for? If it's specifically for the top, we can't get it at this time.
aptuned.com
